Low Profile Roof Box
Discussion in 'Prime Accessories and Modifications' started by Marinna, Aug 19, 2025.
  1. Marinna
    Marinna Junior Member
    24
    San Jose, California
    Anybody has a good suggestion to a roof box that doesn’t compromise the driving dynamics too much?
    I am looking for something to use for a roadtrip. Don’t need a lot of volume and don’t want to compromise my driving dynamics as well as parking situation. My garage at home and work both have a pretty low limit of 7 feet so I want to keep it at that height.
    my plan is to just keep some packed clothing and accessories like sunshade or camping stuff in it so weight shouldn’t be too much of a problem.
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Does that mean you already have a roof rack/crossbars?
  3. Marinna
    24
    I don’t yet. I assume that will be dependent to the roof box I want to use. Especially the crossbar is usually not very low profile friendly.
  4. xliderider
    8,140
    3,277
    Honolulu, HI
    There are rooftop cargo bags available that don't require a roof rack, but you need to be careful not to put too much weight on your roof, or you could damage it. Also, the straps that go into the passenger compartment compress the weather seals so that any heavy rain encountered can leak into the car.
    https://a.co/d/i6dUzzS
  5. Marinna
    24
    Personally I am really not a big fan of roof bag. These are just temporary solution. The fabric never hold well.
  6. xliderider
    8,140
    3,277
    Honolulu, HI
    I definitely agree, but I wasn't sure if you were looking for a less expensive alternative.
  7. Abarnabe
    Abarnabe Active Member
    169
    100
    Netherlands
    #7 Abarnabe, Aug 20, 2025
  8. Abarnabe
    169
    100
    Netherlands
    I find standard roof boxes too bulky to store it in the garage afterthe holidays, so I use a windsurf sail bag, which can be folded and stored in a cupboard in winter, aerodinamically wise it's long and narrow, if you hit something like a garage roof it' s soft, so no damage if you don't hot it too hard. The bag is not completely waterproof though.
    I also use original toyota roof racks
  9. BiomedO1
    3,962
    2,089
    SacTown, Ca
    IMHO; anything you throw up there will impact your aerodynamics and cost you some mpg.
    I'd like to suggest an alternative; one of those trailer hitch boxes. You'll need to be-careful driving around with it, because it shifts weight back - but it should be fine if you don't overload it. The bonus is that it can easily be removed when not needed, since it sound like this is an occasional thing.
    Hope this helps....
    xliderider likes this.
  10. Abarnabe
    169
    100
    Netherlands
    I can confirm that in my experience the hitch mount is definetly the best aerodynamic option.
    I usually secure bags on a hitch bike rack with tension straps, but the bikehas to stay at home :)
    xliderider and BiomedO1 like this.
