Problem using Airlift to pull vacuum
Discussion in 'Gen 3 Prius Main Forum' started by Bob the occasional mech, Aug 21, 2025.
  1. Bob the occasional mech
    North Carolina
    I replaced the water pump on my wife's 2010 Prius, and now I'm all set to refill the cooling system. I purchased an Airlift vacuum system to speed up the refill and help eliminate air bubbles. The coolant tank refill neck narrows to a very small opening just past the mouth of the neck, which prevents me pushing the funnel shaped Airlift adapter far enough into the neck to get a good seal without the adapter moving around. But I found if I combined the funnel adapter with one of the other smaller adapters, I could get what looks like a decent seal, and is reasonably stable.
    So, with the Venturi valve secured to the Airlift body, and air hose attached, and overflow tube and bottle ready, it looks ready to go. I turn on the air and I hear a high pitched whine of air movement through the Venturi valve (which I think is normal when the Airlift valve is still closed), I open the valve, but no vacuum develops. The only noise is air flowing into the overflow bottle (but now without the whine). :-(
    I have a feeling I'm forgetting something, but I can't figure out what. I double-checked the radiator drain cock to be sure it's closed tight. I suppose the Airlift may not have a good enough seal to the tank, but it looks good enough to least draw a slight vacuum. It's almost like the Venturi valve is broke, but I doubt that since it probably has no moving parts. I double-checked the Airlift body valve to ensure it appears to be opening and closing properly. It looks like the water pump is well mated to the engine all the way around.
    Any ideas about what I might be doing wrong? Does anyone have a good tip on how to get a good, stable seal between the Airlift body and the tank?
  2. Mendel Leisk
    41,384
    I’ve used the method proscribed in repair manual, no special equipment needed, and went pretty smooth.
    I wouldn’t bother with the engine block drain btw, I’d heard it was a waste of time, had to find out for myself, think I got 1/2 cup, at most.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,462
    2,422
    Taylors, SC
    I had no problem with the UView airlift and have used it twice with my Gen 3 Prius v.
    I used only the little rubber tip and no other rubber adapter.
    It worked just fine and made a good seal.
  4. Tombukt2
    12,924
    2,322
    Heck I never had a problem filling 3 it's the 2 that's at issue. Water slam rt onto a 3 pretty quick
  5. ASRDogman
    ASRDogman Senior Member
    7,564
    3,903
    If you fill it very slowly, a small amount at a time, you won't have air bubbles.
    The slowly filling coolant will force out the air....
  6. Georgina Rudkus
    3,462
    2,422
    Taylors, SC
    Only problem was the hard set in the coiled vinyl hoses.
    The intake would spring off the bottom of the container and start suckling air ruining the procedure.
    I finally replaced them with super flexible silicone hoses.
  7. ChapmanF
    18,118
    There aren't many typos that can change a meaning more completely than prescribed / proscribed. Using the proscribed method, you rebel, you!
    My experience also. Using the prescribed method Just Works. The gen 3 degas-bottle system ships any trapped air back to the bottle where it trades places with the extra coolant between the FULL and B line, leaving the level at FULL.
    #7 ChapmanF, Aug 22, 2025
  8. Mendel Leisk
    41,384
    Huh, I have been blissfully unaware of the difference, thanks.
  9. Tombukt2
    12,924
    2,322
    I try not to use in big words like mayonnaise.
  10. Bob the occasional mech
    North Carolina
    Thanks, Georgina, that solved the problem! I wasn't sure what that small piece was for since it didn't look or fit the same way as the other adapters, but after seeing your reply, I finally realized it does indeed attach to the Airlift body and creates a good seal. It's amazing to see how fast and easy it makes refilling the coolant!
    Thank you, everyone, for your responses!
    Mendel Leisk and Brian1954 like this.
