Front Brake pad replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by donzoh1, Sep 3, 2025.
  1. donzoh1
    donzoh1 Active Member
    450
    153
    Lenexa, KS
    On my 2013, I am doing front pads and rotors. I disconnected the 12v before starting. Now, I'm ready to compress the caliber pistons but wondering about what to do next. If I just compress the pistons. I will force dirty fluid back through the system which I've heard can mess up the actuator. If I open the bleed screw, air might get in and then require system bleeding, including Techstream which I dont currently have. Any suggestions are appreciated.
  2. rjparker
    10,557
    6,623
    compress them
  3. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    3rd post with the same title
  4. ChapmanF
    18,570
    Indeed, yuck.
    I start by attaching some clear tubing to the bleed screw, looped upward (over a spring coil or something nearby) and then down. I start with some brake fluid in the clear tubing, so if anything flows inward when I crack the screw open, it will be brake fluid and not air.
    Generally, there isn't much inward flow. The piston is just sitting there, then you crack the bleeder open and start pushing the piston, which makes outward flow. Then close the bleeder again before removing the compression tool.
    Mr. F and donzoh1 like this.
  5. donzoh1
    450
    153
    Lenexa, KS
    I would assume that if possible, it is best to have some pressure on the caliper as the bleed screw is cracked open. I like the idea of clear tubing with an upward loop.
  6. donzoh1
    450
    153
    Lenexa, KS
    If puston boots are in good shape, can the pistons just be pushed back in or should the boots be removed and then the pistons cleaned first?
  7. Paul Gregory
    Paul Gregory Senior Member
    2,246
    595
    Alberta
    2024 Prius Prime
    XSE
    I don't know for sure, but I think the Prius brake pads are a bit undersized compared to conventional vehicles. Owing to the fact that regenerative braking is used. I've read a few reviews descrying that Prius brakes wear out prematurely. Mine lasted 50,000 miles on my Gen 3.
    I think it has more to do with your driving style.
  8. Mendel Leisk
    41,928
    This is the one and only thread now? Appears to be.
    Your concern is debris in brake fluid being pushed back up the lines, clogging/fouling something. Myself the only time I open the bleed screws is during a brake fluid replacement. For brake pad replacement I just push the pistons back, bleed screws untouched, and never had a problem. FWIW I do a brake fluid replacement roughly tri-yearly as well. Toyota USA is silent regarding brake fluid replacement, Toyota Canada currently says every 48k kms (~30k miles) or 3 years, whichever comes first.
