Can you connect a high voltage amplifier to the hybrid battery?
Discussion in 'Gen 3 Prius Audio and Electronics' started by zoeboi954, Aug 28, 2025 at 1:57 PM.
  1. zoeboi954
    zoeboi954 Junior Member
    82
    22
    What will happen if you connect a high voltage amplifier to the hv hybrid battery? Will it throw error codes. Amplifiers like stetsom high force 40k or taramp high voltage 80k... will it work fine or will it strain the battery too much
    #1 zoeboi954, Aug 28, 2025 at 1:57 PM
    51,370
    only if you want to see magic smoke...
  3. zoeboi954
    82
    22
    From the amplifier or the battery?... ive seen this was successfully done in a fiat that has a high voltage battery. Just curious about the prius
  4. ChapmanF
    17,628
    Can you supply us with the input power specs for those amps?
    We could probably all duplicate the work of googling it, but as it's your question, after all....
    douglasjre likes this.
  5. zoeboi954
    82
    22
    For my subwoofers application I need 16,000 watts so if i went with a taramp hv40.000
    Its voltage range is 140 - 275vdc
    Its idle consumption is 110mA
    Max musical consumption @0.5 Ohm is 91.5A
    Max sinusoidal consumption @0.5 Ohm (100Hz) is 183A
    Input impedance Is 27K Ohms
    My subwoofers will be wire down to 1 Ohm so my demand from the amp will be less
  6. ChapmanF
    17,628
    If the application is something like: the Prius is a rolling amplifier that you bring to a venue for a gig and park and attach to speakers ...
    The max musical consumption of 91.5 A is within the fuse rating of the battery. It would fully discharge the battery in a few minutes, so the car would have to be in READY mode to keep it charged.
    91.5 A at nominal 201.6 V is about 18 kW.
    The car's powertrain can easily produce 18 kW, but it won't when it's just sitting parked and READY. A gen 3 liftback will generate about 3 kW in that condition (as determined by Randy Bryan, who has offered high-input-voltage inverters for using a Prius to supply home loads).
    By holding the brake and go pedal, you can force a charge mode that may produce more than 3 kW.
    You would want an OBD-II device to monitor the MG and electronics and battery temperatures, at least at first.
    douglasjre and zoeboi954 like this.
  7. Grit
    Grit Senior Member
    6,535
    4,218
    Wilkes Land
    Hate to ask a question that was an original question on your post but how many drivers and size of
    subwoofer box can you possibly fit in a turd gen Prius that will take up 40,000 watts? I have a 5 cubic Ft sub box and can only see thru the top half
    Of the hatch back window, good thing mine has a rear back up
    Cam.
    An 18” sub will need the entire hatch area to be boxed for best sound. A pair of 18s will need the backseats removed and the subs boxes will have to be built all the way to the back of the front seats.
    There’s not enough cabin space to build an effective and efficient sub box for 40,000 Watts let alone 10,000 Watts. You want a big suv to reap the best of a 40,000 watt capable amp
  8. zoeboi954
    82
    22
    Its 4 fi q 12s. yes the box is on the smaller size I cant remember the dimensions cause the box was built about 10 years. Im not going to be using the full 40,000 Watts i just want at least 16,000 the most. I used to have this setup in a different vehicle on a 15k amplifier. But in the prius there only so much you can pull from the 12v system since the car doesnt have a alternator. At one point I had 4 amps that put out 8,000 watts in total in the prius but trying to sustain them in a prius was hard. And i pick the 40,000 watt amp because I dont want the amp working max power. I prefer to get an over power amp than dial it back so its not working at max load.
    #8 zoeboi954, Aug 29, 2025 at 10:59 AM
  9. Paul Gregory
    Paul Gregory Senior Member
    1,824
    448
    Alberta
    2024 Prius Prime
    XSE
    The hybrid battery voltage is quite variable, making it more difficult to use. If this notion comes from the idea that you can produce an earth-shaking audio system from that, good luck. I don't think this is the best approach.
  10. ChapmanF
    17,628
    Post #5 provided the amp's supply voltage range, 140 - 275vdc, which I think exceeds on both ends the voltage excursions of a gen 3 HEV battery.
  11. Paul Gregory
    1,824
    448
    Alberta
    2024 Prius Prime
    XSE
    Personally, I don't see the need to tap into the hybrid battery to run a mega wall-shaker sound system, if that's what you're into. I think you could probably get enough power from the DC-DC converter; I think it puts out 100 amps.
  12. ChapmanF
    17,628
    100 amps at 12 volts is 1200 watts.
    91.5 amps at 201.6 volts is 18446 watts.
    The OP wants something closer to the second number, for some reason.
    This discussion seems that could be an appropriate amplifier capacity for a show in a venue of moderate size.
  13. Grit
    Grit Senior Member
    6,535
    4,218
    Wilkes Land
    Gotcha, use an amp but not push it to the max for sub power for optimum efficiency. There’s some people here that had used refrigerators with the hv battery directly. The fridges have a relatively constant current draw except fridge initial start up but subs have various current draw due to music peaks and silences. On paper the amp and battery should work together but keeping the hv battery above 40% SOC at all times will be my concern.
    #13 Grit, Aug 30, 2025 at 12:10 AM
