Painted my engine cover
Discussion in 'Gen 3 Prius Accessories and Modifications' started by LazuliNyx, Aug 26, 2025.
  1. LazuliNyx
    LazuliNyx Member
    60
    34
    Georgia, USA
    I decided to add a little gentle color to my engine compartment. I painted the engine cover a light metallic blue. The paint is engine paint so it will tolerate the heat and chemicals. To do under the Toyota logo, I cut the welded plastic studs on it, painted, then re-melted the studs. I feel it makes the engine compartment look a little more alive.
    PriusCamper and bisco like this.
  2. LazuliNyx
    LazuliNyx Member
    60
    34
    Georgia, USA
    I wish I could paint my inverter to match.
  3. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    Get the covers for the radiator fluid & the converter /
    Burna J likes this.
  4. LazuliNyx
    LazuliNyx Member
    60
    34
    Georgia, USA
    Oh my, didn't know this existed, going to look now. Thanks!
    Edit: Just found a reddit with part numbers. So the covers are from the ct200h? Fascinating, I could paint them. Maybe I should get them and also paint my intake?
    PriusCamper likes this.
  5. ASRDogman
    ASRDogman Senior Member
    7,529
    3,891
    It looks brand new. Nifty!
  6. Mendel Leisk
    41,260
    I’d stop. Inverter looks pristine as-is , and covers on reservoir bottles, look superfluous.
    what you’ve done so far looks good to me.
    if you have to do more, this is worthwhile imo:
    Question about underhood wiring | PriusChat
  7. LazuliNyx
    LazuliNyx Member
    60
    34
    Georgia, USA
    Thanks I’ll consider what you’re saying strongly. Also it’s a couple hundred to add the covers. Maybe I’ll polish the inverter carefully and lightly.
  8. bisco
    51,823
    great color, well done!
  9. LazuliNyx
    LazuliNyx Member
    60
    34
    Georgia, USA
    Following Mendel’s advice and not worrying about covering the inverter. Also plastic is an insulator and I wonder if it adds a couple degrees temp because some cooling always happens from heat rising. I sis take out the air intake and clean and spray it with silicon to restore the plastic. And other black plastic around the engine compartment. Looks cleaner and newer. More pristine.
  10. Mendel Leisk
    41,260
