Inside smells really bad
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by cool_prius, Mar 26, 2025.
  1. PriusCamper
    PriusCamper Senior Member
    12,393
    5,023
    Pacific Northwest, USA
    Yeah... Out in the PNW we basically have 65%-99% humidity for 9 or 10 out of every 12 months so owning a powerful dehumidifier is essential if you're like me and have way too many houseplants.
  2. cool_prius
    cool_prius Member
    102
    34
    United States
    2025 Prius
    Well I reached out to 30 more lawyers and got 6 responses this past week all saying the same thing about Toyota needing to confirm the issue and replace parts.
    daisy555 likes this.
  3. PriusCamper
    12,393
    5,023
    Asking one of those lawyers to write a letter saying that to the Toyota Stealership will likely get you better results because they'll realize it could get way more expensive than the value of the car if they don't do what your lawyer asked them to do!
  4. PriusTech
    PriusTech Member
    190
    94
    Reno
    You can get a small dehumidifier for around $100, it doesn't have to be big because they're made for houses and a car is a lot smaller area
  5. cool_prius
    cool_prius Member
    102
    34
    United States
    2025 Prius
    I've began noticing that when I have recirc + auto + AC all off and crank up the fan, the car gets incredibly humid and uncomfortable very fast. It's like the air is passing by a steaming bucket of water inside the dash before it comes out the vents.
    I noticed it a lot earlier but I just assumed it was the outside humidity getting in. It hasn't been that humid recently though at high 50s (%).
    Anyone else experience this?
  6. Mendel Leisk
    41,028
    Anyone turning off the AC will notice this. It's AC withdrawal symptoms: all the while cabin air is passing through the chilled AC "radiator" inside the dash it's humidity is condensing on the radiator's fins. Turn off the AC (but continue using the fan, the radiator comes back to ambient temp, and that accumulated water evaporates again.
    Ten minutes or so later, you'll be back to normal, just keep the windows cracked in the interim.
    Trollbait likes this.
  7. Paul Gregory
    Paul Gregory Senior Member
    2,003
    519
    Alberta
    2024 Prius Prime
    XSE
    I'd buy those deodorant pucks, pull the lid off and put them under the seat.
  8. cool_prius
    cool_prius Member
    102
    34
    United States
    2025 Prius
    It's not just a smell though.
  9. Paul Gregory
    2,003
    519
    Alberta
    2024 Prius Prime
    XSE
    If it's fungi you want to kill, try bleach.
  10. Chewpunzel
    Chewpunzel New Member
    Oregon
    2019 Prius
    XLE AWD-e
    It could be mice. Check the cabin air filter.
  11. daisy555
    daisy555 Senior Member
    1,712
    705
    CT
    If I have to buy a dehumidifier for my car, then something is wrong with the car. I was talking about my apartment HVAC. : }
  12. daisy555
    1,712
    705
    CT
    I haven’t noticed this. I’m turning my heat on when I’m almost home despite it being 80-90 degrees out with hopes that it dries things out a bit.
  13. Trollbait
    12,450
    Are you sure the recirc is truly out of the auto system's control and off? My Subaru will turn on recirc when in auto and the AC manually off. Why is this even an option to the HVAC computer? With the system possibly using AC with the AC light off, perhaps the same is true withe recirc.
    Locally, we've just had a more humid summer this year. I've been using the AC more; even when the temperature is okay for me.
  14. daisy555
    1,712
    705
    CT
    I’m not sure or confident about anything with this Gen 5 HVAC system or the media screen. I went into the climate section on the screen and it basically states Auto in white or blue. No on or off wording so I’m assuming the blue means it’s on. I need to pull the manual out again. I just find it odd that I press one of those switches to manually turn a feature on but then I can’t turn the feature off by pressing it again.
    Multiple times I’ve tried to shut the radio off by pressing the knob and sometimes it works and other times it doesn’t. I’ve stopped to check something on an app on my phone and the radio switches to the app’s audio. Then when I close the app I can’t get the radio to play again unless I shut everything down. I’ve had the screen info disappear and the screen message state something like no access to HD. I’m guessing that’s a satellite issue maybe. Car play options only come on when I’m making a call which is fine with me. I need to start documenting these glitchy things. Usually in the moment I don’t have the time or patience.
  15. Trollbait
    12,450
    I think HD refers to the system hard drive.
    Pushing the knob usually just mutes things in these sytems.
