Need Help - Rear frame near tyre rusted out/ Broken - Prius Gen 2 - 2004
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KiranV, Sep 4, 2025 at 1:05 AM.
  1. KiranV
    KiranV New Member
    Thursday
    Chicago
    Hello,
    I got this car at 208K miles in 2023, now it is at 241K miles. The bottom frame is completely rusted out. I am not into DIY or mechanic related stuff - don't have the necessary tools as well. I am attaching photos shared by the mechanic - He says it is not drivable at this rate and dangerous to do so. I need your help if you're experienced in this field / had prius with a similar problem, got a solution. Please don't bash me for my mistake buying an old car - the circumstances were much different when I got it. Any help would be much appreciated.
    Planning to sell this either get repaired/ as is. Also the front wheel bearing hub assembly needs to be changed.
    Thank you.
  2. Mendel Leisk
    40,886
    It definitely needs a new rear axle, say salvage from a down-south car. Still, that may just be tip of the iceberg, you should get a full assessment, repair proposal, and an estimated price.
  3. KiranV
    KiranV New Member
    Thursday
    Chicago
    So the mechanic says he can replace the part but since everything is rusted out he says I should first go to a body shop and see if they have something to do. Otherwise he says get rid of the car altogether. I'm confused. :(
    Thanks for your advice.
    #3 KiranV, Sep 4, 2025 at 12:09 PM
  4. Mendel Leisk
    40,886
    Yeah, again, with that degree of rust (completely rotted through, rear axle arm, second pic), there's likely more. Could be a rusty money pit.
    KiranV likes this.
  5. xw20_driver
    xw20_driver Junior Member
    60
    26
    PNW
    This looks like major body rust from a midwest rustbelt car (Chicago). Beyond the significant corrosion on the rear axle it also looks like parts of the under carriage are rusted through for a 21 year old car. Your mechanic seems correct about consulting a body shop if you are keen on repairing this car.
  6. KiranV
    KiranV New Member
    Thursday
    Chicago
    Thanks for the advice. Do you happen to know how much does a body shop charge on average? I would not go to repair it if its expensive, maybe sell it for cheap.
  7. Tombukt2
    12,593
    2,238
    There ain't no fixing that that is a complete disaster you go down souf and buy car every three years like vacay . Did it for years from Western Mass. You no fixing that
    KiranV and xw20_driver like this.
  8. Tombukt2
    12,593
    2,238
    Enough to give you a quick trip to the ER .you won't be doing any of it .
