Have you changed your tires? What is your experience?
Discussion in 'Gen 5 Prius Main Forum' started by Robmoo, Aug 19, 2025.
  1. Robmoo
    Robmoo Junior Member
    55
    2024 Prius
    Because these cars are so new I don't expect that many people have changed theirs tire yet, but I'm curious about the experience of those who have. I'm at 13,700 miles on my 2024 original tires. I've had 3 punctures. Thankfully none of them have resulted in a shredded tire or me/my family being stranded. Discount tire has 3 tires available in my area. Have you swapped tires? Which tire did you chose? How have they been so far? Have you had any flats? If you chose to change to the 16" rims how has that gone?
    I have the 2024 LE with the 195/60 R17 tires.
    We've had a good experience with the Maxlifes on our Gen4. So, that is likely what I'd get if I don't do the 16" rim.
    #1 Robmoo, Aug 19, 2025
    reservoirblue likes this.
  2. reservoirblue
    reservoirblue Member
    96
    76
    Woodacre, CA
    2024 Prius Prime
    SE
    Don't stay with the original size. Put "new tires" in the search function above, and you're good.
    BiomedO1 likes this.
  3. BiomedO1
    4,090
    2,140
    SacTown, Ca
    Yep; caught three flats on the thin OEM tires. I replaced them with thicker n higher load rating tires, 80K mile wear-out warranty. I did suffer a few mpg penalty. I actually pulled a nail out on my last rotation - it didn't penetrate the new rubber. Running them all @40psi, so I don't have to readjust on rotations.
    Hope this helps.....
    james nicol likes this.
  4. Robmoo
    55
    2024 Prius
    What did you switch to? 80k life sound like the Goodyears. I had Goodyear Maxlife's on our 2017 and was happy with them.
  5. soft_r
    soft_r Active Member
    184
    152
    Beverly Hills
    2024 Prius
    Crossclimate3's on 16" wheels. Center bore size of the wheel needs to be exactly or bigger than the center bore of the wheel hub on the car. I used aluminum OD 78.1mm to ID 60.1mm hubcentric rings for mine.
    No issues, no flats, traction is definitely better than factory tires (tested on some turns in wet conditions where factory wheel+tires at certain speeds would cause light traction loss on the rear (oversteer) but the CC3's did not in the same conditions. And since I don't make my personality about my mpg I don't really know what I was getting on my factory wheels but I still get fantastic mileage. As for road noise, negligible? I hear the wind around the car more than I hear road noise.
    Also I prioritized lighter weight wheels in my shopping. Something to consider if you're buying new wheels.
    Robmoo likes this.
  6. otatrant
    otatrant Active Member
    348
    211
    San Francisco
    2023 Prius Prime
    XSE Premium
    CROSS CLIMATE 2 205/55R17 on
    MSW TYPE 48 17x7.5
    3% smaller circumference than stock wheels and tires so speedometer reads a couple miles per hour faster at highways speeds and odometer is 3% higher. 1/2" decreased ground clearance.
    Improvement in road noise levels and ride comfort. Better traction in wet and icy conditions. Many more options for tire replacement with MSW wheels.
    Robmoo likes this.
  7. Hammersmith
    Hammersmith Senior Member
    2,315
    2,361
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    CC3 or CC2?
    If CC3, how did you get them already? I didn't think they were available in North America yet.
    PrimeDan likes this.
  8. BiomedO1
    4,090
    2,140
    SacTown, Ca
    Don't care much for Goodyear - they have weak sidewalls. Got a set on my GMC. Two of 4 had to be replaced due to road hazard. One was free and the other cost me $5. Armstrong, BF Goodrich, the General Altimax series are good tough tires that I get decent all season grip with longevity. Don't know if they have them in your size.
    daisy555 likes this.
  9. Mendel Leisk
    41,865
    Yeah, comparing to the stock 19" size. Oddly, the stock 17" size is markedly smaller OD, and your choice isn't that different:
    otatrant likes this.
  10. soft_r
    184
    152
    Beverly Hills
    2024 Prius
    Typo, sorry. CC2s. I'll edit my post. Nvm, turns out can't edit after a certain amount of time.
  11. Hammersmith
    2,315
    2,361
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    No worries. Just wanted to make sure I wasn't losing my mind. lol
    Apparently you can get CC3s if you import them from international ebay sellers, but I don't want to even imagine the upcharges.
