Downsized from 19" to 17" and somehow... ride quality is worse?
Discussion in 'Gen 5 Prius Main Forum' started by strawmochi, Aug 25, 2025.
  1. strawmochi
    strawmochi New Member
    Toronto, Canada
    2025 Prius Plug-in
    XSE Premium
    First post here - been lurking for a while, but finally decided to create an account and post this as I'm going insane trying to figure this out.
    Long story short, I recently downsized the tires/wheels on my 2025 Prius from 19 inches to 17 and put on a set of 215/55R17 Michelin CrossClimate 2's, hoping to get a slightly better ride quality especially on Toronto side roads (and also avoid all the other problems with 19 inch wheels).
    What I did not expect is for the ride quality to be actually much worse? Going over road imperfections (not even including potholes) is now painful rather than simply uncomfortable. My bum even feels slightly sore after getting out of the vehicle, which is not an experience I've ever had before driving any vehicle (coming from a Honda Civic hatchback and a few Camry hybrids). The dealer suggested lowering the tire pressure down to 35/33 psi (same psi as for the OEM 19"; Toyota's rec. is 36/35 for 17" tires) and did it for me, but I haven't noticed any difference.
    I have suspected it might have to do with the 215/55R17 being intended for larger vehicles; the load rating of the CC2's at this size is 94V. The OEM load ratings were 90H and 88H respectively. According to this standard load inflation chart (from ETRTO, via Toyo's guide pg 34 - Google "standard load inflation table"), if I wanted to match the 19 inches at a load rating of 88, I could go as low as 28F/27R psi on the 17 inches at load rating 94 and still support slightly higher load per tire than on the 19s (though I also hesitate to go that low as I suspect Toyota may have only recommended 35/33 on the 19 inches for comfort reasons. The load per tire variance in door jamb recommendations is quite high, with 1323lb/1279lb if we follow Toyota's rec for 195/60R17 90H and 1190lb/1157lb if following the 195/50R19 88H rec)
    Honestly, I'm quite confused why my experience downsizing the tires/rims has been this bad - and I also appear to be the only one on the webs with this experience. It doesn't seem to make any sense that it could possibly be worse than with the OEM 19 rims - and mine also came with Toyo Extensa's, so it's not a contest between the CC2 and Primacy's.
    Unless something is catastrophically wrong with the vehicle? (it's brand new, less than a month old, and came straight from the factory in Japan). Or it is the CC2's? (it seems everyone who switched their 2023-gen Prius over has only positive things to say - though I did find one, rare opinion stating that the CC2's in general rode "borderline unacceptable" with the "V" speed rating and that it was much better at "H". Not that it is helpful as they are only available with Vs at this tire size)
    #1 strawmochi, Aug 25, 2025
  2. Winston Smith
    Winston Smith Active Member
    387
    260
    OH
    2024 Prius
    LE AWD-e
    Are the suspension pucks from shipping removed from the coils? Sometimes those are missed.
    Did you try that? How was it? What was the impact on your trip mileage?
    Was your last car a small Toyota? I had a Corolla Hatch with CC2s I wore through pretty quickly, but I hadn't any ride complaints. I have the 17" Toyo Extensas on the Prius at just under 40psi. I would describe the ride as soft, but I'm a small car guy.
  3. otatrant
    otatrant Active Member
    348
    211
    San Francisco
    2023 Prius Prime
    XSE Premium
    I haven’t seen anyone on here do any objective testing but here is a screenshot from consumer reports comparing Toyo Extensa A/S II and Michelin Cross Climate 2 both in size 215/55 R17.
    RandyPete likes this.
  4. strawmochi
    Toronto, Canada
    2025 Prius Plug-in
    XSE Premium
    I actually didn't know this was a thing. I'm bringing it back to the dealer in a few days, so I'll have them inspect it.
