In a pickle with a Prius!
Discussion in 'Gen 2 Prius Technical Discussion' started by PartlyEVDave, Aug 28, 2025.
  1. PartlyEVDave
    PartlyEVDave New Member
    Vernon, BC, Canada
    Hello all; I’m just new here.
    We have an ’09 Prius base model; it went about 380,000 kms. and the HV battery has packed it in.
    Sorry to say, I set it aside and it’s been sitting for a year.
    Time now to fix it. Accessed and tested the battery modules, and found half (14!; all adjacent) looking good at right around 7.2v., but the other half are pretty dead with only a few volts or less.
    For a one-off fix, it doesn’t seem worth buying the deep-cycling and testing equipment, but if someone nearby has and would rent it to me, I’d be happy to rebuild the pack with good used modules.
    Otherwise, I’m looking at buying a “reconditioned” and balanced pack (2 year warranty option) from Greentec in Coquitlam BC (Vancouver; we’re in Vernon in southern central BC); the word seems that they’re reputable.
    They charge a core charge of $150.00 CAD, and the return shipping costs $100.00! That means it’d only cost me $50.00 + 12% taxes to keep the old pack.
    If I don’t find access to the equipment, then I’ll either return the core, or sell or give it away.
    Anybody reasonably local to get involved here??
    I’m interested to hear any comments and ideas about what I’m doing; please and thanks!!
    Thanks!!
    Dave
    51,851
    welcome!
    if you click the report button at the bottom of your post, you can ask the mod to change the title.
    maybe something like, 'need help with battery rebuilding' and perhaps mention your geographic area.
    all the best!
  3. PartlyEVDave
    Vernon, BC, Canada
    Thanks, Bisco.
    You’re right; I know I have a problem with TMI; I’d probably get more and better results with brevity and KISS.
  4. Mendel Leisk
    41,340
    Maybe say “Vernon” in your avatar too, versus “Spalumcheen”, which will have everyone heading for Google maps. I’m (coincidentally) in Coquitlam, but “Greater Vancouver” seemed less bewildering.
    Greentec is essentially a US company if I’m not mistaken, and someone’s set up a franchise here. Relatively local location aside, these are refurbs, I’d be a little wary. Google reviews of this location are very positive, though.
  5. Paul Gregory
    Paul Gregory Senior Member
    2,130
    556
    Alberta
    2024 Prius Prime
    XSE
    I hope you bought it with the cost of a new battery pack factored into the price.
  6. PartlyEVDave
    Vernon, BC, Canada
    “Bought it”, you mean the car?
    Yes; we’ve had the car for about 10 years and ~185,000 kms. It’s been an excellent, reliable car.
    but it does drink oil. A bad habit, but livable.
    Our daughter talked of getting a bumper sticker: “This car’s a hybrid; it burns gas and oil!”
    New rings & valve stem seals, or an engine, would help. If the engine were better, I’d consider a new HV battery. The body is amazingly rust-free and solid, and the rest of the car is fine.
    #6 PartlyEVDave, Aug 29, 2025
    bisco and ColoradoBoo like this.
  7. Mendel Leisk
    41,340
    What’s the oil consumption rate?
    my mistake, applicable to gen 3, not your gen 2:
    it’s typically the rings/pistons, and there are revised versions. Also consider a new short block.
    #7 Mendel Leisk, Aug 29, 2025
  8. bisco
    51,851
    at 380,000 km, i'd say you have gotten good value out of it, whatever you choose to do
  9. PriusTech
    PriusTech Active Member
    247
    105
    Reno
    Next oil change put a bottle of Seafoam and 1/2 qt of generic ATF. Your oil control rings could be gummed up with carbon and this will clean them.
  10. Brian1954
    Brian1954 Senior Member
    2,165
    842
    South Central PA, USA
    You must be thinking of Gen 3 engines that have the low tension piston rings. The OP'S car is a Gen 2.
    #10 Brian1954, Aug 29, 2025
  11. PartlyEVDave
    Vernon, BC, Canada
    The car uses a litre to a litre and a half for every tank of fuel; the worse figure on a harder, highway run.
    Good idea to do the internal engine cleansing; I will do that.
    Mendel, indeed Greentec is US-based, and that’s the biggest stumbling block about buying from them. Otherwise, as you’ve noted, they appear to be good to deal with. And wary indeed; buying anything “refurbished”, from them or anyone, is simply them putting together a battery pack of used, deep-cycled, tested, and balanced modules. Packs assembled with “ok” modules get a one year warranty; good modules get a two year warranty.
    Paul, Mendel, Bisco, PriusTech; thank you all for your support, comments, and suggestions!
  12. PriusTech
    247
    105
    Reno
    It's not as frequent but the 2nd gen rings can get carboned up, usually from short trip driving
    Brian1954 likes this.
  13. Mendel Leisk
    41,340
    Oh heck, yes.
  14. PartlyEVDave
    Vernon, BC, Canada
    2009 Gen 2: I feel sure that I ran across a procedure to command-run the HV battery cooling fan without using a scanner, but now that I want to, I can’t find that information again.
    I have cleaned everything and bench-tested the fan motor (it’s good), and now I just want to know that the circuit works.
    Does anyone know of a procedure to get the car to test-run the fan motor without a scanner?
