Painted my engine cover
Discussion in 'Gen 3 Prius Accessories and Modifications' started by LazuliNyx, Aug 26, 2025 at 9:42 AM.
  1. LazuliNyx
    LazuliNyx Junior Member
    31
    Georgia, USA
    I decided to add a little gentle color to my engine compartment. I painted the engine cover a light metallic blue. The paint is engine paint so it will tolerate the heat and chemicals. To do under the Toyota logo, I cut the welded plastic studs on it, painted, then re-melted the studs. I feel it makes the engine compartment look a little more alive.
  2. LazuliNyx
    31
    Georgia, USA
    I wish I could paint my inverter to match.
  3. StarCaller
    StarCaller Senior Member
    1,273
    723
    Cedar Crest, NM, USA
    Get the covers for the radiator fluid & the converter /
  4. LazuliNyx
    31
    Georgia, USA
    Oh my, didn't know this existed, going to look now. Thanks!
    Edit: Just found a reddit with part numbers. So the covers are from the ct200h? Fascinating, I could paint them. Maybe I should get them and also paint my intake?
  5. ASRDogman
    ASRDogman Senior Member
    7,345
    3,833
    It looks brand new. Nifty!
  6. Mendel Leisk
    40,805
    I’d stop. Inverter looks pristine as-is , and covers on reservoir bottles, look superfluous.
    what you’ve done so far looks good to me.
    if you have to do more, this is worthwhile imo:
    Question about underhood wiring | PriusChat
  7. LazuliNyx
    31
    Georgia, USA
    Thanks I’ll consider what you’re saying strongly. Also it’s a couple hundred to add the covers. Maybe I’ll polish the inverter carefully and lightly.
