smart key fob
Discussion in 'Gen 2 Prius Technical Discussion' started by Tracyheal915, Aug 13, 2025.
  1. Tracyheal915
    Tracyheal915 New Member
    El Paso Texas
    I recently bought 2007 Prius from a customer that did not want to fix it. My dilemma is the key fob ( smart key) The key i does not have the little chip in it. Where can i get this chip?
  2. Tombukt2
    13,765
    2,491
    UHF supply possibly or if all lock and key is still around they were in Maine . I'm sure they're are others . They're are universal fiba available can be programmed like most . You will need some one who can clone . Is the grey sticker inside remote on the lil rectangle it goes on under first slide ? This is you're FCC I'd code
  3. Tombukt2
    13,765
    2,491
    Is remote silver back logo with key button under steering wheel,?
  4. Tracyheal915
    El Paso Texas
    There is no original key. It does run. And yes there is a key button under column.
  5. xw20_driver
    xw20_driver Member
    118
    59
    PNW
    Need more information. What exactly is the problem?
    The Prius came with the SKS system or it didn't. The ones that do have a black button on the front door handles and hatch. If your car has SKS, you need the fob that supports SKS (aka keyless go).
    There is a separate immobilizer ID "chip" embedded in the fob of both the SKS and non-SKS fobs. It's a small 5 sided black plastic chip (rectangular shape with a corner bevel). This unique chip is paired to the car's immobilizer ignition system which allows your fob to start the car when inserted into the key slot.
  6. Tracyheal915
    El Paso Texas
  7. Tracyheal915
    El Paso Texas
    That's what I thought. But does Toyota sell just the ID chip Or do you need to buy the Key assembly. Like I said I purchased it frum a customer and only got a clone key. But thank you for the Info. Toyota can't tell me if the chip comes with the new key set.
  8. xw20_driver
    xw20_driver Member
    118
    59
    PNW
    If you order the factory replacement with the silver logo, the dealer can program it. It should include the ID chip.
    I have purchased three smart fobs off of Aliexpress, all are SKS clones and include a blank blade. The first one included an ID chip that was not recognized in the car. I surmise it is a blank chip that needs to be cloned off of the original chip using a special tool. The 2 other ones I purchased from a different seller both included ID chips and both were fully programmed to my 2007 Prius using the "chicken dance" method. It cost less than $20. Store name YRCARKIT Official Store.
    To perform the chicken dance method, you do need a working original key. Without any keys, you need a special tool to put the car into lost key mode to pair a new key.
    #8 xw20_driver, Aug 14, 2025
  9. Tombukt2
    13,765
    2,491
    If you buy a new key from Toyota the complete key fob it will come with a board it's green has the white looking chip thing with the numbers . And the trapezoidal chip too and the grey is codes on sticker inside too . And electronics folks can decipher . Locksmith w transponder chip burner if you will can generally fix you up. The fob is complete as new and costly . Might but on eBay or check local car lots they have boxes of remotes to trash .
    xw20_driver likes this.
  10. Tombukt2
    13,765
    2,491
    When buying off eBay or AliExpress you have to be careful if you understand how some this works . Welp it may help . Reading the first 8 pages of the SKS or non SKS is a good start. a locksmith with electronic tools and whatnot can read numbers in cars systems and clone accordingly. Or burn new chip with the number the vehicle expects
