Immobilizer All Keys Lost Reset - But can't get SKS Keys Registered
Discussion in 'Gen 2 Prius Main Forum' started by DashingDave, Feb 18, 2025.
  1. DashingDave
    DashingDave Junior Member
    39
    Monterey
    Can you help please ?
    Read dozens of posts on "All Keys Lost" resetting Immobilizer,
    but found exceedingly few about resetting the new SKS FOB Key Immobilizer Chip afterwards
    - which is where I'm stuck.
    Hardware -----------
    TechStream (ver 18.00.008)
    MVCI J2534 Cable v 1.79? - Possibly (not certainly) version shouldn't matter as
    it was used to successfully reset Immobilizer.
    Toyota Prius Smart Remote Car Key Fob MOZB31EG
    Software -----------
    Windows 7 SP1, 32 bit
    Java Installed
    .NET Framework 4.x - "Install Did Not Succeed"
    but .NET 3.5 is apparently "built in" to Win 7 and it appears to be there.
    Code from pin-online (Supports TS versions from 8-18, Octopus only vers 8-17)
    Process -----------
    Using TechStream. From System Menu - Immobilizer - Utility, Immobilizer Code --
    *** Immobilizer ECU Success - "All Keys Lost" Reset - showed 5 key slots available - 0 used.
    *** HOWEVER, now Can Not get a new Key FOB registered
    Firing up TechStream gets --
    "Reduced Functionality
    "Techstream was unable to access the network
    "Some information may not be available.
    "Features such as campaign validation will not function in offline mode"
    So I choose "Offline Mode"
    Under Immobilizer selecting "Transponder Code Registration (STR-09-002)"
    It asks me to "Remove Key from Key Slot"
    (But the key was not in Key Slot - because it never gave an instruction to put it in.)
    So I put a new FOB in for 5 seconds and then removed it.
    "Insert the key back in slot - did that.
    Gets me -- "Transponder Code Registration has failed.
    "The Inserted Key is not currently registered. Do you want to try again."
    Retries fail half a dozen times.
    When I try to register the key from Smart Key (on System Menu)
    It responds --
    "System Select Wizard (S303--05)
    "Selected System is not responding or not available.
    "Please check repair manual for applicable systems"
    Subsequently --
    Tried Re-Re-Setting Immobilizer - Failed 8 Times
    I'm pretty much out of things to try.
    What jumps out at you that I'm doing incorrectly?
    Thank you
    #1 DashingDave, Feb 18, 2025
  2. rjparker
    10,405
    6,519
    My understanding is you need the higher "Security Professional" access. To make things worse, Toyota has changed Techstream to a new version and has effectively disabled some features on the old version such as the ecu software access. Not sure about new key additions but that was always difficult without a working fob in hand.
    Many locksmiths do have Security Professional access, it might be necessary to contact one of them or the dealer.
    DashingDave likes this.
  3. DashingDave
    39
    Monterey
    Thank You RJParker !
    Wondering if I should try an earlier version of Techstream?
    The European Pass-Code folks only support up to version 17 - hmmm.
    I also had Techstream version 7 running (the 6 digit Seed-Code kind (pre 96 digits))
    but the Pass-code pin-online calculators only start with version 8.x
    You indicate techStream has "disabled some features on the old version"
    But if the software was released years ago - and since the Prius was built years ago
    - can't imagine how Techstream could modify any old software - except to re-release old versions.
    Not impossible, but never heard of any software company doing that.
    So maybe I should try getting Techstream version 8.x or 17.x running?
    #3 DashingDave, Feb 18, 2025
  4. rjparker
    10,405
    6,519
    The disabled ecu calibration (software) capability required an online access to retrieve the software. That access failed on the old version even though a user had purchased a legal version with a current subscription.
    Security of the immobilizer was always difficult and required the Security Professional access.
    Even with a hacked version many have reported problems with aftermarket interfaces.
    There may be a way but pro locksmith help is guaranteed when no working fob is available to make adding a fob easier.
    This response "The Inserted Key is not currently registered. Do you want to try again" suggests that function needs a working fob.
