Hitting noise coming from back seat area, when start the car. 23 prius
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by priusasa, Aug 23, 2025.
  1. priusasa
    priusasa Junior Member
    52
    2023 Prius
    Before I go to dealer, I wanted to write here.
    When you start the car, I hear this noise. First, it's like a buzzing sound, not from the brake actuator. But like some motor is engaging. (around 1 second)
    Right after I hear "tık tık tık tık tık" sound, then it stops. It's like it's trying to do something but it can't.
    That sound coming from back seat area.
    When I turn on the car and run back to trunk and listen, I don't hear much. So it's not coming from trunk. It's somewhere in the back seat.
    Usually it's coming when car sits longer time before I start.
    Maybe from fuel pump? Or some doors for fan in the back seat? Not sure. Do you hear something like this?
    I will go to dealer but I am sure they won't diagnose and won't care because it doesn't come every time and needs effort to hear.
    51,517
    can you post a recording?
  3. priusasa
    52
    2023 Prius
    I will try. Its low sound but I will try to record. I know its difficult to understand if you dont have the same noise. But that also means its not normal and something is wrong with my car
  4. BiomedO1
    3,118
    1,653
    SacTown, Ca
    There's the fuel pump, Evap, and traction pack cooling fan back there.
  5. Tande
    Tande Active Member
    536
    318
    Mich.
    Electric "E" brake releasing......maybe? .....
  6. bisco
    51,517
    can you have someone start the car while you sit in back to get a better idea of location?
  7. priusasa
    52
    2023 Prius
    This is the video. first video, I played with the sound so it is louder. Second one as is.
  8. bisco
    51,517
    that isa very strange sound, i've never heard anything like it. did it just start recently?
    it sounds a little like a stuck hvac door, but that would be in the dash
  9. Hammersmith
    Hammersmith Senior Member
    2,164
    2,164
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I was thinking a problem with the evap system, but that would've probably thrown an error code and check engine light.
  10. bisco
    51,517
    maybe it won't if it's just noisy and still working
  11. priusasa
    52
    2023 Prius
    Edit: I am getting closer to find where that sound coming from. When I open the gas cap, then close it, sit in the car and close the door, that sound comes.
    That means something is engaging after closing the gas cap. Chatgpt says it might be evap pressure sensor or something like that.
