17" OEM RIM - 215/55 Pilot Sport 5
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Hotdog453, Aug 31, 2024.
  1. Hotdog453
    Hotdog453 Junior Member
    Ohio
    2024 Prius Prime
    XSE Premium
  2. Mendel Leisk
    41,907
    Looks like some Gen 5 17” rims, underexposed pic. You’re looking for some? Or?
  3. Hotdog453
    Ohio
    2024 Prius Prime
    XSE Premium
    The photo lost some quality I think, in uploading. I'll reupload.
    Mostly, it was for people Googling "17 inch rims 215/55/17". I expected them to look "fatter"; happily I'd say it looks fairly normal. Those are 'just' the OEM 17" rims, yeah, just a <decently wider> tire. Hard to find Google results of that.
  4. TGTGUUD
    TGTGUUD Member
    97
    73
    San Francisco
    2024 Prius
  5. cool_prius
    cool_prius Member
    106
    37
    United States
    2025 Prius
    Exactly what I was looking for. Thanks!
  6. james nicol
    james nicol New Member
    Brooklyn New York
    2025 Prius
    LE AWD-e
    safer tire size for the OEM 6.5 width wheel not so much wider but higher load range and stronger sidewall the car is not 100% about saving gas but build quality
  7. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    The overall wheel plus tire weight (unsprung) should be lower going from larger wheels to ones with a smaller diameter because air, rubber, and steel cords weigh less than solid aluminum alloy.
    Lower rotating unsprung weight is easier to accelerate, so mpg should increase, especially if you do more city driving vs interstate/highway driving.
  8. TGTGUUD
    TGTGUUD Member
    97
    73
    San Francisco
    2024 Prius
    Pilot Sport AS tires are pretty heavy and high rolling resistance.
    VelvetFoot likes this.
  9. VelvetFoot
    VelvetFoot Active Member
    1,226
    480
    New York State
    2026 Prius
    Also wondering about any mpg drop?
    2023p likes this.
