Low profile tires destroyed my front end
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by IwasBirchyFirst, Sep 3, 2025.
  1. IwasBirchyFirst
    IwasBirchyFirst Junior Member
    27
    Dallas, TX
    So one of my 2010s had the low profile tire and I live in N TX, where the cement roads develop multi-inch deep potholes in a matter of days (bad soil, every house has huge cracks, curbside utility boxes look like the leaning tower of Pisa) and it takes months for the cities to repair. Normal wheels/tires survive these sharp edged monsters well enough, but those low profile tires absorb almost none of the impact and my front end is rattling greatly in just a short year. (I drive for a living).I will add, that I replace worn tires with used rubber. I get about 6 months from a $40 used tire, even driving about 30 hrs/wk, but they are always on the last 6 months of the tread.
    Just looking for validation, that others have experienced the same issue.
  2. Hayslayer
    Hayslayer Active Member
    457
    264
    If you have those driving conditions, why not install tires/rims that are more forgiving in those conditions and/or lower your tire pressures?
    I have 195/65/15 tires on my car. If I put 42/38 psi in the fronts/backs to get max MPG I feel every stone in the road. If I put 30 psi in the tires, it's like the smoothest ride ever made.
    Low profile/high pressure is a recipe for destruction.
    Grit likes this.
  3. 462disco
    462disco Junior Member
    34
    17
    Socal
    Get some stock 15's and run 205/70R15.
  4. bisco
    52,335
    yeah, those bad boys have always been on my no-no list
    #4 bisco, Sep 3, 2025
    Grit likes this.
  5. Mendel Leisk
    41,850
    You're on 215/45R17, with the stock 17" rims? What's the speed limit? Alternate route?
  6. Grit
    Grit Senior Member
    6,575
    4,228
    Wilkes Land
    If you drive for a living, why would you go with low profile tires on jacked up roads? Low profile offers no obsorbions and least reliable style of tires.
    ASRDogman likes this.
  7. ASRDogman
    ASRDogman Senior Member
    7,788
    3,975
    And how much do you spend for mounting and balancing?
    Grit likes this.
