Featured Dome light fuse / J6 Connector / slow battery drain
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MozartFixerPrius, Dec 31, 2019.
  1. MozartFixerPrius
    MozartFixerPrius New Member
    Boston
    Hello to all.
    I'm new here, first post. Been reading blogs for a long time. I hope someone smarter than me can help.
    I have a 2007 Prius hatchback gen 3
    The dam car keeps dying the battery in the winter, I even attached two batteries in series for the last winter, but now I decided to solve the problem.
    I traced the problem to a dome fuse and from there to a J6 connector that have issues.
    The problem is that the J6 connector connects to 34 subsystems, and I do not have the expertise or time to take everything apart.
    I found that those 3 connectors on the picture 1 are grounded and I have no idea where they go to.
    Here are the one grounded
    Here is a back picture
    Here is the manual description, it only says j6, does not describe what each one do
    Any help is appreciated
  2. MozartFixerPrius
    Boston
    I'm sure it is the J6, because disconnecting it, the draw falls from 0.38A to 0.05A, and there is a red wire that is grounded.
  3. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Welcome to PriusChat!!
    How many hours per week do you drive this vehicle?
    How old is your current 12v battery?
  4. MozartFixerPrius
    Boston
    Battery is 6 months old and the other is 3 months, a yellowtop. I drive about 100 Mike's per week, sometimes 350 a week. The car makes about 44.5 mph.
    I tested the charging on the battery and says 13.7 stable.
    I already tested everything else and found that connection is the culprit. It drains a stable 0.30A alone. Removing the fuse it reduces that much, to almost Zero. Removing the Cap from the J6 does the same.
    Testing the leads on the J6 shows 3 grounds.
    If only I knew what these points are would be easier.
    Wiring diagram
    #4 MozartFixerPrius, Dec 31, 2019
  5. bisco
    52,393
    how many volts does it lose overnight?
  6. MozartFixerPrius
    Boston
    It is a pain to test that information, it doesn't loose enough to shut down the bat low voltage, since 0.38A or 0.4A isn't that much, but in two days does drop to 11.5V. the battery is small on Prius.
    I can calculate and estimate, 0.4A/hr * 20h = 8A, and 8A at 12v is about 96watts. But constant drop can cause battery problems, like loosing acidity.
    Anyways, treating the battery doesn't solve the problem. The solution is to find the parasitic draw, and i found where the parasitic drain is occuring, I am just not sure where it leads.
  7. Elektroingenieur
    2,515
    3,287
    Three Touring
    I’ve discussed junction connector J6 before. I wouldn’t assume that there is anything wrong with the connector or fuse; among its other functions, J6 connects the unswitched DOME and HEV circuits to loads, such as the body ECU, door control receiver, and hybrid vehicle control ECU, that all need power when the car is off.
    There aren’t actually that many loads. In the System Circuit pages of the Electrical Wiring Diagram (more info), J6 is shown in the diagram for every system that involves the combination meter, for example, since one of its power supply connections is from the DOME fuse, via J6.
    What were the test conditions? For example, were the doors open (so the interior lights would be on), or did you have a key in the car or nearby? Have you reviewed any of the earlier threads about similar problems?
    I’m not sure how you’re testing, but it wouldn’t surprise me that you’d see low resistance to ground. If the terminals were actually grounded, though, I’d expect fuses to blow.
    This calculation is faulty. A current of 0.4 A (400 mA) at 12 V is 4.8 watts, no matter how long it continues.
    SFO likes this.
  8. Patrick Wong
    18,210
    6,513
    Since you have the ability to measure the quiescent current flow, I suggest you look for a stuck relay in the main relay/fuse box next to the inverter, in the relay box above the engine, and in the relay/fuse box under the dashboard, driver side.
  9. MozartFixerPrius
    Boston
    thanks elektroingenieur
    I have reviewed all the answers on this forum prior to open my own blog, the decision was not lightly or lasy. Like I said I before, I tested the continuity in all the terminals and found that the terminals above mentioned are grounded to the chassis, I didn't test the resistance, perhaps I should, or I WILL and will give a response here. , meaning they are bad. If all BBB is supposed to be shorted so they are connected without a splice then one of them is shorted, and so forth.
    It is good to know that most of it are due to the combination meter. I will have to take the whole front panels to access the plug for that, so I can test.
    Test conditions are the same as any other electrical test.
    1. Doors open / close
    2. lights on / off
    3. test the amperage every time with a boy helper
    4. wait for the car to settle with all locked and amperemeter outside
    what did I find?
    1. normally I will have a 0.4 A draw constant with the key away from the car and the keyless system off
    2. removing fuse dome will reduce to 0.08A draw (acceptable?) maybe
    3. testing the J6 connector shows one of the red leads BBB is shorted to ground showing continuity or very low resistance (to be tested the resistance)
    4. I did not follow any circuit after the J6 so I cannot say what is beyond causing the issue, I guess I have to take the panel apart to find the issue.
  10. MozartFixerPrius
    Boston
    I found the issue, couldn't sleep after posting the tread.
    It is the combination cluster. I took apart the panel to that point, disconnected one of the white connectors for the cluster and the draw came down from 0.38 to 0.05A instantly.
    Now I removed the whole panel off, and I am studying what can I do to fix it or replace it.
    SFO and Elektroingenieur like this.
  11. MozartFixerPrius
    Boston
    gdanner and SFO like this.
  12. bisco
    52,393
    texas hybrid batteries
    edthefox5 and J1050 like this.