    No, not yet. I tried 30F/29R which is the current pressure on the car, but I only took that for a spin around the neighborhood before concluding it didn't help that much. My last long-range trip (~30km) at 34F/32R was a bit strange in it used up ~50% of the battery versus ~30% when I tried it on the 19" (could have been the A/C, but I'm almost sure it was hotter a few weeks ago...)
    I guess that I'm more used to sedans and more specifically Camry's. The Civic hatch I only drove for a few months - the ride was certainly firmer/more bumpy than a Camry but even then I didn't have any real complains. The most harsh experience I can remember was driving through a fully cracked and damaged main road (or perhaps the road was stripped for construction - can't remember, but wasn't really the car's fault).
    Upon delivery, I noticed the Prius reacted quite violently on the 19" going over just a minor indent in the road at low speeds of 30-40kmh. That's when the dealer lowered the pressure from around 40 psi to 35F/33R as on the door jamb. After that, I suppose it was an OK ride quality but still firmer than the Civic (which I found strange)
    The experience with the 17"s however makes no sense to me. It was as harsh if not harsher than the 19" at 40-38 psi. You could feel every small (including invisible) imperfections in the road, even at 34F/32R. Though, technically the load capacity is also set equivalently much higher than the 19"s at 40 psi. Maybe I will need to try 28F/27R (though I also did start to notice - or at least I think I did - some wobbly-ness/excessive bouciness at 30F/29R. I'll probably get a professional second opinion first before I lower again).
    There's also another reason I hesitate to match the 35F/33R 19" door jamb rec with 28F/27R. In the owners manual, there's this passage which is only found under the 19" tires section:
    "Driving at high speeds (above 100 mph [160 km/h]) (in countries where such speeds are permitted by law): Add 3 psi (20 kPa, 0.2 kgf/cm2 or bar) to the front tires and rear tires. Never exceed the maximum cold tire inflation pressure indicated on the tire sidewall."
    Now, I don't plan to drive at those speeds, since it's not legal in Canada, but this seems to indicate Toyota only suggested 35F/33R as a compromise for comfort and not safety/other characteristics (which is a real head-scratcher as to why they designed this generation to fit 19" rims on and not something more sensible - yes, I know it's for the looks, but I really hope this trend dies soon)
    #4 strawmochi, Aug 25, 2025
  5. PriusCamper
    PriusCamper Senior Member
    12,980
    5,277
    Pacific Northwest, USA
    It's not the drop down to 17 from 19, nor is it the tire load rating that's the problem. It's a combination of two things:
    1) lower profile of 55 on top of reduction of two inch diameter means there's way less tire absorbing the bumps in the road. Had you gone with a profile rating of 65 or higher I bet it would of been way better.
    2) Prius have always been designed to work with low rolling resistance tires and you made the common mistake of choosing tires that were designed to maximize traction in bad weather, which has a much deeper and softer tread and that's a bad tire if you want a smooth ride in the summer time. What's more, its going to cost you thousands of dollars in lost MPG over the lifespan of the tire.
    Hopefully the people you bought the tires from can at the very least confirm the install was done properly with no defects to the tires. Or at the very best let you switch to some 215/65R17 Low Rolling Resistance (LRR) tires for a minor upgrade fee or for free.
    futurist likes this.
  6. T1 Terry
    T1 Terry Active Member
    929
    491
    The lower the outside circumference, the deeper the tyre will fall into a hole rather than ride over it. That sounds like the ride you are feeling compared to the larger circumference tyres.
    as PriusCamper has posted, reducing the side wall height will also reduce the "give" available for the tyre to take up the smaller bumps, the bigger holes will take up all the "give" available in the side wall and damage both the tyre and the rim.
    Low profile small sidewall tyres are for super smooth surfaces, even the join in the concrete slab roads feel like driving over ripple strips ......
    T1 Terry
    PriusCamper likes this.
  7. Winston Smith
    387
    260
    OH
    2024 Prius
    LE AWD-e
    Strawmochi has moved from 19 inch wheels with very little sidewall to 17 inch wheels with much more sidewall.
