Speakers sound bad after dash button replacement. Cause or coincidence?
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by cool_prius, Aug 15, 2025.
  1. cool_prius
    cool_prius Member
    106
    37
    United States
    2025 Prius
    One of the arrows on the gauge screen brightness buttons went out so I had Toyota replace it. Ever since then , my speakers sound bad. Tinny, not pleasant, and a significant loss of bass. I'm trying to figure out if the process of replacing that button could've touched something related to the sound system, or if its completely unrelated.
  2. cool_prius
    cool_prius Member
    106
    37
    United States
    2025 Prius
    Oh and ever since then my dashboard has a rattle on the left side and the steering wheel makes a clicky/crackly sound whenever I turn. So I at least know that the process was somewhat significant and not just prying the button out from the front.
    Also is the box thing that the turn signal and wiper stalks are attached to, supposed to jiggle when the steering wheel adjustment lever is in the unlocked position? Sometimes it rotates closer to the adjust lever and they scrape together. This is also something that was noticed only after the button replacement.
    Also yes I took it back for the rattles, but despite saying they secured everything, nothing changed.
  3. soft_r
    soft_r Active Member
    189
    156
    Beverly Hills
    2024 Prius
    2025 car, under full warranty
    Just take it back to the dealership and go find a sales person to sit you in a 5th gen on the lot. You can not only listen to that car's stereo but test the steering column jiggle. Then you can rip their service advisor a new donkey when you prove them wrong.
    Edit: Forum has filters to make naughty words not naughty. Imagine grown adults needing such things.
  4. Mendel Leisk
    41,946
    New donkey sounds ominous enough.
    I'm not that up on automotive speakers, is it possible to reverse speaker leads, so that they're out of phase (one pushing out while the other pulls in?
  5. daisy555
    daisy555 Senior Member
    1,727
    715
    CT
    Someone must of done a sloppy job putting things back together. Mysterious vibrations and rattles are loads of fun.
