Auto Window Switch Question
Discussion in 'Gen 2 Prius Main Forum' started by qmanqman, Aug 12, 2025.
  1. qmanqman
    qmanqman Active Member
    439
    152
    CO
    I recently learned (12 year old grandson enlightened me) that the drivers door Auto window switch has two clicks in it that determine auto or manual roll up/down. I always thought it was a random action. Probably one of the dumbest questions ever asked but has anyone determined if you could get one of them auto switches and swap it into the other 3 slots? I'm guessing not but with my new found knowledge I came up with this fantastic new idea.
    I can only find the master switch and the passenger switch. I cannot find the Auto switch all by itself.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,086
    1,997
    NJ-USA
    Not a dumb question, but no, you can't have "auto" function on the other 3 windows.
    The driver's window uses special hardware that's built into the window mechanism, the other windows don't have that. Also there is fancy electronics built into the driver's switch (all 4 switches at the driver's door are built into one "master switch assembly").
    There is no feasible way to do this.
  3. qmanqman
    439
    152
    CO
    That's kinda what I figured. Was just hoping someone made it happen. You know "where there's a will, there's a way." I just don't have the will.
