Short circuit on my rear wiper, trying first to pull out the fusei
Discussion in 'Prius c Main Forum' started by CARSFAN4, Aug 29, 2025.
  1. CARSFAN4
    CARSFAN4 Junior Member
    62
    Los Angeles
    2015 Prius c
    My 2015 prius c has a short circuit on my rear window wiper which starts working nonstop once I switch on the engine. It used to do it on and off but recently it just doesn't stop until I switch off the battery switch.
    I got only one electrician estimate of $200 just for diagnosis. It's ridiculous this rip off. So until I will troubleshoot with somebody more affordable I decided to pull out the correct fuse number.
    Can somebody tell me which fuse do I need to pull out and if there will be any side effects to consider.
    Thank you!!
  2. ChapmanF
    18,391
    Maybe you can use the Report button and ask the mod to change your thread title to something like "rear wiper always on when car is".
    "Short circuit" means a specific kind of fault (whose chief symptom is often a violently-blown fuse).
    I don't have the wiring diagram for Prius c handy. This page explains ways to get it:
    Toyota Service Information and Where To Find It | PriusChat
    CARSFAN4 likes this.
  3. CARSFAN4
    62
    Los Angeles
    2015 Prius c
    Thank you, I will search.
