Prius Gen 2 stumbling, cold start rattle, running lean? Blistered spark plugs, pinging when hot
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rennie, Aug 12, 2025.
  1. Rennie
    Rennie Junior Member
    Australia
    I have an issue that seems to be getting worse and has gotten annoyingly worse after new plugs and throttle body clean.
    Has always seemed to ping a little under load when at operating temp and slight/moderate acceleration. Didn't think much due to many other cars doing the same.
    Then started to rattle on cold start, stumble/shake.
    Recently changed plugs and cleaned throttle body a little (in situ). Old plugs all blistered. Cleaned pcv valve. Seemed to move ok?
    Engine start shake seems a little harder, and it's revving high when coasting down or low speed idle, slowly coming down at complete stop.
    I did a battery D/C.
    No codes from my OBD2 Bluetooth. It's old but has shown a misfire before when there was a tiny bit of moisture in one cylinder.
    Any thoughts or other things to check? I guess I could clean the maf though it didn't seem very dirty looking at the temp "football" thing in there
    52,286
    oem plugs from a dealer?
  3. Rennie
    Australia
    NGK Iridium Spark Plug - IFR5T11 from local auto parts shop
  4. bisco
    52,286
    there are a lot of cheap chinese counterfeits flooding the market. only dealers have secure supply chain from toyota
  5. Rennie
    Australia
    The symptoms appeared on the old plugs after running fine.
    From my reading, people change all sorts of things, and it doesn't necessarily fix the problem.
    Has anyone had all the problems listed above, simply from branded "fake" plugs?
  6. bisco
    52,286
    any trouble lights?
  7. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    Can you take some pictures of the old spark plugs and upload them here?
    Does your scanner show you the short and long-term fuel trims?
  8. Rennie
    Australia
    I have the Torque app, not sure where fuel trim would be shown?
    No dashboard lights
  9. Rennie
    Australia
    I cleaned the maf sensor, found it had oily black on all the bits I couldn't see from the pre-throttle body tube.
    Seems to be running better now. No pinging, no stumbling, much softer engine engagements. We'll see if it re-learns the pinging behaviour or not.
    I also put premium fuel in before, to maybe make it slightly easier while this problem was occurring.
    I guess oil build up is normal over time, though I recall once slightly over filling.
    I'd also used a different oil brand with a 5w-30 "long life engine".
    Not sure if that would have any effect. Usually the car has 5w-40 . Any chance of more oil vapour with the thinner hot weight?
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,080
    1,995
    NJ-USA
    In whatever ECM data that the app can display. There are two values - short term fuel trim (STFT - it's a direct response to the Air-Fuel sensor. This value changes constantly as the engine runs), and long term fuel trim (LTFT - it's a learned value that can be different for various RPM & engine load conditions. It tries to keep STFT near 0).
    Ideally both values stay near 0%. They can go "up" to around +20 to 25% (adding fuel by increasing the fuel injector on-time) or "down" to -20 to 25% (removing fuel) . More than 10% correction points to a problem. The ECM sets codes when fuel trims reach 20% or so.
  11. Rennie
    Australia
    I finally found out how to add pid to the real time screens. Only added a couple of st/LT fuel.
    I didn't get the full cold start but this is after a little bit of driving .
    Pinging is still fixed, but chattery/rough cold start remains.
  12. Rennie
    Australia
    And the pinging is back after filling with fresh regular unleaded
    Edit : how long for account restrictions?
  13. T1 Terry
    T1 Terry Active Member
    929
    491
    I'd check fuel flow and pressure while delivering the flow, then restricted fuel return to see how far the pressure rises ..... this all has the basic symptoms of excessive learn burn ......
    T1 Terry
  14. Rennie
    Australia
    Tightened the TB clamp a little, degreased small PCV hose that comes off the valve. Washed air filter. Seems to start better now. Doesn't shake into life, just starts up smooth.
    Still pinging.
    Not sure how I'd check fuel pressures.
    Should a clean the other crank case hose? The one going into below TB
  15. dolj
    dolj Senior Member
    8,528
    4,327
    Wellington, New Zealand
    When you say regular, do you mean 91 Octane? If so, use 95. On 91, you will get pinging under load. Using 95, it solves the pinging, and you should get at least another 100 km per tank. I get near 200 km extra on 95.
    What do you mean by this? What restrictions are you experiencing?
  16. Rennie
    Australia
    91 octane is regular unleaded, there's also 95 and 98. I guess I'll see if it's much different on 95 next time I fill up.
    Posts have to "wait for moderator approval"
    And : "Your account currently has Private Messaging capabilities restricted due to account inactivity. Please contact the site admin if you would like these capabilities turned back on."
  17. T1 Terry
    929
    491
    What state in Australia do you live, maybe someone in the area can help you go through the various checks etc ......
    The knock sensor should not allow the ignition to advance enough to cause detonation (pinging) but a very lean run will cause all the symptoms you have described, our ex taxi Prius suffered similar after a long rather "spirited" run with the stereo up so loud we couldn't hear any engine noises.
    Turned out to be a blocked catalytic converter and blocked fuel filter that probably caused the lean burn that cleaned all the carbon out of the engine and exhaust, resulting in the blocked catalytic converter.
    Being an Australian model, the fuel filter lives under the vehicle, roughly where the passenger seat (left hand side because we drive on the correct right side of the road) and available from the likely auto parts shops ....
    T1 Terry
  18. dolj
    dolj Senior Member
    8,528
    4,327
    With 30+ posts under your belt, you shouldn't have any restrictions. I would contact the site admin (by clicking on the report button under this post) and request a review of your account settings.
    [EDIT]
    For the USA audience:
    91 RON = 87 AKI aka R+M/2
    95 RON = 90 AKI
    #18 dolj, Sep 28, 2025
  19. dolj
    dolj Senior Member
    8,528
    4,327
    The knock sensor does peg back the engine on 91 (RON), but it still will ping under load. Toyota says this is normal behaviour in the owner's manual as long as it only occurs under load and is not sustained for a long period.
    This reduced performance is evidenced in less responsiveness (in terms of acceleration) and general sluggishness or less "pep", if you like, in general driving.
  20. T1 Terry
    929
    491
    Over here we have E10, low octane fuel with a min 10% ethanol added, both the Prius and the Ford 6.8ltr V10 in our motorhome, love it .... and it is the cheapest by law ..... It sure keeps the fuel system clean and water free, generally around 93 to 94 octane, where the regular unleaded is as low as 89 octane, you really notice the loss of performance and fuel economy when using that stuff, but it never equates to better kms/$$ to buy 95 octane in either vehicle ..... the V10 already eats 40 ltrs/100kms, 95 octane would have to improve the full tank range by more than 100kms to justify the price ..... the improvement would not be anywhere close to that ......
    T1 Terry