    I believe you have something reversed.
    The 17 inch wheel with a 215/55/17 tire has more than 20mm more sidewall than a 19 wheel with a 195/50/19 tire. The stock Toyota 17 inch wheel with 195/60/17 tires will have about the same sidewall depth as 215/55/17 tires.
    That tire would have a 28 inch circumference, an inch and a half more than any of the stock wheels and tires.
    #7 Winston Smith, Aug 25, 2025
    RX808, TGTGUUD, reservoirblue and 2 others like this.
  8. PriusCamper
    12,980
    5,277
    Ok, then go with 195/65R17. I don't understand why you're putting your trust in Toyota's judgement when it comes to tire size and tire quality? The have a well established reputation for making horrible decisions about tire size and especially tire quality.
    And again if you're going to buy a tire for winter weather and complain that the ride is awful in Summer then you failed to buy the right tires, which is the point of my reply.
    As for what the very best tires are for Gen5 for best MPG and most comfortable ride, that's something worth starting a thread about. This thread is explaining why his ride got way worse and uncomfortable because he bought the wrong tires.
    Main point is lower profile tires = less comfortable ride
    and as @T1 Terry points out:
    Smaller diameter wheels = more tire going to the bottom of a pothole
    #8 PriusCamper, Aug 25, 2025
  9. Hammersmith
    Hammersmith Senior Member
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I don't think you're actually reading what the OP wrote.
    They went from a 195/50-19 to a 215/55-17. That's a 23.7% increase in sidewall height. From 3.8" to 4.7". It's even a tiny bit more than the 4.6" sidewall on the stock 17".
    And thousands of dollars in lost mpg? What are you smoking? The CC2 has one of the best rolling resistances in the all-weather category. Not as good as a dedicated economy tire, but still acceptable. The OP had the 19" wheels. That's about 48mpg/114mpge stock. A 17" CC2 is going to get about the same mpg. It's wider and has a higher RR, but it has overall lower unsprung weight because of less metal in a 17" wheel vs. the stock 19" wheel. So they're going to get about the same mpg. If they had gone with the stock 17" size wheel and tire, they'd be looking at 52mpg/127mpge. Both the CC2 and the stock Toyo are about 40k mile tires depending on conditions and driving habits. That's roughly 833 gallons of gas used for the CC2(assuming no EV mode - which is unrealistic for a Prime) vs. 770 gallons for stock 17" Toyo for a difference of roughly 65 gallons over 40k miles. If we use the MPGe numbers, it's 350gal vs. 315gal for a difference of 35gal. Maybe it's different where you live, but 35 gallons of gas does not cost a thousand dollars or more where I live.
    And if it's the difference between saving $150 in gas over five years versus thousands of dollars in repair bills(and even more in possible medical bills) if I go off the road because the stock economy tires were crap in bad conditions, I think I'm going to go with spending a little more on gas every day of the week and twice on Sundays.
    BTW, a 215/65-17 tire would be 5% larger than the stock 195/50-19 and 7% larger than the stock 17"(almost 2 full inches taller). Bet money all that extra mass would almost completely cancel out any RR gains.
    GeoJ, Quovadis007, TGTGUUD and 4 others like this.
  10. Winston Smith
    387
    260
    OH
    2024 Prius
    LE AWD-e
    My comment isn't on tire quality, but is about sidewall depth and circumference.
    The stock wheel circumference may indicate that much larger tires will be a functional problem.
    We know that decreased sidewall depth isn't the cause of Strawmochi's complaint because he didn't do that; he increased sidewall depth. We also know that trusting Toyota's judgement isn't the cause of his problem since he moved from stock 19 inch tires to a 17 inch tire Toyota doesn't provide stock.
    My experience with CrossClimates disclosed no peculiar ride problems in warm weather, but the formula for that tire could have changed.
    strawmochi likes this.
