Engine doesn't want to shut off sometimes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lumpy95, Sep 2, 2025 at 2:18 PM.
  1. lumpy95
    lumpy95 Member
    413
    70
    Mojave Desert, Cal.
    Thanks for the response.
    I haven't received any codes just the motor running problem.
  2. Mendel Leisk
    40,859
    My mistake: Dr Prius.
    lumpy95 likes this.
  3. lumpy95
    lumpy95 Member
    413
    70
    Mojave Desert, Cal.
    Thanks Mendel, I will check it out.
  4. bisco
    51,407
    when that happened to me, an italian tune up took care of it. but i think it might have been egr circuit clogging
    lumpy95 likes this.
  5. lumpy95
    lumpy95 Member
    413
    70
    Mojave Desert, Cal.
    Thanks for the response Bisco
    So it's possible that the egr may be the problem?
  6. bisco
    51,407
    it might be a possibility. normally, you're good for 100-150,000 in most cases i think.
    but the very low mileage may mean a lot of warm up time, and not much steady driving at temp.
    but it's just a guess.
    i had trouble at 87k, i think because it was a plug in, and the engine often ran just for a minute or two, not completing the warm up cycle.
    i never confirmed the egr, but had all the symptoms and traded it in.
    lumpy95 likes this.
  7. PriusCamper
    PriusCamper Senior Member
    12,242
    4,972
    Pacific Northwest, USA
    It's so easy... You just have to change the clock back to the correct time... An also any pre-sets you want on the stereo. For the window, rolling it all the way down and then all the way up to set the auto roll down function.
    lumpy95 and bisco like this.
  8. lumpy95
    lumpy95 Member
    413
    70
    Mojave Desert, Cal.
    Not bad, I thought there was more to it than that. Thanks
  9. lumpy95
    lumpy95 Member
    413
    70
    Mojave Desert, Cal.
    It's not warm up time, this is after I have been driving awhile so not sure from your experience of egr. Thanks
  10. bisco
    51,407
    i don't think i was clear. it's not when you get the symptom, it's what's causing the symptom. but idk if it's the egr circuit or not.
    there are four tiny ports in the intake manifold that clog
    lumpy95 likes this.
  11. rjparker
    9,783
    6,033
    A stuck open egr will make it stumble or stall at low rpms. A clogged egr will do nothing at low rpms. It is designed to be closed at those times.
  12. lumpy95
    lumpy95 Member
    413
    70
    Mojave Desert, Cal.
    No stumble or stalls just keeps running.
  13. Mendel Leisk
    40,859
    I would do an EGR cleaning by 50k, and every 50k thereafter. That will keep it more-or-less functioning as it should, moderating engine temps, and keeping them uniform across the cylinders.
    @bisco's correct that you'll likely be "good" till 100~150k, but "good" means the engine's head gasket will survive till somewhere around there, before the ever-more-clogged EGR system causes it's failure.
  14. bisco
    51,407
    the engine not shutting off thing is puzzling. i couldn't understand why it was happening on mine, or why the italian tune up fixed it.
    i could only think it blew some gunk out somewhere
    lumpy95 and Mendel Leisk like this.
  15. rjparker
    9,783
    6,033
    About the only thing running the car at maximum rpms for a period of time might do is dislodge some gunk on the throttle body. Cleaning the throttle body is easy as long as you can remove the air intake box and carefully use specific throttle body cleaner.
  16. lumpy95
    lumpy95 Member
    413
    70
    Mojave Desert, Cal.
    I have a feeling that whatever sensor/module that tells the motor to shutoff is having a random problem.
  17. rjparker
    9,783
    6,033
