Dome power loss with VSC light on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Zembu, Jul 15, 2015.
  1. Zembu
    Zembu Junior Member
    Silver Spring, MD
    4 weeks ago just after starting my 2007 prius the VSC light came on and along with it, I didn't have power to my audio system, interior lights, clock, or keyless entry/start. A few days later after checking to make sure the dome fuse wasn't blown, the light went away and power was restored. A few days after that, I had to use the manual key to gain entry to the car and after inserting the fob into the slot and starting the VSC light was on with all the previously described power loss. This was the definition of an intermittent problem and it continued that way for about 2 weeks.
    During that time, I took it to an independent shop I trust and they pulled the code, C1231, that was associated with the VSC light. They told me I needed to take it to a dealer.
    While dragging my feet for another 2 weeks, the VSC light is now on all the time with the corresponding power loss. Aside from no power to these systems the car drives fine. I did check the 12V battery and it is fine.
    So this week I finally found a dealer who would look into it without charging me a diagnostic fee. I just got the car back today without anything being fixed and me not agreeing to their suggested fix due to cost. The following is the work text and their recommendation:
    "Code C1231 Steering angle sensor
    Unable to delete DTC & Steering angle does not change
    Checked Fuse 10A Dome: tested okay
    Checked for power at Junction connector J6: Power Present
    Junction 23 has no power
    When back to to instrument panel relay location & checked pin #13 at connector 1A: No power
    Open circuit between 1A & J6 Junction Connector
    Recommend replace instrument panel wire harness $5,100"
    Does anyone have any suggestions as to other things to try besides replacing the instrument panel wire harness? Or does anyone know of a non-dealer shop in the Washington, DC metro area that specializes in Prius troubleshooting?
    I'm certainly not going to drop that amount of money on a repair as that is basically the current value of the car but I do miss the convenience of the keyless entry and start, the clock, and playing music while driving.
    Thanks in advance for any suggestions and help.
  2. valde3
    valde3 Senior Member
    2,002
    747
    Finland
    It’s easy to verify their findings. Just test that there’s no continuity between junction connector J 6 and pin 13 of connector 1A. If there isn’t you do need to replace or repair the wiring harness. Maybe you could get used one? This isn’t a common failure so used one should be ok.
    I wouldn’t use the car like that because you don’t know what the problem is. It can cause (almost) anything at any time.
    gdanner likes this.
  3. Patrick Wong
    18,200
    6,495
    I'm really surprised that dealer did not charge you for the time spent by the tech, which easily could have been one hour, to discover the findings which were documented. It sounds like that tech knows what he is doing with regards to troubleshooting electrical issues.
    1. Was the car in a front-end accident or flooded at some point in its history?
    2. If the car was not in an accident, was it infested with rodents? Check the cabin air filter for example.
    3. Inspect the wiring harness for obvious damage. J6 is located on the passenger side of the car near the engine and HV ECUs behind the glove compartment, and of course the relay box is under the instrument panel, driver's side.
    4. Remove the affected wiring harness connectors and spray with electrical contact cleaner. Maybe that will help.
    5. Run a replacement wire from J6 to pin 13, connector 1A at the relay box. That might work if only one connection is having a problem.
    6. See if the independent shop is willing to install a used electrical wiring harness, which is labor intensive as the dashboard must be totally disassembled for access. That might cost $1K or more in labor effort, not to mention the cost of the used part.
    If you wish to DIY, subscribe to techinfo.toyota.com to obtain electrical wiring diagram information which is required to understand the problem and figure out where the relevant junction connectors and wiring harness connectors are located.
    #3 Patrick Wong, Jul 16, 2015
    gdanner likes this.
  4. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    If it were me and I had a few hours free time, I'd try to find the discontinuity and repair it. I've been looking at the wiring diagrams in my Bentley manual and there's enough information in there to back up the diagnosis. If it were my car, I'd probe a bit under the dash, at least try to see if there's mechanical damage to the connectors or cables, or some corrosion somewhere. If you're really good with wiring diagrams and a soldering iron, or really lucky and/or creative, you may get it. Good luck.
  5. Zembu
    Zembu Junior Member
    Silver Spring, MD
    About not being charged, I called and specifically asked what their diagnostic fee would be to investigate the reason for VSC light. I think I was dealing with a secretary who went and asked and I suspect she asked about a check engine light which a lot of shops do investigate for free. After she told me it would be free, I confirmed that it was for a VSC light and told her that was the only reason I was making the appointment and asked her to make sure it was noted. Of course when I dropped the car off, the service rep wanted me to acknowledge a $142 diagnostic fee. I told him the same thing I wrote above and he reluctantly let it go as a free diagnostic. He did tell me that after they spent an hour on it, he would have to call me back to have me authorize them spending more time by agreeing to a diagnostic charge. I know they spent more than an hour but he never called me for further authorization. Ultimately, I think he felt bad that the suggested repair was so much and just decided not to charge me.
