2014 Prius V groans, pops and thunks in the front end... why?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by wrench, Aug 25, 2025.
  1. wrench
    wrench Member
    149
    55
    Sunnyvale, CA
    I have a 2014 Prius V and it has some issues related to the front end that I can't figure out....
    Problem #1:
    There is a slight 'tick' when I decelerate moderately aggressively, and a very audible 'thunk' when I then accelerate (for instance, at a stop sigh). I've not been able to nail this down. It is almost as though there is a bushing that has disappeared and the 'post' is now free to move around in the cavity previously occupied by the bushing. I cannot discern any play in the wheel when I jack up the car. The vehicle does have fairly recent (off-brand) wheel bearing and axles. The bolts for the wheel bearing carriers are tight.
    Problem #2:
    If I am sitting stationary and I turn the steering wheel back and forth, there is a significant amount of groaning and slight popping noises from the steering setup. It is very similar to what one would hear with low hydraulic steering fluid, but the Prius V does not have a hydraulic steering system; it is all electric. And, again, when I jack up the car and try to detect play in the wheels, I can't detect any.
    History:
    The vehicle has about 128K miles on it. The strut boots have completely disintegrated and I have some suspicion as to whether or not the struts are the source of the problem(s). I have been mulling over whether or not I should proactively replace the front struts, but I would like to be confident that this is actually the problem before I perform that work. This thought isn't because I'm against doing the struts, but more around the fact that I conceptually feel I should be confident I'm resolving the source of a problem versus the "throw new parts at it and see what works" approach.... Similarly, I'm wondering about the ball joints, but, again, there is no appreciable play in the wheels (left/right or up/down) when the vehicle is jacked up.
    Background:
    I am not a professional mechanic, but I do hold my own very well. I've done the wheel bearing on the car because they were definitely bad. The axles were replaced at the same time because the axle nuts buggered the threads. I've done ball joints on other vehicles because the boots were completely gone, and also suspension bushings on other cars. The Prius V is different than the Mini Cooper, however, where I can see how the "thunk" (problem #1) would come into play. The lower control arm looks to be fairly easy to visually determine if the bushing is bad, and it doesn't appear to be.
    Any help is greatly appreciated. I've tried to be thorough with the description, but if there is something you'd like me to clarify or test, just let me know. Thanks!
  2. rjparker
    9,783
    6,033
    The vertical sway bar links on both sides are a common issue.
    Air_Boss likes this.
  3. wrench
    wrench Member
    149
    55
    Sunnyvale, CA
    Great... thanks for the response. One question, though. Is that an issue for *both* problems or only #1 or #2?
    Regards.
  4. rjparker
    9,783
    6,033
  5. Mendel Leisk
    40,859
    How long have you had it, and how long have you been hearing the sounds?
  6. wrench
    wrench Member
    149
    55
    Sunnyvale, CA
    I bought the car about 3 years ago with 100K miles on it. The dominant issue at that time was an increasing growl from a wheel bearing that was going bad. I replaced that and the axles (latter as a result of the nuts damaging the threads). After this, I had a tick/thunk on acceleration (problem #1, not #2). That was an odd one because I torqued (and re-validated) the hub bolts several times. I finally took it to a "real" mechanic who said the bolts were too loose. I asked him what he torqued them to (and mentioned the specs in the service manual, which he also thought were pretty low) and he sheepishly said, "we just used an impact wrench on them...." I wasn't thrill with that answer, of course, and yes... these were very well rated mechanics and I can't say I ever had any issues with them in the past. Still, I am kind of a stickler for torquing correctly.
    Anyhow, the thunk on acceleration came back eventually (maybe 8-12 months later) and I checked the hub bolts. They were still tight. Roughly the same time, the groaning and popping (hard to explain the exact noise) started. Both have, frankly, gotten progressively louder. My initial thought was that it was the struts as the rubber boots are gone. But, the car isn't mushy at all when driving nor when I push down on the front wheels. Although the struts may well still be bad, I don't think that is the issue here. I've tried lifting the car and seeing if there is horizontal/vertical play in the wheels, but I haven't been able to discern any in the past. I have not tried that same test since the noises have become more prominent....
    At this point, the noise is loud enough that it really does need to be addressed. My wife no longer wants to drive the vehicle and I have to agree that I am not comfortable either. It isn't that I think it is going to fall apart, but something clearly isn't correct and that becomes a safety concern. I can start replacing parts, but that isn't the best way to address the issue. I'd rather have a more logical direction and plan of attack, meaning some identification of logical parts to replace (or diagnostic steps to identify the faulty part(s) and then replace that/those.
    I have ordered some sway links per rjparker's suggestion. I have some surgery coming up and some home construction going on at the same time (it has been the summer from hell) so it might take me a month or more before I actually get to the link installation though.
  7. Mendel Leisk
    40,859
    Any evidence (or record) of a collision?
    say suspension components appear different side to side (newer, older, rustier), paint overspray, whatever.
