Prius Gen 2 – SOC drops overnight, normal behavior?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kamilpcc, Aug 18, 2025.
  1. Kamilpcc
    Kamilpcc New Member
    Polska
    Hi everyone,
    I have a 2007 Prius Gen 2 and I'd like to clarify something.
    When I park the car, the MFD usually shows almost all blue bars (sometimes almost green). But when I return a few hours later—or the next morning—the display only shows two purple bars, sometimes almost empty.
    Then, as soon as I drive off, the car rapidly charges the HV battery to the blue bars. This cycle repeats, and because of this, I feel like the gasoline engine is working more often to recharge the battery, which slightly increases my fuel consumption (currently about 5.3 L/100 km).
    So, my questions are:
    Is it completely normal for the display's SOC to drop overnight?
    Is this simply ECU recalibration, and not true self-discharge?
    Could this behavior be related to the age of the HV battery, or simply to the way the Prius manages its buffer (SOC range 40-80%)?
    I'd appreciate it if someone could confirm whether this is normal behavior for the Prius, or if it could be a sign of a weakening HV pack.
    Thanks!
    #1 Kamilpcc, Aug 18, 2025
    52,009
  3. Tombukt2
    13,055
    2,339
    Very normal behavior mine drops from a full load of green Parked to half blue 50 feet down driveway . But comes right back up immediately on the road even with ac on.
  4. pasadena_commut
    pasadena_commut Senior Member
    2,672
    793
    Southern California
    Dropping to purple overnight is not normal behavior. If it had some sort of high voltage short there should be a check engine light on, and none was mentioned. The pack is probably weak. If the OP pays for a copy of the Dr. Prius app there is a test that can be run which will give an estimate of the state of the pack.
  5. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    ^^^ Agreed. This is not normal behaviour. It can be a sign of a weak hybrid vehicle (HV) battery, so verifing that would be a good idea.
  6. Carall
    Carall Active Member
    314
    104
    Harrisonburg, VA
    This is a sign of weakening of the HV package, loss of capacity. 3 discharge charge cycles will eliminate this, but how long it will last depends on the condition of the battery.
  7. Kamilpcc
    Kamilpcc New Member
    Polska
    Okay, I'll buy a Dr. Prius and test the battery. I also noticed that the purple level stays on for a long time while driving, then quickly jumps to blue. Maybe it's because of the short driving distances. Regardless, I'll test it with the Dr. Prius to be sure.
