2010 Orange Triangle "Check Hybrid System"
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by fettuccine, Aug 27, 2025.
  1. fettuccine
    fettuccine New Member
    IL
    Hello :')
    Today on the way to work I had my check engine light & Orange Triangle come on with the "Check Hybrid System" warning appear. I stopped and looked it up and said it was safe to finish the 5 minutes left on my drive to work. I live 15 minutes away from work and the light was still on on my way back home. About 12 minutes in and the power steering light came on and engine shut off. I panicked and since I was only 3 more minutes away from home I turned the car off and on again and it went back to how it was, about a minute later happened again so i turned off and on then successfully made it home.
    I have a 2010 Prius Gen 3 with about 130K Miles on it. This car has been nothing but hell and problems for me and I don't know what to do. I am a college student and cant afford a incredibly expensive fix again. Is it safe to drive 10 minutes to my nearby Toyota dealership for them to look at it? I dont know what to do if it keeps shutting off and if it severely damages it every time. Any help or advice would be extremely appreciated!!!!
  2. Brian1954
    Brian1954 Senior Member
    2,165
    842
    South Central PA, USA
    The dealership will connect a scanner to the car and check for trouble codes. If you do not have any warning lights on the dashboard when you take it to the dealership, they probably will not find and codes, and you will be charged ~$185 for the scan.
    Tomorrow morning when the car is cold, try starting the car and see if you have any warning lights. If you do not have any warning lights, definitely do not take it to the dealership. If you do have warning lights, take it first to an auto parts store (Auto Zone, Advanced Auto, etc) for a free scan to check for the trouble codes and then post them here in this thread.
    It sounds like you have had other problems with your car. Can you please describe what those were? The present problem may be related to the past problems.
    fettuccine likes this.
  3. Tombukt2
    12,908
    2,318
    Technalogia.... no good for college
  4. fettuccine
    IL
    Hey! thank you so much for your reply :) Started the card cold this morning - same lights as before (engine & check hybrid system with triangle). I got the obd2 reader and the codes I got were
    P261B - "manufacturer control"
    P0300 Random/multiple cylinder misfire detected
    P0302 Cylinder 2 misfire detected
    P0304 Cylinder 4 Misfire Detected
    and another P261B Manufacturer Control
    Whats happened with my car in the past:
    I bought the car in July 2022 and September 2022 the hybrid battery went out so my mechanic sent the battery to have all worn down cells replaced/fixed. The battery has been fine since and I've noticed no problems. At this same time I also had the 12 v replaced. Within a year of this happenening i began to have problems with the car rattling at the start as I've see others have called the "death rattle" and the codes for cylinder misfire. My mechanic who is the only prius specialist within an hour from me had tried everything. Checked head gasket, replaced spark plugs, cleaned the egr, washed out all the coolant, rerouted my ac/heat? or something like that. Everything. Its been so expensive and a huge headache. He decided to just let it be and told me to keep driving like normal until it breaks completely then itll show what it is. Well, its been about 2 years now and the rattling happens at start of vehicle sometimes but not all but other than that its been fine until this moment.
    So with that being said seeing the cylinder misfire codes has been normal for me bit the manufacturer ones are new. Thank you so much again for all the help and advice. I dont have anyone I can ask about these problems so this is all very very helpful.
  5. Brian1954
    2,165
    842
    The description for code P261B is "Coolant Pump "B" Control Malfunction." This is for the engine water pump. This code is activated by the ECM (engine control module) when the water pump is rotating slower than 900 rpm when it should be rotating much faster than that. The water pump normally rotates at 2600 rpm or higher when the engine is running.
    When this code is active and the engine coolant temperature goes higher than a certain temperature (I can't remember the exact temperature at this moment), the ECM will shut down the engine to protect it from overheating. The coolant temperature that this happens at is lower than the 248F, which turns on the high coolant temperature warning light on the dashboard. So, when this code is present, you have no indication why the engine shuts down, but it is happening to protect the engine from overheating. This is exactly like what you described in your original post.
    In most cases, when you have the P261B code, the engine water pump needs to be replaced.
    What is the level of the engine coolant in the plastic reservoir located near the right front wheel? If it is below the minimum level line on the reservoir, you should add coolant.
    The Gen 3 engine has a history of head gasket problems happening from 150k to 210k miles. The engine cold start misfires (rattling) is the first indication of engine coolant leaking past the head gasket into cylinder #1 or #2. How has the engine coolant level been during the last two years? Have you needed to add coolant? Your mileage of 130k is lowered that when you normally see the head gasket failures. You can do a search on this Gen 3 forum for a huge amount of information about the failing head gasket in these engines.
