Musty smell will not go away in my used Prius
Discussion in 'Gen 3 Prius Main Forum' started by sanshan, Aug 25, 2025.
  1. sanshan
    sanshan New Member
    Los Angeles
    2014 Prius v wagon
    Hello, everyone. Two months ago I bought a used 2014 Prius from an older couple in New Mexico. But ever since I bought it, there has been this persistent odor in the car. Like a slightly musty carpet with a deteriorating adhesive/vinyl plastic/rubber smell. It is quite hard to describe. I was thinking it could be mildew in the seats, floor liner, or headliner, but I’m not sure. Doesn’t really smell like it. The car sat around a bit, but it was still driven ~5k miles annually in the last few years. It’s not completely overpowering or anything, but I would still like to have a neutral-smelling interior because otherwise the car is in excellent condition and has been very well taken care of.
    So far I have tried:
    • Replacing the cabin air filter. Big improvement as it was very musty and due for a change.
    • Using the Toyota AC system refresh foam & spray. Just masked the smell.
    • Spray with carpet cleaner solution and vacuum it up. Some improvement, but the smell eventually came back within a week.
    • Spray with Tuff Stuff, scrub, then vacuum. Same result as above.
    • Run ozone machine for 2 hrs. Zero effect.
    • Remove the rubber floor mats and carpet from the car for a week and clean them. No effect, was still as strong as with them in the car.
    • Remove the dash cover that was installed and scrape the adhesive off the dash. Mild effect? Hard to say.
    • Leave the windows cracked for the past few weeks.
    • Run my air purifier overnight twice with a carbon odor absorber. Very little effect. Still obvious when you get into the car the next morning.
    I’m running out of ideas. My plan is to just keep using carpet cleaning solution and wet vacuuming it every 2 weeks until the smell is minimized. I’m very certain the smell isn’t from the AC system. Despite all the things I listed above, the smell is 70% as strong as when I got it. I’m looking for any ideas and would appreciate any advice from you fine folks. Cheers.
    52,211
    congrats and welcome!
    only other thing i can think of is the hybrid battery vent tubes. they were a big problem in some gen 2's, but idk about gen 3.
    all the best!
  3. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Run an ozone generator the car, it will kill any living organisms that’s producing foul smell.
    97trophy likes this.
  4. Mendel Leisk
    41,771
    My usual suspect would be the AC evaporator (the AC radiator in the dash): in operation it’s cold, humidity in the incoming the air condenses on it, and if it lingers can start growing stuff. Toyota sells a kit that may help. Preventative measure is to use AC sparingly, and turn off a mile or more before destination, but continue to run fan. A pain, but works.
    douglasjre likes this.
  5. BiomedO1
    3,962
    2,089
    SacTown, Ca
    IMHO; you need to track down the source of the odor to eliminate it. Everything your doing above will only mask the problem for a short time.
    The most likely culprit is the HVAC system, mold in the cooling/heating coils or the car has been in a flood. A previous flood car will have mold spores in the carpet and seat, depending on how high into the interior the water got. Also check if the floor board plugs are in place and all door seals are doing it's job. The rear hatch seal can drip water into the trunk area unnoticed too.
    Hope this helps.....
    Merkey likes this.
  6. ETC(SS)
    7,287
    It's a hatchback.
    Have you checked the other end of the car?
    Merkey and xw20_driver like this.
  7. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    I had a similar problem on a 2013 Prius, I couldn't get rid of the smell in the car. The previous owner had a wet floor under the carpeting. I washed the carpet and the floor, but the smell remained, even when there was no carpet in the car. I tried to wash the floor a few more times, but the smell wouldn't go away. It was disappearing when it was freezing outside, but was returning when the car was heating up. The smell was coming from the noise insulation on the floor. It is a soft material that absorbs very well, but which is very difficult to wash. I soaked it with all purpose cleaner overnight, then cleansed it with water and dried it with a heat gun until the bubbles stopped coming out of it. After all of this I painted it with a primer. Only after this the smell did practically disappear.
    The same material is used under the spare tire in the trunk.
    https://attachments.priuschat.com/attachment-files/2015/04/73688_image.jpg
  8. ASRDogman
    ASRDogman Senior Member
    7,722
    3,960
    You should use white vinegar to clean it. You'll have to pull the whole rug out,
    turn it over, and pour a 50/50 mix of water and vinegar on it and let it soak for a while.
    Then hose it off.
    But finding out WHERE the smell is coming from in important. You need to go to the source.
    Grit likes this.
  9. bisco
    52,211
    your turn :)
    Grit likes this.
  10. Paul Gregory
    Paul Gregory Senior Member
    2,203
    581
    Alberta
    2024 Prius Prime
    XSE
    I'd be careful with that. The ozone can be quite destructive on materials in the car. At least that happened to me. I'd rather try to spray bleach into where the mildew or whatever organism is causing the smell.
    I don't see anything specifically designed for that purpose, but you might be able to make something with a pump, some tubing and a spray nozzle, to poke deep into the vents.
  11. ASRDogman
    7,722
    3,960
    Bleach is extremely destructive, and it really won't get rid of it.The white vinegar will.
    Grit likes this.
  12. Paul Gregory
    2,203
    581
    Alberta
    2024 Prius Prime
    XSE
    Oh sure, I love the smell of vinegar. A weak bleach solution smell will be gone in a day.
  13. ASRDogman
    7,722
    3,960
    The vinegar will KILL the mold, the bleach won't.
    The vinegar smell will be gone in a day....
    And you're suppose to rinse it also.
    Your nose...
  14. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    I run ozone gen quarterly on the pleather trim 4 since purchase. I do use leather clean and conditioner quarterly also because I’ve seen pleather gone bad from test driving many use Prius before buying mine.
  15. bisco
    52,211
    can these ozone generators fix the hole in the roof?
  16. Paul Gregory
    2,203
    581
    Alberta
    2024 Prius Prime
    XSE
    I had one that stayed plugged into the lighter socket in my car. It eventually corroded any exposed metal. I suppose it's not the best thing for your health.
  17. sanshan
    sanshan New Member
    Los Angeles
    2014 Prius v wagon
    Hi everyone, thanks for the suggestions. Apologies for my late reply. The smell was more apparent in the trunk of the car, so I took out the cargo mat again, as well as the spare wheel cover and washed both of them. I initially only washed the cargo mat. That seems to have taken care of it for now (or at least until the soap smell goes away), maybe some water got on it and mildew grew. We'll see.
    Thanks for the input, I'm thinking that is probably my next step if my wash didn't work. I initially suspected it could be some water in the spare wheel area as I had another gen3 that I bought and it had ~100ml of water just sloshing around in there. Amazingly the rest of the cargo area was dry, don't know if its a common problem on this gen.. I didn't see any water in this car, just a bit of rust under the spare tire so I assume water was there at some point.
  18. ASRDogman
    7,722
    3,960
    The trunk has a leak, the tail lights tend to leak.
    You need to check it all.
  19. Rugged_Rowan
    Rugged_Rowan New Member
    Southeast
    2025 Prius
    I originally picked up a used 19' prius from carmax earlier this year, I had it for about 2 months and it had a dog smell that I tried everything to get rid of, and it still was in there. I ended up trading it in for 5th gen and could never been any happier. Nothing beats a brand new car smell LOL.
  20. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Quick fix without no budget limits are the best!!!
