Better sound on the cheap
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by Downrange, Feb 4, 2025.
  1. Downrange
    Downrange Active Member
    372
    209
    2024 Prius Prime
    SE
    I've been putting replacement dash tweeters in Priuses since 2013. I use Infinity models that are direct bolt-ins and sound much better than the paper coned whizzers in the stock Toyota system. This time I opted to have a small commercial shop handle the install and added a small sub. I'm not a thumping bass fan, but just wanted a little fill below 60 cycles or so, and didn't want to break the bank either. I chose a PowerBass PS-DF110T, which is an amplified unit with a 10 inch woofer. I replaced the dash speakers with Infinity REF-3032 CFX tweeters. I have left off the included capacitors in the past with these, but used them this time to avoid some minor resonances in the dash I encountered last time I installed them full range. I must say, they really sound great! The stock "woofer" units in the doors are blended down, with a slight forward emphasis on the sound adjustments. The Sub is set to come in mainly below 65 hz or so, with just enough fill to bring in some needed low end. This is not a thump-boom system! But I listen more to jazz and softer rock anyway. I'm very impressed with how these mods worked in my 24 Prius Prime, and the total cost for two install sessions plus equipment was around 600.00 all in. The sub is in the back, blends in well with the decor, and can be removed in a couple of minutes if I need that extra space.
    PS-DF110T 10" Downfiring Enclosure
    Sorry Spamazon link to Infinity tweeters won't copy/pasta without a lot of personalized codswallop - just do a search, They're 50 bucks!! Deal of the century, if you ask me!
    #1 Downrange, Feb 4, 2025
    PrimeDan and twiin like this.
  2. twiin
    twiin New Member
    Orange County, CA
    2025 Prius
    Looks great! I have a 2025 Prius LE with stock speakers that also need upgrading.
    Would you happen to know the wiring process for the sub and amp? And for those tweeters, were they just a simple switcheroo/plug and play?
  3. Downrange
    372
    209
    2024 Prius Prime
    SE
    Sorry, just saw this. The tweeters bolt right in! The installer took the sub feed from a door speaker. The sub has the amp built in, and put a level control under the dash on driver side. It's a good bang for the buck, but don't expect to rattle the windows.
    Julio_E likes this.
  4. Mendel Leisk
    41,315
    When you say "tweeters" you're referring to everything but a sub?
    #4 Mendel Leisk, Aug 6, 2025
  5. Julio_E
    Julio_E Junior Member
    Michigan
    2024 Prius Prime
    XSE Premium
    Thanks too. I think I may eventually try these tweeters and what you said about these tweeters here.
  6. Hammersmith
    Hammersmith Senior Member
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Generally, tweeters refer to the small speakers in the dash. The standard gen5 has a pair of 3.5" tweeters in the corners of the dash. The cars with the JBL sound system also have a pair of 1" tweeters in the A-pillars(sometimes called super tweeters). The speakers in the doors are generally referred to as woofers, though they can also sometimes be referred to as mids depending on the car/installation. No gen5 comes stock with a subwoofer(sub).
    There's also full-range vs. component. All versions of the Prius use component(though it's not a high-end version). Full-range means a tweeter and woofer(or more) combined into a single speaker. Component means separate speakers for each pitch range. If you have a car with only two speakers in the front(one in each door), you'd want to install full-range speakers so that you could still get decent lows, mids and highs without having to custom mount another pair of speakers.
    Downrange and RandyPete like this.
  7. Mendel Leisk
    41,315
    I was thinking they’re all, or mostly, full range coaxials, could be wrong. Google’s AI says tweeters usually start around 2000 hz. For me that’s humming bird wings lol.
  8. Downrange
    372
    209
    2024 Prius Prime
    SE
    For my money, deliberately kept low, the door units are mostly mid-bass and midrange, and the dash tweeters handle the most critical frequencies around 150 hz and up. This is where a large improvement can be bought for small bucks. The sub I chose fills in a bit from 40 hz to 100 hz where the door units fall off. I've found the cheap paper dash units add a lot of harshness in the upper mids and high frequencies and are the single biggest improvement in overall sonic presentation. YMMV.
    soft_r and Julio_E like this.
  9. Humble Bear
    Humble Bear Member
    130
    49
    Arcadia, CA
    2024 Prius
  10. Eqcliu
    Eqcliu New Member
    SF
    2025 Prius Plug-in
    SE
  11. Eqcliu
    Eqcliu New Member
    SF
    2025 Prius Plug-in
    SE
    I bought these speakers for $50 in Amazon and installed them a month ago. Here are some notes:
    • These speakers make the stock Toyota speaker feel like toys. They also have 2 drivers per speaker which is nice (4" driver + little tweater on top).
    • Installation was surprisingly simple, though you do have to cotort to some awkward positions to reach the speakers. The Polk audio speakers come with all the connectors to install without any wire stripping or soldering required. Total installation took me maybe 20 minutes.
    • Sound wise the sibilance is crazy. I had to use the head unit EQ to tune down treble and tune up mids + bass to balance things out. However they definitley sound much better than the non-JBL stock speakers after tuning.
  12. Humble Bear
    Humble Bear Member
    130
    49
    Arcadia, CA
    2024 Prius
    I tuned the treble at the 2nd position next to the farest left. Bass in the middle. Note, I did use some foam weather strips bought from Home Depot around the gaps between the speaker and the mount in order to get the bass.
  13. PrimeDan
    PrimeDan New Member
    Philly Suburbs
    2024 Prius Prime
    SE
    Can you share the brand and name of the speakers? Not sure if you can post a link since you're a new member here.
  14. Hammersmith
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The problem is that he posted an Amazon link. For whatever reason, this site can't show them correctly. It automatically treats them as a media file instead of a hyperlink. From context, it sounds like it was a Polk speaker of some type, probably the DB402(currently $56 on Amazon).
    #14 Hammersmith, Sep 30, 2025
    PrimeDan likes this.
  15. Eqcliu
    Eqcliu New Member
    SF
    2025 Prius Plug-in
    SE
    Interesting, I did not do that. I'll give it a try next time I have a free weekend.
  16. Mendel Leisk
    41,315
    I’ve found pasting Amazon links into selected text avoid the problem. Also works for links from one site which had gargantuan address strings (name eludes me).
  17. Zeromus
    Zeromus Active Member
    553
    307
    Ottawa Canada
    2024 Prius Prime
    SE
    My Matrix, on the way out, currently has some very old Kicker RS series speakers. The crossover has a bad capacitor that I need to pull out and resolder, as the last attempt to repair it has given away after many years again. But, perhaps I try to fix it again, and I can cannibalize the old speakers and have someone install them in my prius. Would save me a lot of time assuming they haven't gotten too rusty on the magnets over the years. I did buy them nearly 10 years ago now, but they work great otherwise. No harm in giving them another life, they sound great in the old car after all (except for the bad crossover box lol). Though maybe I wouldn't need the crossover box at all, assuming that the prius runs its own wiring to the tweeter separately.
