Can’t reset maintenance required light after replacing head unit?
Discussion in 'Gen 3 Prius Audio and Electronics' started by fgaston, Aug 22, 2025.
  1. fgaston
    fgaston Junior Member
    Old Lyme, CT
    2023 Prius Prime
    Replaced the head unit of my 2014 prius with an aftermarket stereo. That causes me to lose the ability to reset maintenance required light after an oil change.
    I tried looking up and resetting codes with an obd2 scanner but no luck. Any suggestions?
  2. AzusaPrius
    AzusaPrius Senior Member
    2,230
    930
    Buy the harness that allows you to use the steering wheel controls.
  3. ASRDogman
    ASRDogman Senior Member
    7,796
    3,976
    I believe you put the trip display on "A". With the car off, press and hold the mph/kph button,
    then start the car. That's how I reset mine.
  4. Mendel Leisk
    41,871
    When the maintenance required alert is displayed does it block display of other info? Just curious, in Canada we don’t have this “feature”.
  5. AzusaPrius
    2,230
    930
    Pretty sure the OP has reset the oil message before, just now he lost controls because he installed an aftermarket radio without a steering wheel control harness.
    Also yes it blocks all other info when you can not reset it.
  6. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    The car’s audio overall is junk, shocked that people even upgrade it, still junk with new head unit. Get a code reader that doesn’t rhyme with larista to remove it. Or get a hacked version of techstream to kill the light. Oh wait that’s promoting software piracy.
  7. Mendel Leisk
    41,871
    Anything wrong with larista rhyme-mate?
  8. amarino
    amarino Active Member
    142
    105
    99
    I think you need to share what aftermarket radio you installed and how it interfaces with the steering wheel controls. From what I've seen they should not affect the right side of the steering wheel controls where the Trip/Display/Temp/Recirculate are located. Only the left side where the media controls are.
