no ignition key beep headlights nolonger automatically turn off
Discussion in 'Gen 2 Prius Main Forum' started by Meter guy, Aug 11, 2025.
  1. Meter guy
    Meter guy Junior Member
    53
    I did some searching before i posted but not seeing any specific answers to my question. one post about the headlights was a very long one about diagnosing the hybrid system.
    my 09 prius with 287K daily driver, original traction battery.
    my key fob no longer works wirelessly so i just plug it into the dash. (probabally been that way for 5 years)
    a week or 2 ago i noticed that it was no longer beeping at me to remove the fob when i turn off the power. i noticed tonight that it also doesn't automatically shut off the headlights like it has for years.
    the fob receptacle lights still come on, but they also aren't on at times too, but i never really paid close attention to them. also, the immobilizer light on the dash is off when the fob is inserted in the receptacle, that appears normal.
    car turns on and off fine, otherwise.
    any thoughts?
  2. Tombukt2
    13,198
    2,386
    There's about a 80 pages of troubleshooting in manual a guy posted online copy yesterday in similar thread.
  3. bisco
    52,186
    get a free 12v load test at most auto parts stores
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,071
    1,987
    NJ-USA
    Does the dome light work when you open the driver's door? (and do you get the red "door open" icon on the dash?)
  5. Meter guy
    53
    no, the dome light doesn't work when i open the door. another thing I noticed, there's a stop light i have to sit at in the morning on the way to work, and while I'm waiting, I swish some mouthwash, open the door and spit it out. normally when i do that, it puts out a solid tone, the red triangle comes on and it says shift into park on the MFD. it does none of that now. I even tried the passenger door and it doesn't do anything either.
    I can manually turn on the dome light with the switch, but it doesn't work automatically.
    several years ago i replaced the dome light with an LED and lately, the dome light has a very very dim illumination, and it flickers randomly. that's a symptom i bet no one can attest to because most people don't have an LED bulb and a regular bulb would require more current than that to light up,
    ive also noticed a Radio issue, when i first turn on the car, there will be loud static thunder crashing for maybe 30 seconds and then the static will dies down and the music will play. there are times theres no static crashing and the radio/cd player doesnt play.i even replaced the stereo and the replacement did the same thing. thats been happening longer than this issue.
    #5 Meter guy, Aug 14, 2025
  6. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    Weird symptoms...how old is your 12volt battery? 3-5 years? If parked in Florida heat.....could die as early as 2 years. When I lived in Florida I had trouble like that. Reading the codes with a quality OBD should reveal more info. But on the parts cannon list (when I had....very weird things happen..randomly a new 12Volt battery fixed it. also sounds like it could be chewed wires. Do you park in a garage? Maybe Mice?
  7. mr_guy_mann
    4,071
    1,987
    NJ-USA
    I might want to look at the switch that lets the Body control ecu know that you have opened the door.
  8. Meter guy
    53
    my 12V battery is about 3 months old. i read codes today and it only had the typical P1123 or something like that, indicating issues with the coolant valve, a common problem
  9. Meter guy
    53
    im wondering if its the body control computer, i was reading online that they sometimes develop corrosion on the pins and flaky stuff can happen. its under the top dash on the drivers side, ill Probably pull it this weekend and try to inspect and clean the contacts.
  10. Meter guy
    53
    Removed the BCM from the car tonight, all the pins look shiny, no corrosion observed. I pulled the board and looked it over, no burned components and no smell of anything burned, the conformal coating looks good. I do however see the silver electrolytic SMT caps. this is located several inches from the speedo board, and the speedo caps of the same design are notorious for going bad in the heat. I'm thinking about replacing all the caps.
    also thinking about getting a BCM from the junkyard to see if it might just work better or differently.
    I see mixed info online, some say the junkyard BCM needs to be reprogrammed by Toyota, while there's some others that say no. I also saw a video of someone swapping IC001, the little chip at the top of the photo
    this guy only says it needs to have similar product codes
    How to replace multiplex MPX ECU computer Toyota Prius. Years 2002 to 2009
    #10 Meter guy, Aug 17, 2025
