Do I need a new 12v battery?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by BlueV15, Sep 7, 2025.
  1. BlueV15
    BlueV15 Junior Member
    27
    Southern California
    2015 Prius v wagon
    I've read some stuff about checking the 12v battery and I did a test over 3 days with the car off.
    After 24 hours - 12.2v
    After 48 hours - 12.2v
    After 72 hours - 12.18v
    I can't find a date on the battery, but it's a Toyota battery, so it may be the original battery. The car starts and runs normally and nothing seems out of the ordinary. Do I need a new one or can I stretch this one out longer?
  2. rjparker
    10,093
    6,260
    10 years is stretching it a bunch. The problem is an old battery on a Prius is not obvious with signs like slow cranking. As a result you could drive it 5 miles and park it at the grocery store or mall only to find yourself with a no start 1 hour later.
    But there is a test and it is not voltage readings over time. It is a load test free at most auto supplies.
    BiomedO1 likes this.
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,231
    824
    Monument, Colorado USA
    Yep, visit your dealer and buy a Toyota TrueStart....comes with an 84-month warranty! (Last year, I spent $208 for one for my daughter's 2017 Prius.)
  4. BiomedO1
    3,509
    1,823
    SacTown, Ca
    Yep, get it load tested at any auto parts store to confirm it's validity.
    Keep an eye out for future sales and maybe buy a cheap jump-box, just in case you get stranded some place.
    Good Luck....
  5. BlueV15
    27
    Southern California
    2015 Prius v wagon
    I'm not sure if the battery is original or if it was replaced by the previous owner, I'm unable to see a date sticker. I don't want to waste money on a replacement if the battery is still usable. The voltages are in the acceptable range for what I could find online. Where, on the battery, should the date be?
  6. BiomedO1
    3,509
    1,823
    SacTown, Ca
    There's a date/manufacturer code stamped into the plastic somewhere.
    Voltage is only ONE parameter to check on a battery - again, it needs to be load tested - see post #4........
    #6 BiomedO1, Sep 9, 2025
  7. rjparker
    10,093
    6,260
    Voltage is a worthless measure of a batteries health. Load testing will tell you if it can hold a charge for a day, a week or month.
    Air_Boss, Danno5060 and BiomedO1 like this.