    #4 rjparker, Feb 18, 2025
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,076
    1,992
    NJ-USA
    Where did you get the fob? I don't know if that's the correct # for your car, but I wonder if it has a good RFID chip or not. Or if the dash slot works. (A locksmith should have a tool to check that stuff).
    Were there any codes in immobilizer-SKS systems (other than "no valid key" codes)?
  6. DashingDave
    39
    Monterey
    They (I bought two) are advertised as a "Key Fob fits 2004-2009 Toyota Prius Smart Keyless Entry Remote for SILVER LOGO (MOZB31EG)"
    So it claims to have the right number. (They are not Black Back keys - a common mistake.)
    Don't know how to test a key FOB, other than I have tried both - with no luck.
    One hardware failure is not unusual, but two - seriously unlikely - unless they suffer from the same PC board design or manufacturer error.
  7. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    When both are bought from the same seller, it is not a coincidence.
    Have you disassembled the key fobs?
    Is there a board chip for the radio channel?
    Is there a chip hidden in the plastic that looks like a small black and gray seed?
  8. DashingDave
    39
    Monterey
    Thank you for trying.
    No. I quoted every error returned (including exact capitalization. Note -your quoted text is not what I reported. See original post.)
    #8 DashingDave, Feb 19, 2025
  9. DashingDave
    39
    Monterey
    Yes, I disassembled both, they have something the same size & shape as the RFID chip.
    MAX2 likes this.
  10. MAX2
    MAX2 Senior Member
    1,436
    488
    101
  11. DashingDave
    39
    Monterey
    Thank you for hunting down the pictures of the FOB insides.
    I did answer above - Yes, each has "they have something the same size & shape as the RFID chip."
    But I examined them - there are no numbers identifying them as RFID chips.
    #11 DashingDave, Feb 20, 2025
  12. 2genowner
    2genowner New Member
    Rhode Island
    Just an FYI. I have a 2007 Prius that I purchased when the owner lost their key and did not want to spend the $ to get a locksmith.
    Purchased New key fobs from Amazon 2 from one seller and 1 more expensive from another.
    They are the Silver logo type with proximity which this car has. The lock smith confirmed they are the correct part number for the car. He was able to get the RFID part programmed so I can start the car with the fob in the slot but he could not get the proximity or Remote lock / unlock to work and could not figure out why. His program stated programming was successful but they would just not work. I was semi happy to be able to at least now start the car with the fob in the slot but I really want the proximity option to work. I have purchased the Cable and the cracked software for tech stream. I have connected the computer to the car and tested the setting up of tech stream but I have not yet figured out how I am going to attempt to get the proximity part working as it wants to start off with working key. but it works only for security in the slot so even if I try to fake it the steps say to press the lock button on the working remote but the working remote is in the slot locked because you need to have the Car in the on position to start? Dammed if I do and dammed if I don't?
  13. mr_guy_mann
    4,076
    1,992
    NJ-USA
    So, my understanding of an "all keys lost" scenario is that you need an "OE level" scantool. You go through the procedure as prompted by the tool. Somewhere you have to read out a very long ID code that's unique to your car.
    The dealer uses that ID to generate a "seed code" from their server. That code is entered into the ecu to reset the immobilizer - SKS and permit new fobs to be programmed.
    I have read that there is some site in Europe where you can buy "tokens" and do the same thing.
  14. 2genowner
    Rhode Island
    Ok here is an update. I got the token from Europe web site and got a passcode calculated to reset / reseed the SKS part of the system in tech stream. Completed that procedure now I have no (0) keys registered. Now the prompts in tech stream bypass press the button on master fob because it knows there are none, but jumps right to press the lock and unlock simultaneously for 1 second and then press the lock. I tried this on all three fobs that where programmed for the car for the immobilizer part, but none will register. I got a 4th one new and tried to just do sks part and it also does not register. So now I am wondering is there something wrong with the ECU or some other part of this system? and yes the key button below the steering wheel is not pressed in and I even unplugged that switch in case it was shorted out (even though the meter says it is working fine). Don't know what to test or try next. the RFID chip part is working so I can start car and drive with the fob in the key slot but unlocking and locking doors are a pain using the mechanical key all the time.