    1. No accidents or floods with this car.
    2. Interesting that you suggest this. When I was checking the dome fuse, I removed what looked like the partial remains of a mouse from the upper right area under the hood closest to the windshield. I think your suggestion of a rodent problem may be the cause for my trouble. Since you suggested this, I assume you've seen it in other cases. How did the damage from a rodent show up? Is it in a wire or wires being chewed?
    Thank you for the suggested steps to try and resolve it. I'll see what I can do over the next couple of weeks and post again when I have something of consequence to share.
  6. Patrick Wong
    18,200
    6,495
    Yes. I think you have a reasonable chance to resolve this yourself if you remove the plastic dashboard cover so that you can fully examine the wiring harnesses in the dashboard area. This is not a trivial task though, you need to deal with the passenger-side airbag which requires special handling, disconnecting the 12V battery first, etc. Expect to see a wire or wires with damage from chewing. Once you have identified the damaged wires then you can splice or solder around the damaged wires. Soldering is best if you have that skill.
  7. Zembu
    Zembu Junior Member
    Silver Spring, MD
    Unfortunately I don't have the skills to fix this myself. I could probably get the dash off with the help of a youtube video and some effort but I wouldn't know how to fix damaged wires myself.
    I took my car to a DC area electric specialist and they quoted me $1,200 to take the dash off and fix any bad wires. Seems steep to me so I'll be exploring other options where family lives in PA at a shop that has a much lower hourly labor rate.
    It will likely be another month before I can get that done so I'll just continue to drive my otherwise functioning car for another month.
  8. gdanner
    gdanner Member
    102
    Central Illinois
    I’m bumping this old thread because my 2005 Prius suddenly developed an identical fault. I have no dome lights. Audio system is dead. Clock does not light up. Wireless key fob does not work.
    In my case the missing 12V power fault is persistent. Not intermittent at all. All fuses are good. There are no signs of overheated wires or damage by mice chewing on the wiring harness. All plug-in connectors are fully seated. None of my 12V wiring has any signs of corrosion.
    Many other functions still work: Key fob works when inserted into dashboard key slot. Car can be put into ACC or IGN mode and also turned off with dashboard power button. Combo meter display lights up and its warning LEDs operate. For example the “door open” and “parking brake” LED indicators work as they should. My door locks work but when outside the car I must put the physical key into the driver’s side door handle and turn it to lock or unlock. Power windows work. Rear hatch release works.
    Note: I haven’t tried to drive the car because I started the process of replacing my badly corroded HV battery bus bars and HV battery voltage sensing harness before this 12V fault occurred.
    I’m surprised by this sudden loss of 12V power to the above listed items. I don’t think I did anything which could cause this 12V fault.
    At this time I suspect I have an open 12V connection under the dash. In fact I pinpointed J6 myself as a possible culprit. This was confirmed when I read this thread which also mentions J6 along with a possible fault in the under-dash wiring harness.
    Because I also need to replace the 100uF capacitor on my combo meter PC board I decided to dismantle my dashboard. Interestingly my combo meter works perfectly at this time (August) but it failed frequently in Jan. and Feb. during spells of very cold weather.
    Jumper block J6 was very difficult for me to locate even after taking my dash apart. Also it is bolted down with a hard-to-reach bolt which requires a 10mm wrench to remove it. My next step will be to remove the bolt and inspect J6.
    I’m in awe of the vast amount of wiring behind the Prius dash. Why is it so complex? Why does it have these strange “jumper blocks” (such as J6)? What is their purpose?
    Also why are so many different circuits and devices all fed through the “DOME” fuse?
    (Note: “DOME” fuse is located in engine compartment fuse box.)
    I’m looking forward to identifying and repairing my 12V fault.
  9. ChapmanF
    17,588
    Does lots of stuff.
    I don't have a gen 2 wiring diagram in front of me at the moment, but J6 may be s "junction connector". A bunch of wires in the harness come out to various pins of a a connector, and then it plugs into a special connector with internal connections joining groups of the pins.
    Ends up being more convenient on the assembly line than a bunch of splices in the harness—uses the same tooling and methods as other connectors that have to be there anyway.
    Also, for troubleshooting, it ends up being a convenient(-ish) place you can break a circuit and check one side or the other.
    gdanner likes this.
  10. gdanner
    gdanner Member
    102
    Central Illinois
    I'm still searching for junction connector J6. Yesterday I thought I had found it...
