2008 Prius Breakdown - 4 Codes: P1121 P0420 P0A80 P3012
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ChunkyLover53, Aug 23, 2025.
  1. ChunkyLover53
    ChunkyLover53 New Member
    Springfield NM
    Hello all,
    First post on the forum, but long time Prius owner, had a 2007 prius for several years until an accident and then replaced that one with my current 2008 Prius a couple years ago, it has about 120,000 miles on it and as far as I know the HV battery is original, the cat converter was stolen at one point and replaced.
    Has been driving fine then all of the sudden this morning on the way to work the Prius went bonkers and threw these 4 codes along with the red triangle of death.
    The HV battery fan turned on in the back, and the prius could barely drive, I'm guessing this was a fail safe mode, I was able to limp it a couple miles back home, but it barely would go over 15 to 20 miles an hour and the accelerator pedal wouldn't do anything which is odd - the vehicle would move forward at 15 to 20 mph with no pressure on the accelerator pedal, fortunately the brake pedal still worked.
    These are the codes my matco MD60 OBD scanner read out (this is all I've got at the moment, but sounds like there are better code readers / apps out there that can tell you more info and specifics on the HV battery)
    • P1121 - Coolant Flow Control Valve (my reader called it an "Accelerator Pedal Position Sensor problem" but I don't think that description is correct, it should the coolant flow control valve)
    • P0420 -Generic Catalyst System Efficiency Below Threshold (Bank 1)
    • P0A80 - Generic Replace Hybrid Battery Pack
    • P3012 - Battery Block 2 becomes weak
    Anyway, I'm wondering how screwed I am here. Did the HV battery and catalytic converter both just decide to catastrophically fail this morning or could it be as easy as the coolant flow control valve have broken and replacing it would fix the other codes because coolant isn't flowing through the system causing all the codes to trigger?
    Any input is appreciated.
  2. Brian1954
    Brian1954 Senior Member
    2,402
    962
    South Central PA, USA
    If you want to keep this car, the hybrid battery needs to be replaced or repaired. That will fix the P0A80 and P3012 trouble codes. After that, you can then work on fixing the other two codes.
  3. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    P1121 is an error at the Coolant flow Control valve. Usually it means that the ECM could not command the gear within the valve case to move or rotate. Check out my post in: Gen 2 technical discussion - Water Valve controller disassembly - of this valve and how it works if you are interested.
    AND Welcome aboard by the way!
    #3 Dion Kraft, Aug 24, 2025
    Brian1954 likes this.
  4. rjparker
    10,503
    6,593
    Sounds like you have three problems. Might be time to decide if that car is a keeper or not. The battery fan increased speed because the battery was overheating.
    The P0420 code probably was there already and is due to the aftermarket cat. I don't think it caused your limp mode. Most likely the hybrid battery is way past due.
    #4 rjparker, Aug 24, 2025
  5. ChunkyLover53
    Springfield NM
    Thanks for the input everyone!
    I did replace the coolant flow control valve this weekend and after bleeding the system the P1121 code is no longer there. This is probably the 3rd coolant flow control valve as the bad one I took out was a Dorman part, not OEM.
    However, the HV codes and corresponding triangle of death remain (PA080 and P3012). I haven't taken it for a full test drive, but while bleeding the heater core on the coolant system the triangle of death would pop up within a minute or two of staring the car.
    I agree it is time for a new HV battery. It is one of those things about keeping it vs getting a newer Prius. For me, I think given the fact that I have brick on 4 wheels in my garage without a new HV battery in it, it's probably a move to repair it and continue to use it as opposed to spring for a new Prius.
    Definitely a fan of the Prius though, typically super reliable, great daily drivers. The next car I get once this 08 bites the dust will be probably a Gen 4 ... not really stoked on the new gen 5, I feel like they've deviated from the true prius core
    #5 ChunkyLover53, Aug 26, 2025
  6. ChunkyLover53
    Springfield NM
    I'm looking at Electron Hybrid Solutions for doing a rebuild kit. Has anyone had good experience with that battery company?
    Since I'll already be working on the HV battery is it worth proactively replacing the HV cooling fan motor assembly and getting a new air filter as well? Does the fan tend to fail over time? I live in New Mexico and based on the peeling paint my prius has probably lived most of its 17 year life parked in the hot desert sun.
