Metal-on-metal rasping cicada-like noise
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Groutchmeuh, Aug 21, 2025.
  1. Groutchmeuh
    Groutchmeuh New Member
    France La Teste de Buch
    2013 Prius+ MPV
    Hi everyone,
    Anyone ever run into this kind of noise?
    2013 Prius+ (Prius v for USA/Canada)
    When I accelerate gently while on the gas engine, I often get this weird metal-on-metal rasping / grinding noise a bit like a metal cicada or like a saw against a metal bar. Goes grinn-grinn-grinn, sometimes once, sometimes a few times in a row.
    Toyota said everything looked fine at service. Took a mechanic out for a drive — he heard it too but had no idea. Appointment booked to dig into it.
    Short recordings (hosted on my PCloud) will be posted as soon as am given permission (but I should post 4 times , so quite hopeless.)
  2. Groutchmeuh
    2013 Prius+ MPV
    Copy paste error
    The message should've ended with :
    "Appreciate any thoughts or ideas.
    Thanks!"
  3. 2015V-BadHG
    2015V-BadHG New Member
    Portsmouth NH
    2015 Prius v wagon
    Yikes that's never good.
    Maybe timing chain?
    If the timing chain tensioner is failing or dirty?
    Do you have leak down back of motor towards front , just below valve cover?
  4. Groutchmeuh
    2013 Prius+ MPV
    Thx for the fast reply.
    I 'll suggest the mechanic ! I'm totally dumb.
    But I see no leak
  5. Groutchmeuh
    2013 Prius+ MPV
    I posted a VIDEO on YOUTUBE
    You may lesten to the noise if you search Youtube for
    Prius plus (v for USA/CND) noise
    It comes up on top
  6. rjparker
    10,238
    6,393
    This is his "video" with about 3 seconds of sound only
  7. Groutchmeuh
    2013 Prius+ MPV
    Thanks for your efforts but something happened to this video . I had to convert an MP3 recording into a video to post it on Youtube and the converter added an empty track.
    I had edited the sound to decrease backgroune nois and suppress parts of the recording with no event.
    Yet 2 occurrences of the weird noise can be heard within those 3 seconds/
  8. bisco
    52,093
    how many miles/km on her?
  9. bisco
    52,093
    for anyone listening, there are only sounds in the first 5 seconds, don't keep listening.
    there are two distinct sounds in those first 5 seconds, is it the second sound that is new?
  10. bisco
    52,093
    can you determine what part of the car it is coming from? i don't hear the engine starting, so i'm assuming it is a pump