  13. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    271
    563
    Dallas -Fort Worth
    I’ve seen this before. There’s a switching circuit in the combo meter that draws about 300 mA from the dome circuit. It’s only supposed to draw for about 10 seconds after the car is turned off but if the switching transistor fails it will continue to draw.
    I can tell from the picture that somebody worked on that board before. They either damaged something or didn’t realize the problem.
    We’re aware of this possible malfunction so all meters that we sell are tested for proper current draw and shut down switching operation before going out to a customer.
    I’d be happy to work with you on a repair or replacement.
    Matt
    TX Hybrid
    gdanner, ydpplqbd, edthefox5 and 4 others like this.
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    I highly recommend Texas hybrids for the win.
    On my second year of his rebuild works like a champ. Thanks Matt!
  15. MozartFixerPrius
    Boston
    Hi thanks, I will get in touch with the repair man that I hire didn't work it right. Unfortunately, I already paid to be fixed. Hope will work.
    Thanks for all so far, has been a great adventure.
    I will follow up.
    Texas hybrid battery, thanks for the info.
  16. bisco
    52,393
    pleasure
  17. *Goldfinger*
    *Goldfinger* Junior Member
    81
    Sheffield, England
    Did you resolve this draw problem? I too have a constant parasitic draw on that circuit of 0.4A
    Regards
    David
  18. gdanner
    gdanner Member
    134
    51
    Central Illinois
    The combo meter PC board contains a DC-DC switching power supply which provides proper voltages to the VFD (vacuum fluorescent display).
    You are correct that this DC-DC converter should switch off when the car is off.
    The 300mA drain should occur only when the VFD is illuminated (car in IGN or READY mode). However, something is causing this DC-DC converter to remain active at all times. It should only be switched on during times when the VFD display itself is illuminated due to the car being in "READY" or "IGN" mode.
    I've been working with VFD displays throughout my lengthy career as an electronic design engineer. Starting in the 1970's they became popular in clocks, calculators, VCRs, CD players, microwave ovens and many other home stereo components and appliances. They are still widely used today.
    VFD displays are actually a specialized vacuum tube. They contain a filament which must be heated in order to emit the stream of electrons which lights up the blue-green fluorescent segments inside the display. This filament does not get bright enough to glow visibly. However, power consumption of a VFD filament is 1 to 2 Watts (or a bit more) even though it isn't hot enough to glow. Because the Prius combo meter VFD display is rather large and also must be capable of getting very bright in order to be visible inside a car, its filament will have higher power consumption than VFD displays used in household devices.
    My theory is this 300 mA is powering the VFD filament even though the car is off and the display isn't displaying anything. 12V x 300mA = 3.6 Watts.
    This DC-DC converter generates the proper voltages to operate the VFD. As described above, the VFD filament requires 3 to 4V at roughly 600mA (2.4 Watts). A VFD also requires a -30V DC source to supply the stream of electrons which causes the fluorescent segments to glow. Current demand from the -30V source is <50mA (up to 1.5W). Max current occurs only when many of the VFD display segments are illuminated at the same time. However, the VFD filament current is constant regardless of whether any of the fluorescent segments are visibly illuminated. Therefore 2-3 Watts will still be consumed by the filament itself even when all of the fluorescent segments are off.
    The DC-DC converter is located near the transformer on the lower right corner of the combo meter PC board. There are several electrolytic capacitors of the "through-hole" type located near the transformer. This section of the combo meter PC board is several inches away from the place where the well-known 220uF 16V capacitor which often fails is located. In fact the 220uF capacitor bears no relationship to this other issue of the combo meter consuming excessive 12V supply current while the car is off.
    Therefore this issue needs to be addressed so that forum users who choose to repair their combo meter can end up with a repair which is fully functional.
  19. gdanner
    gdanner Member
    134
    51
    Central Illinois
    Update: I discovered this thread while searching for issues related to "junction connector" J6.
    Hopefully the following details will be helpful to Prius Chat members:
    The 3 red wires which go into junction connector J6 carry 12V which is "always on."
    When the black plastic cap is plugged into J6 it connects these 3 red wires together in parallel.
    One of these red wires comes from the "DOME" fuse located in the engine compartment main fuse/relay box. This wire is the source of 12V power coming into J6.
    The two other red wires in junction connector J6 go across the dash to the "Instrument Panel J/B" fuse/relay unit. These 2 red wires feed 12V to J/B.
    Both red wires terminate into a large connector labeled 1A
    Connector 1A is located on front side of J/B. It is easy to access after removing the lower plastic trim panels from the driver's side.
    One of these red wires goes into connector 1A at pin 30.
    The other red wire goes into connector 1A at pin 13.
    In my case there is an open circuit between J6 and 1A pin 13. This prevents my interior dome lights, clock, radio, and wireless key system from operating. I haven't yet found where this red wire is broken or disconnected. This is the first time I've had any electrical faults under the dash in my 2005 Prius which I've owned for 19 years.
    The issue for the OP of this thread was excessive current drain (300mA) at all times on the red wire going into 1A-13.
    The circuit receiving 12V from pin 1A-13 feeds 12V to the combo display, which evidently wasn't entirely shutting off for the OP, thus causing the 12V battery to discharge.
  20. Sean_999
    Sean_999 Junior Member
    Seattle, WA
    Hi "gdanner": would this 3.6 watts be enough power that one could feel warmth there (where the speed digits are displayed when the car is in use) even when the car is totally powered down with all power (supposedly) off?
    -Sean
