Rattling 2k miles after HG replacement.. but only after sitting 5 mins.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 462disco, Aug 15, 2025.
  1. 462disco
    462disco Junior Member
    32
    Socal
    2013 Prius. Replaced the HG about 2-3k miles ago @ 142k miles. Everything was kosher, until recently.
    When the car sits overnight or more than an hour, no startup rattle.
    When I drive the car, turn it off for about 5 mins & turn it back on, engine rattles. Initially thought maybe something in the fuel pump was bad, so I just replaced the entire assembly with an OEM unit - still rattles.
    Intake manifold cleaned, EGR circuit cleaned, injectors were sent to be rebuilt / balanced, new plugs (original coils), new gaskets, headstuds, head machined, block was checked for flatness (0.05mm feeler gauge). Engine runs great otherwise. I do about 1500-2000 miles a month at about 90% highway and it runs great. No coolant loss detected.
    Two things I still need to do - replace evap solenoid (sticky?) & refresh ECU to the latest firmware per T-SB-0041-15.
    I also read one situation on reddit where someone's catch can tubing was too large, so it would sporadically rattle for a few seconds until vacuum was built. Currently sourcing an OEM PCV tube to rule out the possible catch can issue.
    Any other suggestions? Sticky EGR valve?
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,692
    1,736
    Bay Area
    If you rev the engine, does the rattle go away? still no check engine light? can you post a video of it on youtube so I can hear it.
  3. 462disco
    32
    Socal
    - YouTube
    If I start it and immediately drive before the engine starts, I don't really get a rattle. I can't tell if it goes away when I rev it, since the rattle is short and stops within a second. Also, if you're facing the engine, it sounds like the rattle is coming from the right side of the motor where it interfaces with the trans. No CEL.
    May be related - when I first changed the HG, I would get a weird half second low idle as shown in this video - which led me to believe the fuel pump assembly needed to be replaced.
    - YouTube
  4. Mendel Leisk
    40,918
    Did you do all the work yourself?
  5. NutzAboutBolts
    1,692
    1,736
    Bay Area
    Is everything tighten down properly? From the intake manifold to the engine air box? Set it on maintenance mode and let it idle. If there’s no rattle during idle, I doubt it’s the egr issue. Can’t tell much from the video since it has a slight jump in the front and stops after the engine starts running as if there’s something loose in the front…
    try using seafoam and see if it clears up
    #5 NutzAboutBolts, Aug 15, 2025
  6. 462disco
    32
    Socal
    Yes.
    Everything was actually torqued to FSM specs, i'll check again. If something was loose, I would imagine it would rattle regardless? (cold/warm). I have let it idle for 10-15 mins with maintenance mode, no shaking unless I stop it and let it sit for the 5 mins & restart. Seems like too short of an interval for coolant to seep into the chamber.
    If it was a HG leak, I would imagine it would rattle in the morning on cold start?
    Techron has been run thru the tank, but I've replaced most everything in the fueling system.. new OEM pump, injectors cleaned/balanced, head hot tanked, carbon cleaned off pistons. This one definitely has me scratching my head.
    Intermittent coilpack, maybe sticky evap valve? It seems like whatever the issue is is when it's "warm", since the problem disappears after more than an hour.. In any case, I bought a coolant exhaust leak tester to test.
    [​IMG] .
  7. NutzAboutBolts
    1,692
    1,736
    Bay Area
    Yeah this is pretty tough without a check engine light, and everything you’ve replaced seems to be running properly. Did it ever rattle like this before the head gasket replacement? Have you borescope the cylinders yet?
    What gaskets and o-rings you’ve replaced besides the head gasket?
    #7 NutzAboutBolts, Aug 15, 2025
  8. 462disco
    32
    Socal
    I bought the car with a leaky headgasket, but repaired it as soon as I got it. Seller said it never overheated, just would rattle in the morning. Toyota borescoped and confirmed coolant in cyl #2.
    I haven't borescoped the cylinder but that'll be next, probably along with a leakdown test.
    Confirmed there was no warping in the block with the straight edge & feeler gauge.
    Here's a video with the car starting up after I let it sit for an hour. Small shaking seems normal per other video's I've seen?
