One of my Prius won't start the engine....
Discussion in 'Gen 2 Prius Main Forum' started by priuslyfe, Aug 29, 2025.
  1. priuslyfe
    priuslyfe Member
    233
    57
    Basically I've let this Prius sit in the yard for quite a while without starting at all, maybe 3 months. There is about 1/2 tank of gas and all the lights come on but the engine won't turn over. Is it the HV battery? The 12V is in good condition. I thought as long as the 12V is in good shape the car will start?
    I just need to move this car to another place in my yard.
    Thoughts appreciated.
    HV battery showing no bars of life....
  2. Tombukt2
    12,908
    2,318
    Are the relays clicking in the rear and staying open when you boot the car with foot on brake??
    priuslyfe likes this.
  3. priuslyfe
    priuslyfe Member
    233
    57
    UPDATE:
    First I checked the codes with the Autel 2000 reader. Got no codes all passed. Left the car on for a little bit and now checked again....only two codes came up...
    1. hybrid P0A80
    2. hybrid P3000
    "The P0A80 code is a generic code that indicates a problem in the hybrid battery system. More specifically, it means that the battery pack has failed to charge or maintain a charge. This can be caused by a variety of issues, such as a faulty battery pack, a malfunctioning charging system, or a problem with the control module.
    The P3000 code is a manufacturer-specific code that is related to the P0A80 code. It indicates that there is a problem with the hybrid battery system, but provides more detailed information about the specific issue. Unfortunately, the meaning of this code can vary depending on the make and model of your Prius."
    So these are Hybrid battery codes but is it IMMEDIATELY fixable to even move the car in drive 50ft?
  4. Brian1954
    Brian1954 Senior Member
    2,165
    842
    South Central PA, USA
    Does the car go into "Ready"?
    Did you have the orange safety plug removed from the hybrid battery?
    What is the voltage of the 12v battery?
    You need the 12v battery to power up all the ECUs in the car for the car to go into Ready mode, and you need a certain amount of charge in the hybrid battery to start the engine.
  5. priuslyfe
    priuslyfe Member
    233
    57
    Car goes into "ready" mode but then nothing else happens....usually in my other Prius the engine kicks on when you give it gas. nothing is working. I'm not sure about the 12V battery's voltage but it powers-up my other Prius so i assume its good (enough).
    Again, if the car powers up via the 12V the engine SHOULD start even if the HV battery is not good, right?
  6. Brian1954
    2,165
    842
    NO, the hybrid battery needs a certain amount of charge to be able to start the engine.
    Use your Autel scan tool to read the voltage of the hybrid battery.
  7. priuslyfe
    priuslyfe Member
    233
    57
    DAMN! I assume its too low. is there anyway to charge it some degree (using a plug in charger maybe?)
  8. Brian1954
    2,165
    842
    You first need to use your Autel or open the battery and use a meter to measure the voltage of the hybrid battery to determine what the next step is.
  9. PriusCamper
    PriusCamper Senior Member
    12,710
    5,136
    Pacific Northwest, USA
    When an older hybrid car sits for months the NiMH cells in the hyrbid battery pack self discharge and because the cells are older they tend to discharge at different rates so your pack is no longer balanced and has a low charge, aka: P3000.
    So what you're in need of is a charging and balancing of your hyrbid pack. Maxx Volts and www.hybridautomotive.com sell commercial products but they're overpriced. So instead you can something with this type of specs for a much lower price and it has many more uses: www.alibaba.com/product-detail/KUAIQU-SPPS-D3001-232-300V-1A_1601010961235.html and follow the instructions on the hybrid automotive site .
    You'll also want to send 12v power to the battery cooling fan because keeping the battery pack cool while charging and balancing is essential.
  10. Hayslayer
    Hayslayer Active Member
    390
    219
    If you disconnect the 12v from the car, it will reset all the ecus, clearing all DTCs and putting them to default values, including telling the car the HV battery is at about 60% SOC. Usually, this is enough to get one or two start attempts, but obviously you're using a relatively depleted HV battery, so if it doesn't start, the battery is really drained now.
    If the battery is in very rough condition, the ecu may recognize it has a problem before the start cycle can occur and then you're just SOL until you can get a charge on it.
  11. priuslyfe
    priuslyfe Member
    233
    57
    thank you but I've tried that. I read that unplugging the HV and then plugging it back in might temporarily fix it as well. I just need to move it to another place in my backyard but its not critical that it be moved.
  12. bisco
    51,851
    if it makes 'ready', you can put it in neutral and push it.
    Brian1954 likes this.
  13. ChapmanF
    18,094
    For that matter, you can go plain IG-ON (two button presses, no brake), then press the brake and shift to neutral and push it. There is no need for the hybrid system to operate for shifting to neutral.
  14. Tombukt2
    12,908
    2,318
    P 3000 you need sub code like 384 or such ?
  15. priuslyfe
    priuslyfe Member
    233
    57
    UPDATE:
    Went out at 11pm and put in neutral and pushed it. Its out of the way but not sure what to do next. I ALSO have a spare HV battery that I pulled from my wrecked Prius but thats been idle for 4 years. Is it possible that it might work better than the current HV battery? so I might forgo the charging and such? When i was in an accident (not my fault) the battery was fully-charged (aka in the blue bar zone).
    That might be a better temporary option until I get to assess the current HV battery at least.
  16. dolj
    dolj Senior Member
    8,434
    4,285
    Wellington, New Zealand
    It is not likely, but one way you can know for sure is to measure the voltage with a voltmeter. If it is 202 V or more (210+ V would be better), you're in luck. Otherwise, you need to invest in charging and possibly discharging equipment to progress.
  17. priuslyfe
    priuslyfe Member
    233
    57
    On smaller devices I often remove the batteries when not in use and can use them later. I was wondering if you pull a HV battery out of a car while it is still fully-charged and set it on a bench, does it lose charge slowly the same as in the car OR does it relatively keep its charge?
  18. dolj
    dolj Senior Member
    8,434
    4,285
    Removing the hybrid vehicle (HV) battery from the car will not serve any useful purpose in terms of slowing self-discharge because the HV battery is mechanically isolated from the rest of the car by way of the relays.
    The rate of self-discharge will depend on the age and condition of the battery. Probably the most reliable way to ascertain the self-discharge rate would be to measure it.
  19. Tombukt2
    12,908
    2,318
    just sits they're in the place ya put it. Hot or cold . No connection . Volts amps no move it. tecnologia
  20. ChapmanF
    18,094
    While it's sitting there, it self-discharges, at some rate over time.
    The owners' manual provides:
    ... (traction battery), the battery does not need to be charged from an
    outside source. However, if the vehicle is left parked for a long time the
    hybrid battery will slowly discharge. For this reason, be sure to drive the
    vehicle at least once every several months for at least 30 minutes or 10
    miles (16 km).​
    (cribbed from a 2010 owners' manual, gen 2 probably has similar wording.)
    That's harder to do if the battery is out of the car. (On the other hand, that can simplify access for recharging it if you have suitable equipment and it's needed.)
