I recently bought 2007 Prius from a customer that did not want to fix it. My dilemma is the key fob ( smart key) The key i does not have the little chip in it. Where can i get this chip?
UHF supply possibly or if all lock and key is still around they were in Maine . I'm sure they're are others . They're are universal fiba available can be programmed like most . You will need some one who can clone . Is the grey sticker inside remote on the lil rectangle it goes on under first slide ? This is you're FCC I'd code
Need more information. What exactly is the problem? The Prius came with the SKS system or it didn't. The ones that do have a black button on the front door handles and hatch. If your car has SKS, you need the fob that supports SKS (aka keyless go). There is a separate immobilizer ID "chip" embedded in the fob of both the SKS and non-SKS fobs. It's a small 5 sided black plastic chip (rectangular shape with a corner bevel). This unique chip is paired to the car's immobilizer ignition system which allows your fob to start the car when inserted into the key slot.
