One safety feature keeps trying to kill me
Discussion in 'Gen 5 Prius Technical Discussion' started by cool_prius, Aug 18, 2025.
  1. cool_prius
    cool_prius Member
    101
    34
    United States
    2025 Prius
    Sometimes I'll get too close to a lane line and the steering wheel jerks to the side the line is on, as if it thinks the line isn't a boundary I'm about to hit, but one I've already crossed? It's confusing what it's actually doing, but on the display I see a green lane line. What feature is responsible so I can turn it off?
  2. Trollbait
    12,430
    Is this with the active lane centering with cruise control, or the passive lane tracing that is on most of the time?
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,198
    782
    Monument, Colorado USA
    Yep, LTA, Lane Tracing Assist. Whenever you drive over 30 mph it will start working, IF you have it turned on. (You can change the settings in the menu, even turn it off.)
    My main issue is it seems to want to steer the car more to the left side than I'm comfortable with, especially when there's incoming traffic....else it's fine.
    Get that owner's manual out and read all about it!
  4. Hammersmith
    Hammersmith Senior Member
    2,166
    2,166
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Terms:
    LDA - Lane Departure Alert - only activates when close to or crossing a line - fairly sharp correction
    LKA - Lane Keeping Assist - only activated with Dynamic Cruise Control is active - gently keeps the car in the middle of the lane
    I agree that LKA drives a little more to the left than I'd like. When I'm on a two-lane with oncoming traffic, I'll just keep my hand on the wheel and gently nudge it to the right when a car is passing. Takes very little effort to override it that much. BTW, it will adjust over on its own if you are overtaking a car or it's overtaking you(you're both going the same direction). It just can't detect an oncoming car quick enough to safely move you over on a two-lane.
    LDA is a little more aggressive, but it's not nearly as bad as a couple posters on here have claimed. Hands firmly on the wheel, and you can easily keep control even when it's fighting you. Honestly, it says more about them as drivers then it does about the car.
    If a car surprises you with its behavior(especially after owning it for over a month), then that's on you for not properly learning about your vehicle. I know that if I cross a line without signaling first, the car is going to fight me. So in an emergency situation when I have to make a quick lane change or hug the line, I know I need to firmly grab the wheel and force the car to do what I want. Just like if I was driving in rough conditions like bad gravel or snow. It's on me to understand how the car drives in all conditions. It's no different than knowing that your vehicle tends to pull left or right under hard braking(more common in the days before modern anti-lock brakes) or any other quirk that makes one vehicle different from the next. Got no sympathy from me on this topic.
    otatrant and Trollbait like this.
  5. Prodigyplace
    12,462
    11,703
    Central Virginia
    With LTA active, you can depress the turn signal slightly and LTA will perform the lane change for you.
  6. BiomedO1
    3,119
    1,656
    SacTown, Ca
    I believe the top right outer steering wheel button toggles that function ON-OFF.
    https://www.usnews.com/object/image/0000018c-5f14-dc6c-aded-ffbcaa430000/https-cars-dms-usnews-com-static-uploads-images-auto-custom-15210-original-2023-toyota-prius-prime-steering-wheel-controls-2.jpg?update-time=1693340330000&size=responsiveGallery
    Prodigyplace likes this.
  7. Hammersmith
    2,166
    2,166
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Only on Prius Prime/PHV. Doesn't work on regular Prius HEVs. They don't have the front side radar sensors that the Lane Change Assist system needs.
    And don't even try adding them yourself right now. Ask me how I know. :cry::cry::mad:
    (2.5 months and two dealerships later and I'm still stuck)
    otatrant and Prodigyplace like this.
  8. Hammersmith
    2,166
    2,166
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    No. That button is for Lane Tracing Assist. What the OP is describing is Lane Keeping Alert. That can only be disabled in the settings menu. And it might turn itself back on every time you start the car. Not sure.
    otatrant likes this.
  9. Hammersmith
    2,166
    2,166
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Grrr - Double post
  10. Prodigyplace
    12,462
    11,703
    Central Virginia
    OK, fair enough. I have a 2025 Camry XLE with the Premium Plus package that adds extra sensors.
  11. BiomedO1
    3,119
    1,656
    SacTown, Ca
    If we're talking about LKA; it looks like the inner button may toggle that function. I'm making inferences based on the iconography; so double check with your OM.o_O:rolleyes::whistle:
    Weather that toggle is a "sticky" is a good point. My gen4 LTA is a sticky - set once and forget it. I somehow accidentally turned it back ON - had to take an off ramp, and stop to figure it out. I hate it when someone messes with my settings. That was a very very bad thumb (fat finger move).:eek::p:cool:
    #11 BiomedO1, Aug 18, 2025
  12. Hammersmith
    2,166
    2,166
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    No, I'm very certain the button is for LTA, not LKA. Personal experience plus the manual.
    Remember: Tracing(LTA) gently keeps you in the center of the lane while in DRCC. Keeping(LKA) not-so-gently keeps you from going into the shoulder or another lane when you're not paying attention.
  13. BiomedO1
    3,119
    1,656
    SacTown, Ca
    Top left seems to be LKA, signified by the CC icon. Top right seems to be LTA, but you've got the manual.....
  14. Hammersmith
    2,166
    2,166
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Okay, I guess I just assumed you were talking about the top right.
    Top left is cruise control ON/OFF and CC set. Still not LKA.
    LTA is linked to CC(which is why the button is part of the CC group). LKA has nothing to do with CC. It's a basic safety feature which is why it's deep in the settings.
    edit: Jesus. Now I'm getting LKA and LTA mixed up while typing them out. Fixed now.
    #14 Hammersmith, Aug 19, 2025
    BiomedO1 likes this.
  15. Mendel Leisk
    40,964
    No more cruise control stalk eh? I do like that on our '10 (with dumb cruise), very easy to find/control.
  16. ColoradoBoo
    1,198
    782
    Yep, it's gone in my wife's 2024 Corolla, too....takes getting used to the buttons on the steering wheel. (And her car has 4 settings to how close the car follows the car in front while on cruise.)
    Her Corolla, also, will slow itself down when it sees the car in front slowing down...whether you have it on cruise or not....I kinda like that! (Must be the Toyota Safety Sense 3.0)
  17. Trollbait
    12,430
    The stalk on the Toyotas was a better design than the ones on the Fords, but I find the buttons on the steering wheel even better in that less of your hand has to come off the wheel to use them.
  18. Prodigyplace
    12,462
    11,703
    Central Virginia
    That is part of their PDA (PRedictive Driving Assist) and can be somewhat customized on my 2025 Camry in the Settings menu.
  19. cool_prius
    cool_prius Member
    101
    34
    United States
    2025 Prius
    Whatever feature I'm talking about isn't something that's tied to cruise control, or any of the steering wheel buttons I think. Like I press the top right one and an icon with a car between two lines shows up. That's always off.
    #19 cool_prius, Aug 22, 2025
  20. cool_prius
    cool_prius Member
    101
    34
    United States
    2025 Prius
    Not able to find anything about it in the settings menu.