  11. Hammersmith
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    What 195/65-17? No such tire exists.
    strawmochi and otatrant like this.
  12. Hammersmith
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Correct. The CC family is not a winter tire. It's an all-weather tire. It gives you about 90-95% of the performance of an all-season tire in the spring/summer/fall and about 90% of the performance of a dedicated snow tire in the winter. It's the perfect choice for a driver that occasionally needs snow/ice performance(say they live in a temperate valley but sometimes drive into the mountains for skiing) or they need good(but not great) winter performance every year but don't put on enough miles to justify two sets of tires.
  13. PriusCamper
    12,980
    5,277
    I was just throwing that out there to make the point that there's other tire sizes to learn about and Toyota doesn't know jack about what the best tire is for each specific customer's needs.
    Clearly my recommendation was to use 215/65R17 Low Rolling Resistance (LRR) tires and I confirmed before I posted that recommendation that they're readily available from many manufacturers.
  14. Winston Smith
    387
    260
    OH
    2024 Prius
    LE AWD-e
    Strawmochi isn't complaining about a Toyota supplied tire.
  15. Winston Smith
    387
    260
    OH
    2024 Prius
    LE AWD-e
    I bought them when because I hate hydroplaning and trying to predict when it will stay warm or cold in my region.
    My two gripes were a high pitched whine they produced and the set not making it to 20,000 miles. I do like lateral Gs, but that's much less durability than I anticipated.
  16. PriusCamper
    12,980
    5,277
    So somebody goes with a two inch smaller diameter wheel and you're really going to argue the sidewall height increased? It's a two inch smaller wheel and that means there's way less tire to cushion the bumps and potholes in the road. It's absurd to say that a slight increase in sidewall height is going to compensate for two inches less diameter of the wheel.
    More to the point, PriusChat and Prius owners have historically been frugal folks and we've spent decades on here discussing which tires and wheels get the very best MPG...
    But now because Gen5 doesn't look ugly and costs a fortune we have this forum of wealthy people who are not frugal, not like historic Prius owners at all. I've never seen any substantive discussion in the Gen5 forum about max mpg options because the owners of Gen5 are too affluent to care about how much gas costs and in 4-5 years when gen5 owners spend another fortune on the next over-priced brand new car regular frugal Prius owners will finally start buying used Gen5 for cheap and we can finally have an intelligent discussion about high mpg tires instead of all this nonsense.
  17. PriusCamper
    12,980
    5,277
    Lol... Way to conflate one persons post with someone else's. Why so petty about the discussion? Seriously, Gen5 owners are so presumptuous and rude.
  18. PriusCamper
    12,980
    5,277
    Meanwhile I've been on here for 12 years talking about how I'm pumping inexpensive LRR tires up to mid-40's in PSI and getting 60K miles out of the tread.
    Did you ever consider that you're getting scammed out of your tires lifespan because the tire store can tell you're wealthy enough and gullible enough to buy whatever is most profitable to them? That's what it seems like to me!
  19. Gokhan
    Gokhan Senior Member
    6,468
    2,582
    Paramount CA
    It is likely the aftermarket tires. With the Prius, I wouldn’t stray from the OEM low rolling resistance (LRR) tires.
    I rode a 2021 Prius Limited Uber a few days ago, and the road noise was unbearable. I am guessing the aftermarket tires were the problem.
  20. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    What are you talking about?
    Yes, the wheel diameter is 2 inches smaller in diameter, but the overall diameter/circumference of the tire stays the same (or very close) because you mount tires with taller sidewalls to compensate for the loss of wheel diameter. Therefore, there is no smaller tire falling into potholes and road imperfections.
    OP, many find new tires with fresh tread has a harsher ride, even when mounting the same manufacturer and model tire. The extra tread is heavier and stiffer than the old worn tire. Perhaps your ride will improve when your new tires have worn in a bit.
    RX808, strawmochi and otatrant like this.
