C2318 yet 12v is good
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ironandsteel, Aug 14, 2025.
Tags:
  1. ironandsteel
    ironandsteel Junior Member
    Battery voltage is 13.2 (it is on a charger). If not low 12v battery, what can it be? I pressed the blue splat and got data that i don't know how to interpret. IMG_20250814_163430Z.jpg
    51,845
  3. Tombukt2
    12,904
    2,317
    The blue splat equal snowflake in Prius speak. He is using tech
  4. Tombukt2
    12,904
    2,317
    In that data you can interpret. You see about 4 lines down battery volt value 7.4 or some nonsense . That's part of it . You reading 12 plus but the car is seeing 7 volts of what you see.. problematic . Wer other voltage disappearing to?
  5. LKasdorf
    LKasdorf Junior Member
    77
    24
    Waterford, VA USA
    Techstream. Blue splat = snowflake- get more data on the code. The 12v batt tests good with a load tester.
    I saw that 7.4 and I don't understand what could cause that.
  6. bisco
    51,845
    rodents chewing on wires, corrosion on ecu connectors
  7. ChapmanF
    18,078
    Voltage higher at point A than point B ⇒ scrutinize the whole electrical path from A to B. The problem is somewhere.
  8. Brian1954
    Brian1954 Senior Member
    2,154
    837
    South Central PA, USA
    You are again logging on to the PriusChat forum using two different user names in the same thread. This makes it difficult to follow your discussion when you do that. You should only use one of your two usernames to log in to this forum.
    You did the same thing back in January of this year, and here is your response,
    #8 Brian1954, Aug 14, 2025
  9. ironandsteel
    I have mended my duplicitous ways... I post from my phone and my desktop.
    The problem was that I was signed in on my phone as LKasdorf. I have signed out and back in as ironandsteel. At one point, I guess I didn't remember if I already had an account and made a new one.
    #9 ironandsteel, Aug 15, 2025
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,036
    1,965
    NJ-USA
    Per Chapman's post, point A is the 12V battery (13.2V with your charger). Point B is the transmission control ecu (which showed around 7.4V in your data capture). So somewhere between A & B is high resistance on the power or ground side - resulting in voltage "drop".
    The "transmission control" on a Gen2 is really just the motor and ecu that applies and releases the "park pawl" that prevents the car from rolling away when you turn it off.
    Now, a not uncommon problem on the Gen2 is corrosion at a connector in the underhood fuse box. At the top left corner under the black cover is a white connector. Specifically a blue wire at this connector that supplies 12V power to the transmission control ecu.
    The usual repair is to cut and splice the blue wire from both sides together, bypassing the damaged connector.
    FYI, we use the term "snowflake" for "the blue splat". That symbol means that the ecu has stored freezeframe data - a "snapshot" of information and details for that system from when the code was set. fuse%20box1.jpeg fusebox%20conn2.jpeg
  11. ironandsteel
    mr_guy_mann - THANK YOU! Great info. I will look for that corrosion. The car has been sitting undriven for 5 -6 months.
  12. ironandsteel
    Ok- I pulled that connector and saw no signs of corrosion. Still, I used DeOxit and a brush and cleaned the contacts. I put the connector back in and now I get absolutely nothing when I press the start button. I do get the open door icon when the door is open, and the blue headlight icon when I turn on the headlights. In the under-hood fusebox, I get the correct battery B+ voltage at the big main connector at the upper left.
    I checked all the fuses, and they are good.
    So, what can cause no display at all when I presss start? BTW, the fob has a good battery and I have it plugged in to the slot in the dash.
  13. pasadena_commut
    pasadena_commut Senior Member
    2,588
    767
    Southern California
    Is C2318 for the sense wire that comes off the battery? If so, perhaps back probe that connector with a voltmeter at the battery and verify that it is the same as the voltage on the big battery cable. In that box which attaches to the positive terminal, under the red removable cover, there is a large fusible link between the battery and the thick cable, and there is additionally a small fuse (15A? Don't recall) between the fusible link and the sense wire. The battery is no doubt being charged with a clamp on the metal attached to the positive terminal, so the battery voltage should be fine, at least with the charger on. There must be enough current going through the big cable for the car's computer to run. So the fusible link must be good too. Perhaps though the little fuse is almost but not quite completely blown? That could drop the voltage the car sees on the sense line. Come to think of it, unplug the sense line and see what voltage the car sees. I don't know how that circuit works, it is possible that they bias that side to around 7 volts and then see if it pulls up when the sense wire is attached. If it is the same 7.x V with and without the wire the simplest explanation is that the little fuse is blown.
  14. ironandsteel
    Just to clarify- as of a few days ago, if I stepped on the brake and pressed the start button, it would come to life sorta. Now, after pulling that big connector at the top of the fusebox, cleaning, and re-connecting- the dash is totally dead (except for the door open icon, and headlight icon). Pressing the start button does nothing at all.
    I will re-check the connectors at the 12v battery for corrosion.
    I need to find a schematic.
  15. rjparker
    10,090
    6,260
    I would go back to the last thing you did and check it again. There could be bent pins or incomplete connection.
    You should also check the 12v battery voltage at the fuse box with the headlights on high to create a load. A battery can have a poor internal or external connection that provides good voltage with minimal load but much lower voltage under load.
    #15 rjparker, Aug 21, 2025
    Brian1954 likes this.
  16. ironandsteel
    Ok- I am a giant dummy. When I cleaned the male and female contacts on that connector under the black cover in the fuse box, I used a soft brass wire brush. Soooo... sine B+ is one one of those pins, I inadvertantly distributed it randomly to various other pins. Maybe I just blew some fuse. I'll be lucky if I didn't fry something.
    Jeez, I can be an idiot sometimes...
