Bug deflector and window rain visors
Discussion in 'Gen 5 Prius Accessories and Modifications' started by CruisnGrrl, May 24, 2023.
  1. Blackat
    Blackat Active Member
    476
    338
    Colorado
    2023 Prius
    Limited AWD-e
  2. 2023p
    2023p Active Member
    161
    102
    Here
    2023 Prius
    the in channel versions from WellVisors company are available now, haven't gotten them but considering. they also use pre layer double sided tape but it's for the inside area
    Wellvisors In-channel Window Visors 4Pcs For Toyota Prius Prime 2023-2024 23 24 | eBay
    if anyone gets or has these, please report back, maybe with pictures too. thanks
  3. Djyoshi626
    Djyoshi626 Junior Member
    34
    LA
    2024 Prius
    I have a spare set of GR Window Visors (minus the driver rear) if anyone's visors flew off. I haven't had any issues with it other than the trunk recall where the dealer had to remove my rear visors to fix. One of my visors flew off when I stuck it back on so I ordered a new set.
    2023p likes this.
  4. kev604
    kev604 Junior Member
    56
    49
    Vancouver, BC Canada
    2026 Prius Plug-in
    Grabbed a set of OE window visors from the dealer. Install looks straight forward just two clips and double sided tape. Surprised to see these were made in Japan so expecting good quality. Will follow-up with pics once I get them on.
    2023p likes this.
  5. Pepe Mtz
    Pepe Mtz New Member
    Rhode Island
    2023 Prius Prime
    XSE
    Found this hood deflector on Amazon Japan but no deliveries to US, at least it exists somewhere
  6. kev604
    56
    49
    2026 Prius Plug-in
    Got the OE window visors done on the weekend I always put window visors on my cars. Quality on these are top notch made in Japan glad I went with these over less expensive aftermarket.
    Install is super easy there are two clips the clips don't actually clip on to the frame more to help the visor sit on to the window frame. The visor is held on only with 3M tape. Key is to make sure the visor is lined up with the window frame before it sticks down then just slowly pull off the tab and apply some pressure to the sticky parts and done.
    Overall I love the aesthetic love how it sits nice and flush and the color is perfect too it's clear with a slight tint but not too dark.
  7. BiomedO1
    4,022
    2,111
    SacTown, Ca
    In my experience; you need the check the double stick tape every fall. The leading edge tends to loosen up and start flopping around, due to the hot summer heat any you blasting down the road at over 75 mph. So buy a small roll of that double-sided adhesive tape to fix that. The best time to do this is when it's still warm outside. The hotter it gets the loser the adhesive gets.
    Looks great; also check it, if you hear dash board rattles - It could be that visor rattling around in the wind.
    2023p likes this.
  8. otatrant
    otatrant Active Member
    348
    211
    San Francisco
    2023 Prius Prime
    XSE Premium
    2023p likes this.
  9. mingc
    mingc Member
    73
    56
    Portland, OR
    2023 Prius
    XLE AWD-e
    Back when I was a kid, my dad always had window visors on his cars. This was back in the day in the old country where no cars except for luxury makes were air conditioned. Most cars there had widow visors and they were always chrome. Window visors allowed you to drive with the window cracked down an inch or two in order to allow air to circulate while keeping out most of the draft and, perhaps more importantly, rain if it was raining. Now that all cars are air-conditioned and are driven with the windows closed, what are window visors for?
    #49 mingc, Dec 24, 2025
  10. BiomedO1
    4,022
    2,111
    SacTown, Ca
    You answered your own question. Rain & air circulation - some of us don't like the car's interior from getting too hot while we're working and it keeps the rain out, if it rains.
    2023p and mingc like this.
  11. mingc
    mingc Member
    73
    56
    Portland, OR
    2023 Prius
    XLE AWD-e
    So you drive with your window cracked open? The only time I ever do so here in the Pacific NW is if someone hasn't showered or has farted in the car! Otherwise, I keep the windows closed to keep rain or pollen out.
  12. BiomedO1
    4,022
    2,111
    SacTown, Ca
    Yep, summers are brutally hot and if you don't have your windows cracked - opening the door would be like sticking your face in a blast furnace. Interior would take longer to cool down too. I don't get wind buffering until I lower the glass below the visor. It's also great for the occasional car camping.
    2023p likes this.
  13. kev604
    56
    49
    2026 Prius Plug-in
    The obvious one would be to keep the rain out.
    To keep dirt, dust and pollen or anything else from entering the vehicle while driving with the windows slightly cracked open actually alot of.the.dirt and dust in a car comes from the windows being open.
    Also when I'm parked and sitting in the car I like to crack the windows for fresh air and to help the windows from fogging up especially when it rains. I love in the Pacific Northwest as well.
    And I just like the look of visors on my cars especially these well designed ones for the Prius.
  14. BiomedO1
    4,022
    2,111
    SacTown, Ca
    Your correct, dust and pollen does get into the car while parked and windy. If it's not windy, that stuff stays out of the car because the route into the car is not a direct one. The amount of stuff getting into the car will be determined by far down you have your window. My windows are always down about 1/8-1/4 inch. I use to have it down further, but wild fire ash made it into my car. 1/8 inch down seems to be the happy median, but you'll sometimes get window rattle - close the glass, rattle goes away. I'm going to need to shove some padding or weather stripping behind the window guide felt to tight them up a bit. Another project on my to-do-list.:(o_O
  15. VelvetFoot
    VelvetFoot Active Member
    1,140
    450
    New York State
    2026 Prius
    I always thought they were for smokers.
    mingc likes this.
  16. otatrant
    348
    211
    San Francisco
    2023 Prius Prime
    XSE Premium
    Here is a link to the listing on buyee.
  17. Blackat
    476
    338
    Colorado
    2023 Prius
    Limited AWD-e
    Nah, that's the side wing window......haha
    VelvetFoot likes this.