    Edit: As an experiment, when you are done driving your car for the day, open the hood of the car and slowly loosen the plastic cap on the engine coolant reservoir. Use a large rag so you do not burn yourself. The next morning, before you start the car, tighten the cap again. This should reduce the cold start misfires if the misfires are due to a failing head gasket.
    #5 Brian1954, Aug 28, 2025
  6. fettuccine
    IL
    Yes! My car just drinks coolant, I have to refill it about once a month and it will go through an entire fill in about 2-3 months. I dont drive much either, to and from work each day 15 min drive and then sometimes an hour to my familys. This has been going on for about two years since the rattling has started. I foresee a complete head gasket failure in the future- but I am not sure.
    I owe 3440$ on my car and pay $350 a month. Since owning this car for 3 years Ive maybe spent about $3-4000 in repairs. I wanted this car to last at least 2 more years till I can finish school but I am panicking at the state it is in right now. Is it worth it to get the pump replaced knowing the head gasket may need to be replaced soon anyways? Both very, very expensive repairs- head gasket is my worst nightmare. It feels like each time im getting it repaired i hear "this will be the last thing then the prius will run great forever!" until it needs a major repair soon after. All the repairs seem to center around this rattling noise no one could tackle. I LOVE my prius when it works but wow it has sucked the soul out of me.
  7. bisco
    51,851
    i'm sure finances are tough, but if you can swing it, i'd try to make a trade with someone like carvana.
    maybe they can roll up the monthly payment. don't buy another hybrid.
  8. ASRDogman
    ASRDogman Senior Member
    7,549
    3,897
    Replacing the coolant pump won't resolve your issues.It's likely bad and needs to be replaced, but if you don't repair the head gasket, it's just going to get worse, and you risk bending a rod or throwing a rod out the side of the block then you need a whole new engine.
  9. Brian1954
    2,165
    842
    Well, your mechanic did not try replacing the head gasket, which would have fixed the engine misfires (rattling).
  10. ChapmanF
    18,094
    The coolant isn't supposed to go anywhere. The gasket's job is to keep the coolant in. If the coolant hasn't been staying in for about two years, gasket failure isn't a future event. It's an event about two years in the past.
  11. Brian1954
    2,165
    842
    The head gasket in your car was failing two years ago when the car had the first cold startup misfires. To minimize the misfires on startup, you can release the pressure in the coolant system when you are done driving the car for the day. Doing this will help extend the life of the engine.
    If you want to drive the car, yes, you need to replace the water pump. If you do not change the pump, the ECM will shut down the engine when the engine coolant reaches a certain temperature, leaving you stranded along the road like you report in your original post.
    You can continue delaying the head gasket replacement like you have been doing the past two years by only taking short trips with the car. Start releasing the pressure in the cooling system when you are done using the car each day. This will help make the engine last longer.
    Your situation is exactly why it is not advisable to buy a used Gen 3 Prius. We see people on the forum seeking advice about buying a Gen 3, and most people advise buying a Gen 2 or a Gen 4.
    Bite the bullet and replace the water pump yourself or have someone else replace it for you OR sell the car as is to someone.
    #11 Brian1954, Aug 29, 2025
  12. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    You forgot to include dump stop leak into the system then sell it!
    Mendel Leisk and ASRDogman like this.
  13. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Hope the engine doesn’t throw a rod as your on the highway with cars behind you. Prayers and wishes.
  14. fettuccine
    IL
    It has been awhile but i am back with updates :)
    I took prius into dealership and to a local mechanic to get looked at. Both said engine absolutely needs to be replaced. We found a low mileage 2018 prius engine for $1,800 im wanting to replace it with. Dealership quoted $3000 to replace if i bring my engine and mechanic did about $2,500-3k. My younger brother is currently taking mechanic classes and him and my dad offered to try to replace the engine themselves. Theres a lot of in depth tutorials/videos online for how to do but Im wondering if this would be a dumb idea to let them try. They have worked on their own Toyota vehicles in past but never a full engine replacement. We would need to buy the materials to move the engine and such but wondering if its worth it to do the DIY ourselves or keep shopping around for another mechanic. I did find a reddit post of a traveling prius engine replacement mechanic with many good reviews who looks like he could maybe do it for 1.5k with travel to my area.
    Also to note, i havent been driving at all other than the 10 min to get the quotes its just been sitting in my driveway while ive been borrowing roommates cars but that blessing is ending soonish.
  15. DirkAshburn
    DirkAshburn Member
    143
    58
    Virginia
    Personally, I'd junk it. Take the loss, get something else. It's a headache you don't need while trying to finish school. Check Alamo/Hertz/etc car sales and see if you can find a good deal to save a few bucks that way. I have several friends that bought that way years ago and have had no issues.
  16. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    If a 2018 Prius engine gets installed on turd gen, a lot of us will be clamoring to do it also.
