Torn radio screen protector, 3rd Gen Prius - how do I replace? what's the part number?
Discussion in 'Gen 3 Prius Technical Discussion' started by andreimontreal, Aug 20, 2025 at 2:57 PM.
  1. andreimontreal
    andreimontreal Active Member
    353
    109
    32
    Montreal
    I managed to tear the screen protector without damaging the screen (an alu pipe did that, enough said). Been looking for a replacement part, something, but I'm most likely not using the proper wording. What's the part or an alternative and how do I fix this?
  2. andreimontreal
    353
    109
    32
    Montreal
    I keep finding these "digitizer" parts. Is that what that part looks like? I thought it was just a piece of plastic, nothing electronic.
  3. andreimontreal
    353
    109
    32
    Montreal
    Update again. Took the screen out and it's 100% the digitizer. I ripped off the piece of plastic and it seems like I damaged some electric connectors as well - the digitizer looks pretty but doesn't work anymore. If you need to take the plastic off at least try heat to see if you can undo the glue or cut it with an exacto or scisors.
    I found the digitizer on aliexpress and ebay - now I'm weighin the costs of replacing it or getting a 3rd party NAV which can display the maps.
    Case closed.
  4. andreimontreal
    353
    109
    32
    Montreal
  5. andreimontreal
    353
    109
    32
    Montreal
    PS: looking at the cable, the numbers of wires seems off. Checking now more in detail.
