Another head scratcher
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by David Mc, Aug 14, 2025.
  1. David Mc
    David Mc Junior Member
    Indiana
    I have the Triangle.
    The problem is the car system says both 12v (12.1) and hybrid (14) are ok.
    However the screen shows the batter not charging while driving then eventually kicking into limp mode.
    After getting home and shutting off and checking hybrid it still reads 13.9 to 14.1 restarting car allows me to drive again for a short distance and the screen shows it charging till it kick off again. Usually 4 miles or less.
    Is this the inverter failing or something else as I'm stumped.
  2. Brian1954
    Brian1954 Senior Member
    2,363
    950
    South Central PA, USA
    Read the trouble codes using a capable scanner.
    #2 Brian1954, Aug 14, 2025
  3. ChapmanF
    18,436
    ^ This.
    Because there are a couple hundred reasons that triangle can be on, it's generally premature to start asking "do I agree with what the car is saying?" before knowing which of 200 things the car is saying.
  4. bisco
    52,263
    where does the car tell you the hybrid battery is okay?
    Brian1954 likes this.
  5. Tombukt2
    13,264
    2,395
    The 14 has nothing to do with the hybrid battery buddy
  6. bisco
    52,263
    what does it have to do with?
  7. Tombukt2
    13,264
    2,395
    It tells ya the DC to DC converter is producing the voltage to maintain 12V systems . Tells me nothing about the 200Volt DC HV system at all me no think . I mean because it's charging the 12V is not much
  8. David Mc
    Indiana
    When you do the car test the MFD gives you the numbers for both the 12v and the hybrid which is where I got my numbers from.
    The only scanner I have is a Harbor Freight OB2 iirc.
  9. T1 Terry
    T1 Terry Active Member
    929
    491
    12v on a 12v lead acid battery, means all the capacity is gone and the battery is down to 50% SOC ..... 12v battery is in the process of passing over to the other side .....
    The 14v is probably the voltage at the 14v battery with the system on, meaning the DC to DC is applying 14v to the DC circuit.
    T1 Terry
  10. dolj
    dolj Senior Member
    8,502
    4,314
    Wellington, New Zealand
    It does no such thing. I'm not sure where that idea has come from, but it is wrong.
    Probably came from AI. LOL.
    ^^^ This. ...
    ^^^ and this.
  11. mr_guy_mann
    mr_guy_mann Senior Member
    4,072
    1,990
    NJ-USA
    You need a more capable scantool to check the 15-16 systems on a Gen2 Prius. Here is a thread that reviews several options. The synopsis is post 37 (Autel AP200 is a good choice for general diagnostics).
    https://priuschat.com/index.php?posts/3246758
    gdanner and Brian1954 like this.
  12. ChapmanF
    18,436
    Well, gen 2's MFD does have a "vehicle signal check" screen that will show you the 12-volt system voltage. It doesn't show traction battery voltage. (Its normal screens include the simplified traction battery bargraph, of course.)
    I've always found the MFD voltage display to be a good fraction of a volt lower than what I see on a meter at the battery, so if I saw something like 12 there it really wouldn't concern me at all.
  13. Mendel Leisk
    41,809
    Dash reported voltage of the 12 volt battery is not exactly a battery assessment. One of the electronic testers that assesses CCA and gives a verdict is the usual go-to. They have names like "Digital Battery Tester" and "Automotive Battery Analyzer". I've got an older model "Solar BA5", works.
  14. bisco
    52,263
    could be the inverter pump i spose, or maybe a battery module or two
  15. David Mc
    Indiana
    Got a veepeak scanner today and here are the DTC's
    P0446
    P3000
    P3020
    And of course p0a80
    1st on I know is emissons
    I think next 2 are modules.
    Am I basically looking at 2 bad modules?
    Im trying to get the car to run long enough to find something else.
  16. Brian1954
    2,363
    950
    It is time for hybrid battery service. What year is your Prius, and how many miles on it?
  17. David Mc
    Indiana
    285+
    Brake system is failing too.
    Pretty sure its time to replace just need it to last long enough to find something else.
    It has been the best car I've had bought in 16 for 3,000.
    Had to replace the HV in 19
  18. pasadena_commut
    pasadena_commut Senior Member
    2,765
    828
    Southern California
    When the HV pack is out, or more specifically, when the converter decides not to run, all sorts of spurious codes can come up.
    A HV pack should last more than 6 years, unless it is a refurb and not a new OEM pack. There are some HV failure modes that have nothing to do with the modules but might look that way. For instance, bad wires or corrosion at the computer that lives in the electronics side of the pack.
  19. David Mc
    Indiana
    Greenbean that had a 5 year warranty of course.
