Better to let run before shutdown?
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Aug 12, 2025.
  1. cyberpriusII
    1,157
    1,822
    Mars Hotel
    Hey all: I needed to close my car windows, so I started the car and let it run for a minute or so before closing windows and shutting off the engine.
    A co-worker questioned me and asked why I kept the car running.
    Well, I don't really know, but I do remember my dad always said to never start a cold engine and then immediately shut it down again. At least I think he said that...something about it not being good for the car.
    Is, or was, that a "thing."???
    Or should I start, close and shutdown with no "waiting period."
    I looked about the web and only found stuff about to drive or not to drive on a cold engine. Well, in any case I have been doing it his way for nearly 20 years.
    kris
  2. ChapmanF
    18,463
    It is definitely a thing with gen 3. Shutting down after a brief run can leave condensed water in the skinny EGR passages, and then on the next start the engine will bang like the hammers of Hephaestus for a long moment before smoothing out.
    I haven't heard the same thing about gen 2.
    But never mind all that, you don't need to start the engine at all to roll the windows up. You can just go to IG ON (two button pushes without brake), roll the windows up, and switch the car back off (one more push, no brake). No going READY, no starting the engine, no waiting.
  3. PriusCamper
    PriusCamper Senior Member
    12,991
    5,284
    Pacific Northwest, USA
    For 20 years you have been making exposure to deadly poisons worse for you and your loved ones. Here's 3 different reasons for why you need to stop doing that!
    1) Long ago you needed to warm up a car engine, especially big trucks in cold weather because it took a while for the oil pump to get everything in the engine well lubricated... But as time went by and engines got more modern you no longer had the need to wait on lubrication to optimize.
    2) Another reason people used to wait for the engine to warm up is because you needed the intake manifold and carburetor to heat up to better vaporize the fuel so the engine worked normally. When Fuel Injection came along in the 80's waiting for it all to heat up was no longer necessary.
    3) "Existing literature, as well as analytical tools like the U.S. Environmental Protection Agency’s Motor Vehicle Emission Simulator (MOVES), indicate that while total vehicle emissions have dropped significantly in recent years, those associated with cold starts can still constitute up to 80% for some pollutant species. Starting emissions are consistently found to make up a high proportion of total transportation-related methane (CH4), nitrous oxide (N2O), and volatile organic compounds (VOCs). After 3–4 min of vehicle operation, both the engine coolant and the catalytic converter have generally warmed, and emissions are significantly lower." https://www.sciencedirect.com/science/article/abs/pii/S1361920915002229
    and
    "Toxins released during cold starts
    • Benzene: A known human carcinogen and neurotoxin, benzene is present in gasoline and emitted during incomplete combustion, according to ScienceDirect.com and the Colorado Department of Public Health and Environment (.gov).
    • Formaldehyde & Acetaldehyde: These are air toxins and volatile organic compounds (VOCs), which can contribute to respiratory issues and other health problems.
    • Carbon Monoxide (CO): A colorless, odorless, and highly toxic gas that can restrict the blood's ability to carry oxygen and lead to serious health problems or even death.
    • Nitrogen Oxides (NOx): These pollutants contribute to smog and can cause respiratory problems.
    • Particulate Matter (PM): Fine particles released during combustion that can penetrate deep into the lungs and cause respiratory and cardiovascular issues.
    • Volatile Organic Compounds (VOCs) and Intermediate VOCs (IVOCs): These organic gases are important precursors to secondary organic aerosols (SOAs), which have adverse impacts on air quality and human health."
    • From: https://www.sciencedirect.com/science/article/abs/pii/S0304389422007683
    #3 PriusCamper, Aug 12, 2025
  4. PriusCamper
    12,991
    5,284
    She's said she no longer drives a Prius in previous posts... If she was still driving a Prius she could roll up the windows and be done with it before the engine even started.
    As for water in the EGR passages that would be a problem on a car that's rarely driven, but that line of thinking seems like nonsense if its a daily driver.
    #4 PriusCamper, Aug 12, 2025
  5. ChapmanF
    18,463
    For gen 3 it has been a nuisance known from the earliest days, with the first reports rolling in around October 2009 for spanking-new 2010 model year cars, only on a next start after a short no-warm-up run followed by a cold soak, with Toyota's response a couple years later in January 2012.
    Water in the EGR passages isn't any great mystery, given that those passages carry ... exhaust, which is 13% water. It's usually there; I poured a noticeable amount of clear water out of mine when I cleaned the system.
    Only, for it to fill the passages enough to be snorted into the intake on the next startup, it seems to take a short, no-warm-up engine run followed by a good while sitting cold.
  6. Stevewoods
    Stevewoods Senior Member
    663
    1,194
    Seattle, WA
    Looks as if Kris' "let it run" mantra has some merit at least sometimes with the right rig, such as G3.
    But I suspect her dad was was talking about less exotic rigs and if it was a good idea then, is it still smart to let it run a bit?
    As a WAG, IT may have some merit,but...?
    This would had been a great question for Tom&Ray on CarTalk. Heck, they may have covered it.
    https://www.cartalk.com/
    #6 Stevewoods, Aug 12, 2025
    cyberpriusII likes this.
