Flickering Multivision Screen - 12V Battery Issue?
Discussion in 'Generation 1 Prius Discussion' started by Kadalora, Aug 16, 2025.
  1. Kadalora
    Kadalora Junior Member
    New Zealand
    2002 Prius
    So I knew my 12V was dying, and when it does this my lil multivision screen flickers (the one that displays if you're using petrol or HV battery etc), until you run the car for about 5min then presumably the 12V recharges enough for the screen to hold steady. I recently got a brand new 12V battery, however, to my horror the multivision is still flickering for the first 5min or so then holds steady, just like before.
    Has anyone had this before? I wonder if I need to take it back and try a different 12V battery? Unfortunately there's a bracket in the boot that limits the size of battery I can put in there. I bought this one: ENDURANT CAR BATTERY NS40ZLPP - Battery Warehouse which is 330 CCA. I know it's technically supposed to have this AGM battery: https://www.centurybatteries.co.nz/products/s46b24r however it's over twice the price and 5 less CCA, not sure if that would have any effect over interior electrics like the multivision?
    Any help appreciated
    Cheers
  2. ChapmanF
    18,587
    As soon as the word READY appears on the dash, the electronics aren't relying on the 12-volt battery anymore. Probably the light source behind the MFD screen is just flickering until it warms up.
    mroberds and Kadalora like this.
  3. Tombukt2
    13,483
    2,425
    Old screen tech that's all
    Kadalora likes this.
  4. Kadalora
    New Zealand
    2002 Prius
    Ouu ok interesting, I was not aware of that! I wonder why it never used to flicker? I guess upgrading the 12V battery will make no difference then. Would it be worth perhaps trying to get in behind the centre console and checking the connections to it? Not sure how difficult that may or may not be..
    Many thanks
  5. ChapmanF
    18,587
    I bet the light source behind that old LCD is a cold-cathode fluorescent tube, and it's 23 years old.
  6. Kadalora
    New Zealand
    2002 Prius
    Ahhh right on, interesting! I wonder if it's possible to replace that tube or connect a newer version screen (that presumably doesn't have the same component/issue)?
  7. dabard051
    dabard051 Tinkerer-in-Charge
    260
    97
    Rochester, NY USA
    2002 Prius
    Yes, it's possible, but it will require removing the 23-year-old sun-baked plastic fascia tee-shaped panel, which likely will fall apart in the disassembly process. That's before you try to figure out how to replace the backlight for the LCD display.
    There's 2 types of flickering - one due to the slowly failing cold-cathode lamp, and one that looks like static or snow on the LCD screen, which I believe is a decaying solder connection between the LCD display and driver electronics.
    Which is your pleasure?
    mroberds likes this.
  8. ArCanSawDave
    ArCanSawDave Junior Member
    2003 Prius
    SE
    My 2003 does this also. Mine looks to be associated with the screen itself, but it gets worse if the screen is brighter (day vs. night mode). If it's really cold the screen is just solid gray, but once it warms up if I turn the car off and then back on the screen comes up fine.
  9. Trombone
    Trombone Active Member
    360
    124
    Allentown, Pennsylvania
    2002 Prius
    In cold weather, say 40ºs and lower, the screen in my '02 is very dim until the car warms up. It's been this way for a long time, and I've come to accept it as "normal" behavior. Whether that's true or not, I have no plans to do anything about it.
