2014 Tire Pressure Light won't go off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by terobers, Aug 27, 2025 at 6:36 AM.
  1. terobers
    terobers Junior Member
    Light went on. Inflated tires. Light won't go off. Help?
  2. ChapmanF
    17,617
    Does it come right on solid and stay solid as soon as you turn the car on?
    Or does it come on blinking, blink for a minute, and then go solid?
    Once you've got that answer, you can search here for existing posts that tell you the two different meanings.
    Brian1954 likes this.
  3. Grit
    Grit Senior Member
    6,525
    4,214
    Wilkes Land
    Press and hold the Tpms button until
    It still stops blinking. If
    It doesn’t stop blinking after wards, the battery in one or more the tires has ran out. Mine had ran out years ago, my car thinks I have a flat for more than 3 years!!!
