Hatchback higher lift gas struts?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by priumium, Aug 30, 2025 at 6:57 AM.
  1. priumium
    priumium New Member
    Sweden
    Upgrade
    I am apparently way too tall and have hit my head on the trunk top of my two Prius gen2 for years, so I am testing/buying 5-10cm longer struts for the trunk. 550mm/21.x inches is my first experiment.
    Naturally they cannot be to newton weak, but 400N ought to be enough me thinks?
    Any tips and/or pitfalls experienced are greatly appreciated!
    #1 priumium, Aug 30, 2025 at 6:57 AM
  2. Leadfoot J. McCoalroller
    7,955
    7,420
    Pennsylvania
    2018 Prius c
    Is there enough room (lengthwise) in the door jamb to hold a longer strut when it is closed?
    strikes me that you'd have to re-mount the door-side ball anchors. Looking forward to hearing about it though.
  3. Paul Gregory
    Paul Gregory Senior Member
    1,826
    448
    Alberta
    2024 Prius Prime
    XSE
    I believe you can order gas struts online, bespoke to stroke, lifting force etc.
    Gas spring 14-28 Stroke 500 Long - Gasspring.ca