  7. PriusCamper
    12,991
    5,284
    #7 PriusCamper, Aug 13, 2025
  8. PriusCamper
    12,991
    5,284
    They actually did... It was a hilarious husband and wife dispute.... I'm not able to dig that recording up but CarTalk laughed and told jokes like they always do and they were 100% on the side of start your car up and drive away (but go easy on driving it as it warms up) ---> minimize poisons to family and neighbors! Cold engine air pollution is highly toxic!
    #8 PriusCamper, Aug 13, 2025
  9. PriusCamper
    12,991
    5,284
    #9 PriusCamper, Aug 13, 2025
  10. Hayslayer
    Hayslayer Active Member
    446
    262
    Drunk posting?
  11. ETC(SS)
    7,324
    ^ Usually.
    At the risk of actually answering the OP it's OK to roll up the windows without starting the car - in fact, it's probably better than starting the car to do so - but mostly???
    It's a difference without much of a distinction.
    This isn't 1930, and even marginally built cars will last well over 100,000 miles under normal use which will certainly include a few short start/stop cycles.
    Oil is a little bit different too which is the reason for the overly long oil change periodicities that the OEMS use.
    Priuses have criminally small aux (12vdc) batteries - and they mostly can get away with it because they do not have separate engine start motors.
    EVEN IN A PRIUS, if your aux battery dies because you use it to roll up your windows you didn't CAUSE a problem you DETECTED one. Most other cars these days still have two things that will probably be with us for a while longer.
    Start motors for ICE cars and inept government regulation - in case you're not familiar (or cursed) with the auto-stop-start (A.S.S.) feature.
    This means that normy cars are ALSO going to be forced to have adequately sized 12vdc batteries - at least for a while.
    In my never-to-be-humbled opinion?
    You may as well use it to roll up the windows.
    MY mileage.
    Yours will undoubtedly vary....
    #11 ETC(SS), Aug 13, 2025
  12. bwilson4web
    16,332
    These are significant electrical loads on the 12 V battery:
    • Window motors - have a high current load. Brief but significant as shown by the fuse rating in your car fuse box.
    • Starter motor - often measured close to 100 Amps, starting the engine needs to run a minute or so for the alternator (formerly generator) to replace the charge on the battery.
    If you have a weak, 12V battery, operating the window motors could deplete it enough there might not be enough charge to start the engine. But if the engine starts first, in a minute, the starting current load will be replaced and the alternator can immediately handle the window motor current.
    IMHO, as long as the battery is not over 5 years, just turn on the ignition and close or open the window. If you are trying to stretch a weak battery, start the car first. If it starts, no problem. If it doesn't, get a battery jump and get thee to a parts store.
    Back in the day when headlights were incandescent, you could turn them on and see how badly they dimmed as a crude battery health check under different loads. Of course that was when I had hair.
    cyberpriusII and Trollbait like this.
  13. ChapmanF
    18,463
    The one time it most irritated me was when I was searching for a spot in a very full parking garage and I saw someone walk to her car and get in. The lights came on. The car started. I waited. The car blocked behind me waited. The car blocked behind that car waited. At the point when there were about six cars blocked behind me, I got out of my car and walked up to the one in the spot and asked whether she was planning to leave that spot at any point, and she said "sure, as soon as my engine warms up".
    She was in a Prius.
  14. Trollbait
    12,653
    Any car can close the windows in IG ON. As Bob says, the only reason to turn on the engine is if the 12V is old or weak.
    As for other reasons with starting engine, letting the engine warm up after start up sounds like something from older cars. Perhaps leading to starting issues later with carbs.
    cyberpriusII and PriusCamper like this.
  15. Mendel Leisk
    41,829
    Diesel truck manufacturers sometimes recommend to idle, say for 5 minutes, after a cold-start. Just remember from one time getting a ride home after work.
  16. bisco
    52,294
    suburu?
  17. rjparker
    10,415
    6,522
    Exactly.
    However leaving your windows open when parked is not a great idea in a highly computerized car. Obvious issues if it rains. One woman I know left her windows open and a raccoon got in to survey the situation. It hid under the seat when she returned to close the windows. The interior was shredded the next morning.
    We won't even talk about mice.
    #17 rjparker, Aug 13, 2025
  18. PriusCamper
    12,991
    5,284
    Idling for more than 5 minutes is prohibited within California's borders (exceptions apply). While at a school, the driver must shut down the engine immediately upon arrival and leave within 30 seconds of starting the engine. https://ww2.arb.ca.gov/sites/default/files/2020-12/commercial_vehicle_idling_requirements_July%202016.pdf
  19. bisco
    52,294
    she's lucky that's all it did
  20. Stevewoods
    663
    1,194
    Seattle, WA
    One important clue here.
    Kris' father's tip.
    Which probably means her father is (was) a 1950s kid such as myself growing up working on old beaters with clutches, chokes, Pep Boy Cadet batteries, which we all filled with tap water, though we were supposed to use distilled.
    So, Chapman, Bob, Trollbait, ETCS most solidly hit the concern, but a few others also alluded to: Not killing the battery.
    Kris' Outback, if it is a few years old probably has the 320CCA, same as my starting battery in my Outback (Subaru has since doubled the CCA).
    While for many modern cars, her father's method may be outdated, for others, not so much.
    BTW, after killing the OEM 320CCA in my Subaru several times, I finally replaced with 730 CCA, or something like that and no problem since. Yeah, Just check Subaru forums for that whole issue.
    #20 Stevewoods, Aug 13, 2025
