Passenger side rear view mirror rotated wrong direction
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pasadena_commut, Aug 24, 2025 at 8:57 PM.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,387
    711
    Southern California
    My wife came home yesterday evening and reported that she had hung up the passenger side rear view mirror of our 2007 on a concrete pillar while slowly backing into a parking space. (Somehow it was the pillar's fault.) I went out expecting to see it either missing or dangling there, but it looked perfectly normal. So I tried moving it (carefully) and discovered that these mirrors normally will actually rotate "the wrong way" quite a bit, which is why it didn't just tear off. That is, while it will rotate 90 degrees when folded in normally, it can also rotate almost as far when "folded in the wrong way". The movement didn't feel much different than the unsullied passenger side mirror, with two exceptions. First, it felt very slightly rougher. That might just be dirt, dust, leaf fragments, or spider webs, as the car was really dirty at the time. Secondly, when in the "normal" driving position if lifted gently at the distal end it had a bit more range of motion. Hard to measure, but if the normal driver's side was as designed (probably) and its wobble range up/down was 2 mm then the passenger side had a range more like 4 mm. It didn't feel loose though, just more flexible.
    I have never had one of these mirrors off on this car. Had I not been told it been bent backwards by a pillar I probably would never have given the slight difference between them a moment's thought. So do I need to take it off and/or disassemble it to check for broken plastic somewhere, or is this degree of difference normal?
    Good thing it wasn't her Accord, those mirrors are fixed, with no give whatsoever.
    Thanks.
  2. PriusCamper
    PriusCamper Senior Member
    12,224
    4,959
    Pacific Northwest, USA
    I've swapped 'em out with $50 ones at the junk yard more than once. Super easy job, takes like 10 minutes. Just pop off the cover and there's just two or three 10mm bolts depending on which type of Prius. Also the plastic cover that matches the paint color of your car pops off and so you don't need to find a donor car with the same color.
  3. Tombukt2
    12,527
    2,222
    Most people will have to move or lift up the door panel to be able to plug in the mirror if you know where everything is you can do it without but it is very tricky and yes I regularly smack work cars mirror on McDonald's yellow pipes in drive thru forward and reverse a few times they do well my 02 rolla not at all
  4. pasadena_commut
    2,387
    711
    Southern California
    You are referring to the cover on the inside of the door? I'm going to assume that once that is off I'm going to see 3 mounting bolts coming in with nuts on them. And it would still look like that even if the mirror part of the unit has been completely destroyed and is no longer present.
    How does one release the colored plastic cover on the anterior side of the mirror module? If anything is broken inside it should be obvious once that is off. The manual has a picture of the retaining clips for it, which I'm sure makes perfect sense if one has already seen the actual object, but lacking that knowledge I couldn't see how this was to be released. Half the time in a case like this it is just pried off, and the other half of the time the cover needs some magic incantation and specific release motions applied to bits which are completely invisible from the outside.
  5. dolj
    dolj Senior Member
    8,285
    4,229
    Wellington, New Zealand
    Ideally, the front-facing cover is "unlatched" from the inside, so the mirror needs to come off to gain access. The mirror is clipped on at the bottom, and it is best to position the mirror in the fully up (top back, bottom forward) position to allow you to get a panel trim tool in behind it. You get the tool in – as parallel as possible, following the back of the mirror – right to the clip point, and then give it a twist to release the clips. Once released, the mirror should hinge up on the top fixing point and should easily release. At this point, you should be able to sight the fixing clips for the mirror cover, and those can be manipulated to release the clips – two top and two bottom – if I remember correctly.
  6. Tombukt2
    12,527
    2,222
    The mirror rips rt off the furry stanchions or the lil ball n socket snap it's off . Usually breaking nothing and then you looking at pancake sq motor . Usually I no fool w this I've a million mirrors . Just chuck in trash . I know use fake mirrors they make a racket.
  7. PriusCamper
    12,224
    4,959
    Colored plastic cover has hooks/clips that come apart by pulling it, maybe try a screwdriver... Near the hinge that allows you to rotate mirror forward and backwards is usually where the plastic breaks. I repaired one once using JB weld and some chunks of scrap plastic because my friend didn't want to wait for the order to come in and then she lost track of the order when it did come in and 4 years later the mirror still has not failed. I'm kinda surprised.
  8. Mendel Leisk
    40,808
    Not completely unfounded:
  9. PriusCamper
    12,224
    4,959
    That's probably why Mendel is still married! :)