    - YouTube
    All gaskets were changed - EGR circuit gaskets, valve cover, spark plug seals, injector O rings, valve stem gaskets, water pump & gasket, exhaust gasket, throttle body, intake manifold, crankshaft seal, etc. I used the Fel-Pro HS 26515 PT-1 gasket set, and additional OEM gaskets that were better quality over the Fel Pro.
  9. Mendel Leisk
    40,918
    What was the miles on it?
    Out of my depth, but the injector post-cleaning flow number being 260 on the dot, for all of them, is a little odd? Maybe the case due to totally clean injectors? Immaterial anyway I'd think.
    #9 Mendel Leisk, Aug 15, 2025
  10. 462disco
    32
    Socal
  11. NutzAboutBolts
    1,692
    1,736
    Bay Area
    did you replace the fuel injector vibration dampeners as well?
    that YouTube video seems normal, didn’t have the rattle that you have…
  12. 462disco
    32
    Socal
    I have not, gonna look those up.
    The video I posted is my car,
    (same car that was rattling in the previous video), only difference is I let it sit for an hour and started it.
  13. NutzAboutBolts
    1,692
    1,736
    Bay Area
    ok, yeah the second YouTube video start up wasn’t so rough as the first one… you be willing to tear down the engine again if you can’t resolve this issue? I think I would and figure what went wrong and back track it.
  14. ASRDogman
    ASRDogman Senior Member
    7,390
    3,854
    Did you confirm that the head is not warped? The block doesn't really warp.
    If it ever did, you'd need a new motor....
    NutzAboutBolts likes this.
  15. 462disco
    32
    Socal
    ugh. I don’t have the time anymore.. if I can’t figure it out, I may just drive this thing into the ground and get a fresh rebuilt engine from HybridPit. Also- if the fuel injection rubber dampers are what the injectors slide into in the head, then yes, I did change those.
    I didn’t flat edge the head, but I assume the machine shop that I took it to would check. I had the head resurfaced/decked when they serviced it. IMG_0726.jpeg
  16. NutzAboutBolts
    1,692
    1,736
    Bay Area
    Everything looks good, just drive it till it gives you a check engine light. I’m sure if it’s bad enough, it’ll pop something for you to check on.
    462disco likes this.
  17. 462disco
    32
    Socal
    Tested my HG with a coolant kit, did not trigger.
    Verified test kit by putting it in the exhaust, changed colors.
    The search continues..
  18. Mendel Leisk
    40,918
    That tests for exhaust in the coolant if I'm not mistaken, which is not the usual 3rd gen Prius head gasket failure mode, at least not in the early stages.
  19. 462disco
    32
    Socal
    Did some more testing.. Pulled the coilpacks, plugs and intake manifold. Have some interesting results I need help deciphering.
    I ohm'ed the injectors both cold and warm. All were 12.4 cold, and hot 12.9, 13.1, 13.1, 13.2. So I don't think the injectors are the issue.
    I ohm'ed the coilpacks cold and warm as well, per this YouTube video . Tested resistance between pin 1 and plug connector, then pin 1 and pin 4. Results were pretty consistent for all 4, so I ruled that out.
    So, pulling the coilpacks, there was no oil in the tube seal for any of the cylinders, so spark plug tube seals are all good.
    However, all of my plugs have oil on the threads and up to the sealing washer.
    So, the oil is coming from the cylinder head / combustion chamber. I looked at all the intake valves, and they look fairly clean, but there is a bit of oil getting thru the intake manifold even with my catch can. There was a little oil sheen on the intake valves, but I didn't see any oil dripping down the intake valves or pooling, so I assume my valve stem seals are good? (pics attached).
    IMG_0848.jpeg IMG_0847.jpeg IMG_0849.jpeg IMG_0850.jpeg IMG_0851.jpeg IMG_0852.jpeg IMG_0853.jpeg
    So, here's where I'm at.
    Possible sticky piston rings allowing oil to wick up to the plugs? Going to try a piston soak.
    Faulty IG2 injector relay? Is this replaceable?
    I'm temporarily removing the catch can to eliminate that as a variable.
    New evap valve and ecu are going to be updated in a few weeks.
    Leakdown test as well.
    Any suggestions?? Where's the oil on the plugs coming from?
    #19 462disco, Aug 22, 2025
  20. NutzAboutBolts
    1,692
    1,736
    Bay Area
    What service did you get for your cylinder head?
