Cruise Control
Discussion in 'Gen 5 Prius Technical Discussion' started by maiki, Aug 9, 2025.
  1. maiki
    maiki Member
    213
    32
    I just got a 2025 Prius Plug in XSE Premium (with advanced technology package, and every premium feature) about a week ago, and am trying to figure things out? So please forgive newbie questions.
    I tried to use Cruise Control last night while driving on an LA freeway. I pushed the Cruise Control button, and got an error message, and it did not work.. (I forget what it said, something about look in the manual.)
    Shouldn't it just work? Is there some kind of pre-condition for it?
  2. soft_r
    soft_r Active Member
    187
    152
    Beverly Hills
    2024 Prius
    Maybe you should look in the manual like it told you to.
    Maybe you should try it more than just the one time and then if the error message comes up you should try committing the message to memory for later to help you resolve the issue.
    Maybe you should also consider post subjects that clearly define your post.
    But then this is just standard Cali driver brain I guess.
    KMO, PrimeDan and LRO like this.
  3. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    What speed where you going? There is a minimum else you get a beep trying to engage it.
    Since you were on the freeway I'll assume where we above the minimum.
    To the right of the CANCEL button there is a button that toggles between traditional curise and adaptive cruise control. Make sure it's flavor you want.
    maiki likes this.
  4. maiki
    maiki Member
    213
    32
    I guess insulting people makes you feel good, eh? To each his own.
    Leo and pramodhrachuri like this.
  5. maiki
    maiki Member
    213
    32
    I didn't notice that. Adaptive means the car would slow down if the car in front of it slows down? Why might one not want that?
  6. schja01
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    There are conditions where Adaptive is not recommended eg. heavy rain, snow etc. You "could" use Non Adaptive in those types of situations I guess.
    otatrant likes this.