  8. wrench
    wrench Member
    149
    55
    Sunnyvale, CA
    No. There is no evidence of a collision, and the CarFAX was clean. The previous owner was the original purchaser of the vehicle and a fairly wealthy physician. Although that doesn't mean a ton, my strong suspicion is that she/they would have gotten rid of the car in a significant accident if there were any. It was dominantly used as a freeway commuter for about a 30 mile (one way) trip. This was a private party sale, and the vehicle had been regularly serviced at the local Toyota dealership. When I purchased my other V, I did so from the same dealership; I had my vehicle serviced there during the warranty period and, although expensive, I never had any complaints with their competency.
    #8 wrench, Aug 26, 2025
  9. wrench
    wrench Member
    149
    55
    Sunnyvale, CA
    So... bit of an update here...
    I ordered some links and they arrived today. However, I don't think I'll need them. Over the weekend, I decided to pull the wheels off again and give it another look see. The links look perfect, the boots are not broken, and there is no unusual play in there, so I'm pretty sure they are fine (but not positive). I looked at all of the other interface points and I couldn't see anything there either. The brakes can rotate back/forth and hit the studs, and I've wondered if that could be a problem, but this isn't anything different than you'd find on any other California (low rust state) car. Plus any new car would be fairly loose. Once the wheels are torqued to 76ft-lbs, I can't see that that would be a problem (not to mention the fact, that as I start, the brakes are disengaged so there would be no "thunk" there.
    What I did finally do was manage to snag my friendly wife. She always seemed to be unavailable when I was looking at this problem before. Anyhow, I had her rotate the steering wheel from stop to stop. Although not as pronounced as when the car is on the ground, and the suspension is loaded, there was definite groaning coming from the struts. I traced this to the top of the strut. As it moves around in the carrier, it has a very distinct, "I'm sleeping... leave me along... go away!" sound eminating from that area. So, I'm back to thinking that my problem is in both struts (both moaned and groaned more than my kids when they had to do homework!). I don't know if the thunking is also part of the struts, but given that I'll be replacing the struts, I guess I'll find out.
    The downside to all this is that I guess I'll have to do a wheel alignment now. That isn't the worst thing in the world to do if my problem gets fixed. Anyhow, that is the latest on the problem
  10. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,376
    2,361
    Taylors, SC
    Unless tge struts are leaking, the struts are fine. My 2012 v has shredded strut boots from UV exposure and age. They went at 33k miles.
    Just cut away the debris so that they don't get into and destroy the seals t o cause them to start leaking.
  11. wrench
    wrench Member
    149
    55
    Sunnyvale, CA
    I have both a 2012 (155K) and a 2014 (125K) and both have shredded rubber boots. Neither has any visible leakage, but only the 2014 groans really loudly when turning the wheel from stop to stop. It is pretty bad. I actually don't think the issue is so much the strut but the rubber carrier on TOP of the strut. Unfortunately I do not have the tools to remove the spring, so I cannot replace the rubber/top. It is easier to replace the entire strut. The second part of this is that I'm *hoping* the thunking (which has gotten quite unnerving) is still of unknown origin. THAT I want to fix. I no longer take the vehicle on the freeway simply because I am not sure where it is coming from. I'm hoping the strut replacement will magically fix the problem but??? I guess it is possible that the top carrier rubber is so buggered that this is the source of the thunking. I can't really see much up there. I haven't take the wiper/tray off to see if there is anything visible from the top because I really didn't expect this to be the area of the noise until last weekend when my wife turned the steering wheel.
  12. Georgina Rudkus
    3,376
    2,361
    Taylors, SC
    It might not be the top bearing swivel on the strut.
    I would examine the ball joints, the tie rod bushings and the contol arm bushings for cracks and movement.
  13. wrench
    wrench Member
    149
    55
    Sunnyvale, CA
    I'll do that again, but I've tried to identify the source before without great luck. When I was trying to get a better location this weekend, it definitely seemed as though the noises were far more pronounced higher up, and even louder when I stood up and was next to the top plate in the engine bay. I also took a diagnostic stethoscope and placed it against several areas (ball joints, etc) that I suspected could be problems. Although I'll not say my process was conclusive, the noise certainly seemed to be emanating from the top of the strut.
    I think what worries me is that everyone thus far has been suspicious of this determination. It makes me feel that I must be missing something. That is especially true because what I'm suggesting here isn't just a single strut failure, it is an identical issue with BOTH sides. That worries me. If you all, who I readily admit probably know more than I, are suspicious, it seems statistically unlikely that TWO struts would fail in the same car, at the same time. :(
  14. Georgina Rudkus
    3,376
    2,361
    Taylors, SC
    I would get the front wheels off of the pavement on jack stands and have a friend turn the steering from stop to stop.
    That way, you can use a stethoscope to listen to the pivot on the top of the struts and also do it with the wheels on the ground with the wheels loaded.
    I would also listen to the rack and pinion of the steering gear on each side while having your friend turn it to the limit of particular side.
    That may be the issue.
