Hitting noise coming from back seat area, when start the car. 23 prius
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by priusasa, Aug 23, 2025.
  1. priusasa
    priusasa Member
    100
    51
    2023 Prius
    Before I go to dealer, I wanted to write here.
    When you start the car, I hear this noise. First, it's like a buzzing sound, not from the brake actuator. But like some motor is engaging. (around 1 second)
    Right after I hear "tık tık tık tık tık" sound, then it stops. It's like it's trying to do something but it can't.
    That sound coming from back seat area.
    When I turn on the car and run back to trunk and listen, I don't hear much. So it's not coming from trunk. It's somewhere in the back seat.
    Usually it's coming when car sits longer time before I start.
    Maybe from fuel pump? Or some doors for fan in the back seat? Not sure. Do you hear something like this?
    I will go to dealer but I am sure they won't diagnose and won't care because it doesn't come every time and needs effort to hear.
    52,271
    can you post a recording?
  3. priusasa
    priusasa Member
    100
    51
    2023 Prius
    I will try. Its low sound but I will try to record. I know its difficult to understand if you dont have the same noise. But that also means its not normal and something is wrong with my car
  4. BiomedO1
    4,000
    2,103
    SacTown, Ca
    There's the fuel pump, Evap, and traction pack cooling fan back there.
  5. Tande
    Tande Active Member
    549
    337
    Mich.
    Electric "E" brake releasing......maybe? .....
  6. bisco
    52,271
    can you have someone start the car while you sit in back to get a better idea of location?
  7. priusasa
    priusasa Member
    100
    51
    2023 Prius
    This is the video. first video, I played with the sound so it is louder. Second one as is.
  8. bisco
    52,271
    that isa very strange sound, i've never heard anything like it. did it just start recently?
    it sounds a little like a stuck hvac door, but that would be in the dash
  9. Hammersmith
    Hammersmith Senior Member
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I was thinking a problem with the evap system, but that would've probably thrown an error code and check engine light.
  10. bisco
    52,271
    maybe it won't if it's just noisy and still working
  11. priusasa
    priusasa Member
    100
    51
    2023 Prius
    Edit: I am getting closer to find where that sound coming from. When I open the gas cap, then close it, sit in the car and close the door, that sound comes.
    That means something is engaging after closing the gas cap. Chatgpt says it might be evap pressure sensor or something like that.
  12. priusasa
    priusasa Member
    100
    51
    2023 Prius
    Update: That noise coming from here: upload_2025-9-23_16-57-56.png
    sound comes everytime I open the gas cap and close it, and close the doors.
  13. AgentPTFC
    AgentPTFC Member
    57
    PNW
    2025 Prius Plug-in
    XSE Premium
    Is it malfunctioning and needing to be replaced?
  14. priusasa
    priusasa Member
    100
    51
    2023 Prius
    I am not sure. When my gas is low, I might take the hoses out and take it. There might be something inside stuck. I will take a closer look. Also, I can not find the exact part on google anywhere. Neither Toyota parts or rockauto. Part no on repair manual is 77070A but when I google it, the result is sligly different part. I dont have check engine code also.
    813ebead-06e0-4302-aec7-b9b4cd656ec8.jpg 99396f51-914c-444c-b1fe-291246498d20.jpg
  15. Hammersmith
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    90910-15087 - Close Tank Valve Sub-Assembly
    $575.74 MSRP
    $398.05 31% off
    $298.54 w/Black Friday sale
    VelvetFoot likes this.
  16. priusasa
    priusasa Member
    100
    51
    2023 Prius
    nice shot. I wont pay that, dealer has to pay that. I went there few months ago for service campain (About fuel stuff), but they did wrong thing that day and they had to keep the car one more day. After that this sound started to come. But I dont have any proof. I will go there and see what they say
    PrimeDan likes this.
  17. VelvetFoot
    VelvetFoot Active Member
    1,120
    435
    New York State
    2026 Prius
    Holy cow. That's crazy.
    A similar part threw CEL on my MINI. Part was way cheaper.
    Has an OBDC reader been used? Perhaps it hasn't been in failure mode long enough to throw a CEL.
    edit: How about a pinched hose? Maybe take it off and spray it out with something or other? Is this part of the usual emissions warranty?
  18. priusasa
    priusasa Member
    100
    51
    2023 Prius
    I went to the dealer and I told them where the noise coming from. I tell them the part name and picture. After 5 hour. they told me they could not find where the noise coming from... I am like. bro i told you its this part.... Anyway, they told me car needs to stay one more day and they provide me rental car, which is good and i would not expect that from them.
    The rental car is also prius le with 5k mileage, probably its 2025 model. Do you know what is amazing? That car has the same noise! Little bit less than my car but I can still hear it easily. If I assume that sound is normal, how nobody noticed and said something? Also, how Toyota make that sound default for the cars. I dont know, its just interesting.
    This car also makes `Clicking noise when braking reverse`. But that one conformed by people in this forum as normal.
  19. VelvetFoot
    1,120
    435
    New York State
    2026 Prius
    Hopefully they don't charge you.
  20. priusasa
    priusasa Member
    100
    51
    2023 Prius
    I conformed that if they want to charge anything, they will ask me before they contiune.
    PrimeDan and VelvetFoot like this.