    ...but what I actually found is a "ground junction connector" which I believe to be J5. It is also referred to as IK. All 11 pins of J5 are grounds. IK identifies J5 as a "ground point" which is bolted to the car body.
    I expended considerable effort to remove the bolt which fixes J5 to the sheet metal.
    Now I have to put all of this back together, followed by continuing my search for J6...
    What I learned:
    • Connectors such as J5, which have metal lugs bolted to the car body, are grounds. The wiring diagram identifies them both as a "junction connector" (J5) and as a "ground point" (IK).
    • "Junction connectors" such as J6 are taped to the wiring harness (or have plastic pegs to hold them in place). However junction connectors of this type do not have metal lugs bolted to the car body.
    #10 gdanner, Aug 16, 2025 at 11:19 AM
  11. gdanner
    gdanner Member
    102
    Central Illinois
    Today I improved my access to the wiring harness on the passenger side of the car by removing more trim panels. I also removed a small black plastic bracket attached by 2 screws. It's part of the lower glove box hinge support mechanism. Doing this made it much easier to reinstall grounding connector J5 (also known as IK - I believe "IK" refers to the bolt which attaches J5 to the car body).
    Then I located several other "junction connectors" under the passenger side dashboard: J10, J17, and J18. These 3 junction connectors are thoroughly wrapped to the wiring harness with plenty of layers of black electrical tape which totally covers them. This made it difficult to find them. I assume the black electrical tape was applied at the Toyota factory?
    I still haven't found J6. According to drawings in the Prius wiring diagram J6 is close to the connectors I already located: J5 (IK), J10, J17, and J18 Perhaps it is totally encapsulated in black electrical tape?
    And then I found a Prius Chat post containing photos of J6:
    Dome light fuse / J6 Connector / slow battery drain | PriusChat
    Unfortunately It's cropped in a way which makes the photo difficult to overlay against what I actually see under my dash. But perhaps this will help me locate the elusive J6.
    #11 gdanner, Aug 16, 2025 at 4:48 PM
  12. gdanner
    gdanner Member
    102
    Central Illinois
    Finally: J6 located.
    J6 is totally encased underneath many layers of black electrical tape. It is firmly attached to a very thick wiring harness segment (more than 1 inch in diameter) which terminates at a vertical column of several large white connectors located at the right side of the white plastic heater/AC blower assembly. I would never have found J6 except for carefully feeling the wiring harness for a hard plastic rectangular object deeply embedded underneath the black tape.
    But perhaps I won't need to unwrap J6:
    My first test will be to determine whether or not 12V appears at pins 1A-13 and 1A-30 on connector 1A which plugs into the front side of junction module J/B on the driver's side. With the trim removed this connector is easy to access.
    #12 gdanner, Aug 16, 2025 at 8:56 PM
  13. gdanner
    gdanner Member
    102
    Central Illinois
    After plenty of hours of searching I located the elusive J6.
    In the following photo, J6 is the "junction connector" with the black cap on it. The wires going into J6 are red, yellow, green, brown, and white.
    FYI, the other junction connectors in this photo are J17 (blue cap) and J18 (gray cap).
    Another junction connector, (J10, white cap) is barely visible in this photo behind the wiring harness.
    However, J10, J17, and J18 play no role in "the case of the missing 12V."
    With that said, they were easy to find (compared to J6).
    Next I checked the 3 red wires on J6 which feed power from the "DOME" fuse (located in engine compartment fuse box) to the "instrument panel J/B" junction block underneath driver's side dashboard.
    My problem turned out to be exactly the same as what was stated by the OP of this thread:
    Interior lights, clock, radio, and wireless key fob all abruptly stopped working.
    Testing with a voltmeter reveals that 12V appears on all 3 red wires at J6. The probe in this photo shows the location of the 12V input wire coming in from the engine compartment. The black plug which attaches to J6 connects all 3 of the red wires shown in this photo to each other.
    One of the other 2 red wires is working properly, supplying 12V to JB pin 1A-30
    However, the second red wire which feeds 12V to J/B pin 1A-13 is open circuit.
    I haven't yet located the exact place where the open-circuited red wire has failed. There are no signs of overheating, corrosion, or other damage.
    For now I installed a temporary jumper wire between J/B pins 1A-30 and 1A-13. This restored functionality to all items powered by the "DOME" circuit. When I dismantle the rest of the dashboard to repair the combo meter I'll attempt to precisely identify where the red wire between J6 and J/B pin 1A-13 is broken.
    #13 gdanner, Aug 20, 2025 at 12:34 PM
    mr_guy_mann likes this.
