Engine doesn't want to shut off sometimes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lumpy95, Sep 2, 2025.
  1. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    The last couple weeks, when I stop somewhere ( even when I put the car in the garage ) the motor just keeps running. I have waited up to 20 minutes for it to shut off before pushing the button to shut off the car and it keeps running until I shutoff the car. This is random, sometimes the car motor will shut off as it's supposed too Any idea what is keeping the motor running?
    Thanks for any responses.
    douglasjre likes this.
  2. Mendel Leisk
    41,303
    In other words, Idle-Stop is not happening? Have you by chance got the "gear" in B (instead of D)? I think that'll keep the engine running. Maybe "PWR" mode too, not sure about that.
    Also, I've noticed on really hot days, especially with a lot of low-speed tooling around, the engine will keep running, maybe some hybrid battery protocol.
    lumpy95 likes this.
  3. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    Thanks for the response Mendel.
    For sure not in "B".
    It's definitely hot here in the Mojave desert but I have never had this happen in the past hence my wondering why now.
    Before it started happening I had it in for service ( oil change, rotate tires ) and the mechanic changed the Air to Oxygen sensor but I doubt that would affect the motor not shutting off.
  4. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    Another thing I noticed is that the Hybrid battery gauge doesn't refill as fast as it used to so maybe your comment about the battery could be in play. Grasping at straws LOL.
  5. rjparker
    10,074
    6,240
    The engine will keep running in Ready IF the hv battery needs charge. Sometimes a really weak hybrid battery will not accept enough charge to let the engine shutoff at a stop.
    There is really no reason not to shutoff the engine when you park even if it's running.
    lumpy95 and Mendel Leisk like this.
  6. Mendel Leisk
    41,303
    Try Dr Hybrid, check the hybrid battery condition?
    What's the miles?
    lumpy95 likes this.
  7. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    Actually when it happened the last time the charge bars were almost to the top. I would understand if the Hybrid charge was low.
  8. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    It's just under 32,000 miles ( obviously I don't drive much lol ).
  9. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    DrHybrid???
  10. rjparker
    10,074
    6,240
    A low capacity battery is really the most common reason. Other than that the engine will run if it needs to warm up but in the summer that is usually less than a minute. If it was winter, low coolant temperature might force the engine for heat. If you put the car in maintenance / inspection mode it would run continously, but that's not easy to do by accident.
    PrimeDan likes this.
  11. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    True but that wasn't the case for me.
  12. rjparker
    10,074
    6,240
    Bars do not show capacity. Next time it happens reduce the load by turning off the ac and lights.
    #12 rjparker, Sep 2, 2025
    lumpy95 likes this.
  13. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    So your saying that the Hybrid battery may be going bad?
  14. rjparker
    10,074
    6,240
    Something is wrong with it. I would give it 98% likely. Could be corrosion on the bus bars (most old batteries have some) or a weak module(s). These battery modules are series connected. The weakest module or connection sets the bar. How many miles on the hv battery or was it already replaced with a "reconditioned" unit?
  15. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    Just under 32,000 miles so it's not the mileage. I bought it new and it's the original battery.
  16. rjparker
    10,074
    6,240
    Age and infrequent use is just as bad for a hybrid battery.
    lumpy95 likes this.
  17. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    You could be right so I guess the answer is take it in to service and bend over. Thanks for your responses.
    PrimeDan and bisco like this.
  18. PriusCamper
    PriusCamper Senior Member
    12,680
    5,118
    Pacific Northwest, USA
    Actually a brand new battery refills the slowest and a really old battery, which lacks capacity refills the fastest.
    One reason your engine would keep running would be if your battery is constantly getting drained down super low. Another reason would be if the heating or air conditioning is drawing lots of power. Lastly if your battery is fully charged it might spin the engine to dissipate the extra energy to ensure max lifespan of battery pack.
    Because you haven't mentioned anything I'd reboot all the computers to original factory settings by disconnecting the 12v battery for a few minutes. Then if the problem persists and your don't have any warning lights, I'd focus on a sensor sending bad data to the computers.
    lumpy95 likes this.
  19. Brian1954
    Brian1954 Senior Member
    2,137
    828
    South Central PA, USA
    I would not do anything until you get a trouble code.
    lumpy95 likes this.
  20. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    Thank you for the response.
    If I disconnect the 12v battery won't I have to reset everything ( windows etc. )? I don't have the knowledge to reset everything after unhooking the 12v.
    I do use Air conditioner in this heat and the battery gets low and the motor comes on to charge and the battery fills up when driving
    ( just not as fast as it used too ). All seems well except for randomly not shutting off the motor when stopping somewhere and I can see that the bars are way up on the battery ( not full but at least 3/4 full ).
