Break in oil
Discussion in 'Gen 5 Prius Main Forum' started by John Berger, Feb 2, 2025.
  1. Gokhan
    Gokhan Senior Member
    6,546
    2,613
    Paramount CA
    Toyota engines do not need break-in oils. That was for flat-tappet engines of the long-gone past. Moreover, even the SAE 0W-8 oil today protects the valvetrain better than the SAE 20W-50 oil of the past.
  2. rjparker
    10,523
    6,605
    I agree 100% on this one. Change the oil at 500-1000 miles using factory specified oil, not any "special" break in oil. No additives as well.
    It's not a bad idea to let the dealer do this with specific instructions to look for any fluid seeps or other new car defects.
  3. Trollbait
    12,689
    0w20 is acceptable by the manual. Toyota just says to change it in 5000 miles when it is used.
  4. Paul Gregory
    Paul Gregory Senior Member
    2,235
    593
    Alberta
    2024 Prius Prime
    XSE
    I believe that the reason my Gen 3 Plug-in lithium battery lost very little capacity over 12 years, was because I did not plug it in often. I ran it in hybrid mode most of the time.
  5. Mendel Leisk
    41,911
    Our Hondas and this latest Toyota do have break-in period recommendations, in the Owner's Manual. That said, it's very simple, just take it easy on the brakes as much as possible, and avoid long highway road trips on flat terrain.
    PrimeDan likes this.
  6. Mendel Leisk
    41,911
    That always strikes me as a copy-and paste exercise:
    Gen 2:
    Gen 3:
    Gen 4:
    Gen 5:
    plainv70 likes this.
  7. keryst
    keryst New Member
    Pittsburgh, PA
    2024 Prius Prime
    SE
    HV mode seems to want to keep the battery at near the same soc, so as long as you aren't keeping it at 100%, that seems like the battery would last forever. But I do look forward to using it in pure ev around town.
  8. mva
    mva Member
    154
    92
    B.C. Canada
    2024 Prius Prime
    SE
    I bought the Prime specifically to use the EV mode as much as possible. That's where the payback and environmental benefits lie - I live in an area with cheap hydroelectric power and expensive gasoline combined with moderate speeds on most the roads i regularly drive. I would own a full EV but I wanted the gasoline hybrid optionfor long trips.
    I'm going to trust that Toyota has done a good job designing the battery for long life, even beyond the generous warranty period.
  9. CalvinL
    CalvinL 2025 Prius Plugin XSE Royal Green PPF
    100
    28
    Long Island, New York
    2025 Prius Plug-in
    XSE
    I have the Plugin XSE so I opted to bring it in at 1500 miles because I initially used mostly electric for the first 800ish miles. The plugin defaults to electric so had to keep remembering to engage hybrid mode or charge mode (highly inefficient mode btw).
  10. ETC(SS)
    7,358
    You should do that anyway.... ;)
    frodoz737 likes this.
  11. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Well… maybe?
    When you build an engine, the standard method is to apply assembly lube to all of the hearing surfaces. This line contains zinc, phosphorous, (ZDDP) and molybdenum… the same things used in break-in oil. It explains why we see metal in the first oil drain and it also explains why break-in oil isn’t necessary… you’re just draining out the ZDDP and replacing it with ZDDP. Go figure.
  12. Gokhan
    6,546
    2,613
    Paramount CA
    If a short-interval oil change were needed for the factory fill, Toyota would say so. There is no need to wash away the factory-fill oil.
    Regarding metal shavings, I don't see how they would harm the engine. They either get caught in the oil filter or eventually get drained. They only cause problems if there is a manufacturing problem, which may need a recall, and chances are that a short-interval oil change doesn’t help much.
  13. rjparker
    10,523
    6,605
    Small metal shavings (which can be microscopic) are bad for bearings long term. Large amounts accelerate the problem as was seen with the new Tundras. Toyota is changing over100,000 of those engines.
    Considering Toyota will do the first two changes free on their new cars, using them early makes sense to me on our new cars.
  14. PriusCamper
    PriusCamper Senior Member
    13,071
    5,306
    Pacific Northwest, USA
    That's an excellent point... Of course assembly lube is a very small volume compared to someone using break in oil for a race car cam shaft for example.
    And there's always going to be fine metal particulate when using new machinery for the first time so while I think you're mostly right, I still think the data from when we were testing proves its wise to get your trans oil swapped out at least once over the lifespan of the vehicle. I mean it may sound silly because planetary gears have no way to wear out to the point of failing, but it still makes sense and its why I'd recommend it, among many others things, if I was going to keep the same hybrid car as a daily driver for decades.
    Rebound likes this.
  15. Mendel Leisk
    41,911
    The first time I changed transaxle fluid, at about a year and 10k miles, was by far the darkest. I did a couple more, at longer intervals, seemed increasingly pointless.
    PriusCamper likes this.
  16. ETC(SS)
    7,358
    As pointless as a 'break-in oil' argument? :ROFLMAO:
  17. plainv70
    plainv70 Junior Member
    Naperville
    2024 Prius
    The color of lubricating oils is not a definitive measure of its condition by itself. Modern motor, transmission, transaxle, rear wheel diffs in AWD systems (those with low viscosity oils) lubrication oils are formulated with long-life stabilizer packages. Typical additives in this category for very colored byproducts, as they are consumed, which will darken an oil very quickly--despite the oil having significant usable life left. These colors start with reddish, then go purple to deep purple, almost black, depending on the concentration of the byproduct in the oil. The rate of discoloration is also temperature dependent; short periods of relatively higher heat can cause premature discoloration of the oil while still having many miles of usable life left.
  18. plainv70
    Naperville
    2024 Prius
    ZDDP is a catalytic converter poison. I can envision assembly lube being used, however but, it would be foolish to use a high ZDDP break-in oil and leave it in for 10k miles. I do not know what Toyota puts in its engine for the OE fill, but I would be surprised it is anything more than a OE spec motor oil. Engine design & manufacture, as well as lube technology are a far cry from internal combustion tech of the 60s, 70s, even into the 80s, and prior.
  19. Mendel Leisk
    41,911
    Concur. It's the stuff that's normally in there. Last link in my signature is the full engine section from Repair Manual. I doubt there's mention of anything other than motor oil, for the engine internals during assembly..
    (on a phone turn it landscape to see signatures)
  20. MScelery
    MScelery Junior Member
    83
    24
    Mississippi
    I must have overlooked this part. A little concerned because I’m picking up a new Prius later today that I’ll have to drive back home on a 7-hour drive…
    can you explain what taking the long highway trip on flat terrain does negatively to the Prius?
